Tool/software: Linux
Hi Team,
I attached the two uart files for read and write.
1)my problem is after running both read and write from /dev/ttyUSB0, read will work one time and then write will happening. but after write read is not working.
2)sometimes whatever i am write the data read program reading the same data.
3)This is happening when pc and end device communicating through UART.
4)please guide me how to solve the problem.
3652.uart_write.c
/*====================================================================================================*/ /* Serial Port Programming in C (Serial Port Write) */ /* Non Cannonical mode */ /*----------------------------------------------------------------------------------------------------*/ /* Program writes a character to the serial port at 9600 bps 8N1 format */ /* Baudrate - 115200 */ /* Stop bits -1 */ /* No Parity */ /*----------------------------------------------------------------------------------------------------*/ /* Compiler/IDE : gcc 4.6.3 */ /* Library : */ /* Commands : gcc -o serialport_write serialport_write.c */ /* OS : Linux(x86) (Linux Mint 13 Maya)(Linux Kernel 3.x.x) */ /* Programmer : Rahul.S */ /* Date : 21-December-2014 */ /*====================================================================================================*/ /*====================================================================================================*/ /* Running the executable */ /* ---------------------------------------------------------------------------------------------------*/ /* 1) Compile the serialport_read.c file using gcc on the terminal (without quotes) */ /* */ /* " gcc -o serialport_write serialport_write.c " */ /* */ /* 2) Linux will not allow you to access the serial port from user space,you have to be root.So use */ /* "sudo" command to execute the compiled binary as super user. */ /* */ /* "sudo ./serialport_write" */ /* */ /*====================================================================================================*/ /*====================================================================================================*/ /* Sellecting the Serial port Number on Linux */ /* ---------------------------------------------------------------------------------------------------*/ /* /dev/ttyUSBx - when using USB to Serial Converter, where x can be 0,1,2...etc */ /* /dev/ttySx - for PC hardware based Serial ports, where x can be 0,1,2...etc */ /*====================================================================================================*/ /*-------------------------------------------------------------*/ /* termios structure - /usr/include/asm-generic/termbits.h */ /* use "man termios" to get more info about termios structure */ /*-------------------------------------------------------------*/ #include <stdio.h> #include <fcntl.h> /* File Control Definitions */ #include <termios.h> /* POSIX Terminal Control Definitions */ #include <unistd.h> /* UNIX Standard Definitions */ #include <errno.h> /* ERROR Number Definitions */ void main(void) { int fd;/*File Descriptor*/ printf("\n +----------------------------------+"); printf("\n | Serial Port Write |"); printf("\n +----------------------------------+"); /*------------------------------- Opening the Serial Port -------------------------------*/ /* Change /dev/ttyUSB0 to the one corresponding to your system */ fd = open("/dev/ttyUSB0",O_RDWR | O_NOCTTY | O_NDELAY); /* ttyUSB0 is the FT232 based USB2SERIAL Converter */ /* O_RDWR Read/Write access to serial port */ /* O_NOCTTY - No terminal will control the process */ /* O_NDELAY -Non Blocking Mode,Does not care about- */ /* -the status of DCD line,Open() returns immediatly */ if(fd == -1) /* Error Checking */ printf("\n Error! in Opening ttyUSB0 "); else printf("\n ttyUSB0 Opened Successfully "); /*---------- Setting the Attributes of the serial port using termios structure --------- */ struct termios SerialPortSettings; /* Create the structure */ tcgetattr(fd, &SerialPortSettings); /* Get the current attributes of the Serial port */ cfsetispeed(&SerialPortSettings,B115200); /* Set Read Speed as 9600 */ cfsetospeed(&SerialPortSettings,B115200); /* Set Write Speed as 9600 */ SerialPortSettings.c_cflag &= ~PARENB; /* Disables the Parity Enable bit(PARENB),So No Parity */ SerialPortSettings.c_cflag &= ~CSTOPB; /* CSTOPB = 2 Stop bits,here it is cleared so 1 Stop bit */ SerialPortSettings.c_cflag &= ~CSIZE; /* Clears the mask for setting the data size */ SerialPortSettings.c_cflag |= CS8; /* Set the data bits = 8 */ SerialPortSettings.c_cflag &= ~CRTSCTS; /* No Hardware flow Control */ SerialPortSettings.c_cflag |= CREAD | CLOCAL; /* Enable receiver,Ignore Modem Control lines */ SerialPortSettings.c_iflag &= ~(IXON | IXOFF | IXANY); /* Disable XON/XOFF flow control both i/p and o/p */ SerialPortSettings.c_iflag &= ~(ICANON | ECHO | ECHOE | ISIG); /* Non Cannonical mode */ SerialPortSettings.c_oflag &= ~OPOST;/*No Output Processing*/ if((tcsetattr(fd,TCSANOW,&SerialPortSettings)) != 0) /* Set the attributes to the termios structure*/ printf("\n ERROR ! in Setting attributes"); else printf("\n BaudRate = 115200 \n StopBits = 1 \n Parity = none"); /*------------------------------- Write data to serial port -----------------------------*/ char write_buffer[256]; /* Buffer containing characters to write into port */ int bytes_written = 0; /* Value for storing the number of bytes written to the port */ while (1) { if ((bytes_written = read(fd, write_buffer,sizeof(write_buffer))) > 0) { if ((bytes_written = write(fd,write_buffer,strlen(write_buffer))) > 0) { printf("%s", write_buffer); } } } close(fd);/* Close the Serial port */ }
