Hi all
Would you mind if we ask DP83867IR?
<Question1>
Our customer would like to use following pulse trans.
http://productfinder.pulseeng.com/products/datasheets/JXD1-0015NL.pdf
It seems that the value of turn ration is spec out(1:1@±2%, 100kHz).
So, we will recommend HX5008FNL.
<Question2>
In relation with <Question1>, wihich construction is better about pulse trans?
-HX5008L : Trans -> common mode filter -> Center tap with Bob smith AC termination -> RJ45
-JXD1-0015NL : Trans -> Center tap with Bob smith AC termination -> common mode filter -> RJ45
Kind regards,
Hirotaka Matsumoto
