I would like to know whether DP83867 ethernet PHY supports 1000Base-KX standard or not?
If not , please suggest any part number which supports 1000Base-KX standard with SGMII interface.
Usha
Hey Usha,
I don't believe that any of the PHY outputs for SGMII will output the sufficient rise times to clear the 1m requirement. You will have to look at getting an Ethernet re-driver or multi-use buffer to get the reach that you're looking for. A list of TI products that you can look through to meet your projects specific needs can be found here.
If this answered your question please verify the answer below by hitting the green button, it goes a long way in helping others with similar issues solve their problems more quickly! If you have additional questions feel free to send them my way and I will work to resolve them for you.
Nick
We are not working on any backplane concept. We are working on design of access point.
So, We are looking for a Gigabit Ethernet link with SGMII interface. It should support 1000KX mode . Please check and suggest.
Usha
