Other Parts Discussed in Thread: DP83867E
We are using "DP83867ERGZ" component in our design. We had some doubts while using SGMII interface in our design. The PHY is configured for 2.5V VDDIO.
It is mentioned in the datasheet that "The SGMII interface uses 1.25-Gbps LVDS differential signaling" and "The 1.25-Gbps rate of SGMII is excessive for 100-Mbps operation".
- If I am configuring the SGMII interface for 1Gbps will the PHY operate in 1.25Gbps?
- Can I still operate the PHY at lower speeds (software configurable) after I boot the PHY in 1Gbps?
