Currently, when using auto-negotiation, it is linked with 10Base-T (advertise) equipment, but it is a problem in packet transmission.
TX normally goes out, but RX seems to be broken.
The DP83867IS states that it supports 10Base-Te, not 10Base-T.
It is related to EEE, so it seems that we need to set up something extra to communicate with devices that only support 10Base-T.
Looking at below link, the voltage level seems to be low.
https://e2e.ti.com/support/interface/ethernet/f/903/t/501970
In the document below
10BaseT will transmit with 10BaseT
10Base-Te seems to be transmitting with 10Base-Te.
I suspect that maybe 10Base-Te's RX does not recognize 10Base-T properly.
Can you check it out?
thanks,
TS
