I work on a radio frequency design in the 900 MHz band with a coaxial antenna connector (50 Ohm impedance).
Our customers will connect whip antennas or other antennas to the coaxial connector. For this reason we need a good ESD protection.
But it is important, that on the one hand the ESD protection doesn't reduce receiving sensitivity (low capacitance) and on the other hand is
compatible with the radio output power of 2Watt.
Can you recommend me the best approach for this problem? Or can you recommend literature?
Thank you very much!
