We are using the DP83867IS component on an adapter board between SGMII and physical ethernet (RJ45-> cable). The following confguration we are using:
- SGMII as 4 wire interface
- physical interface: 10/100 BaseT
- Strapping: RX_D0: mode 1, RX_D2: mode 1, RX_CTRL: mode 3, GPIO_0: mode 1, GPIO_1: mode 1, LED_2: mode 1, LED_1: mode 1, LED_0: mode 2
With that configuration we get the following problem (client = physical interface, server = SGMII):
- datatransfer from server to client (from SGMII to physical interface) works fine; we are getting transfer rates of appr. 77MB/s
- data transfer from client to server (from physical interface to SGMII) works wrong; we are getting transfer rates of appr. 200kB/s
Have you got any idea, what we could do to fix that problem?
