DP83849IF: DP8349IF
Part Number: DP83849IF
I plan to use DP83849IF to build a media converter. As an optical transceiver, a module will be used in the SFP form factor. The documentation for the DP83849IF chip shows the connection diagram for the optical transceiver of the form factor 1x9.
How should the DP83849IF connection and the SFP form factor transceiver be made?
BR
Andrey
