As far as I can tell, the circuits for SCL and SDA channels appear to be identical. I want to swap the lines for layout reasons, but I'm worried I will encounter some problem.
So, for example, current layout is:
MASTER_SDA <=> SDA1 - SDA2 <=> SLAVE_SDA
MASTER_SCL => SCL1 - SCL2 => SLAVE_SCL
I want to change to:
MASTER_SDA <=> SCL1 - SCL2 <=> SLAVE_SDA
MASTER_SCL => SDA1 - SDA2 => SLAVE_SCL
This shouldn't cause any problems for I2C @ 400kHz translating from 1.8V to 3.3V, correct?