5732.uart_read.c
/*====================================================================================================*/ /* Serial Port Programming in C (Serial Port Read) */ /* Non Cannonical mode */ /*----------------------------------------------------------------------------------------------------*/ /* Program reads a string from the serial port at 9600 bps 8N1 format */ /* Baudrate - 115200 */ /* Stop bits -1 */ /* No Parity */ /*----------------------------------------------------------------------------------------------------*/ /* Compiler/IDE : gcc 4.6.3 */ /* Library : */ /* Commands : gcc -o serialport_read serialport_read.c */ /* OS : Linux(x86) (Linux Mint 13 Maya)(Linux Kernel 3.x.x) */ /* Programmer : Rahul.S */ /* Date : 21-December-2014 */ /*====================================================================================================*/ /*====================================================================================================*/ /* www.xanthium.in */ /* Copyright (C) 2014 Rahul.S */ /*====================================================================================================*/ /*====================================================================================================*/ /* Running the executable */ /* ---------------------------------------------------------------------------------------------------*/ /* 1) Compile the serialport_read.c file using gcc on the terminal (without quotes) */ /* */ /* " gcc -o serialport_read serialport_read.c " */ /* */ /* 2) Linux will not allow you to access the serial port from user space,you have to be root.So use */ /* "sudo" command to execute the compiled binary as super user. */ /* */ /* "sudo ./serialport_read" */ /* */ /*====================================================================================================*/ /*====================================================================================================*/ /* Sellecting the Serial port Number on Linux */ /* ---------------------------------------------------------------------------------------------------*/ /* /dev/ttyUSBx - when using USB to Serial Converter, where x can be 0,1,2...etc */ /* /dev/ttySx - for PC hardware based Serial ports, where x can be 0,1,2...etc */ /*====================================================================================================*/ /*-------------------------------------------------------------*/ /* termios structure - /usr/include/asm-generic/termbits.h */ /* use "man termios" to get more info about termios structure */ /*-------------------------------------------------------------*/ #include <stdio.h> #include <fcntl.h> /* File Control Definitions */ #include <termios.h> /* POSIX Terminal Control Definitions */ #include <unistd.h> /* UNIX Standard Definitions */ #include <errno.h> /* ERROR Number Definitions */ void main(void) { int fd;/*File Descriptor*/ printf("\n +----------------------------------+"); printf("\n | Serial Port Read |"); printf("\n +----------------------------------+"); /*------------------------------- Opening the Serial Port -------------------------------*/ /* Change /dev/ttyUSB0 to the one corresponding to your system */ fd = open("/dev/ttyUSB0",O_RDWR | O_NOCTTY); /* ttyUSB0 is the FT232 based USB2SERIAL Converter */ /* O_RDWR - Read/Write access to serial port */ /* O_NOCTTY - No terminal will control the process */ /* Open in blocking mode,read will wait */ if(fd == -1) /* Error Checking */ printf("\n Error! in Opening ttyUSB0 "); else printf("\n ttyUSB0 Opened Successfully "); /*---------- Setting the Attributes of the serial port using termios structure --------- */ struct termios SerialPortSettings; /* Create the structure */ tcgetattr(fd, &SerialPortSettings); /* Get the current attributes of the Serial port */ /* Setting the Baud rate */ cfsetispeed(&SerialPortSettings,B115200); /* Set Read Speed as 9600 */ cfsetospeed(&SerialPortSettings,B115200); /* Set Write Speed as 9600 */ /* 8N1 Mode */ SerialPortSettings.c_cflag &= ~PARENB; /* Disables the Parity Enable bit(PARENB),So No Parity */ SerialPortSettings.c_cflag &= ~CSTOPB; /* CSTOPB = 2 Stop bits,here it is cleared so 1 Stop bit */ SerialPortSettings.c_cflag &= ~CSIZE; /* Clears the mask for setting the data size */ SerialPortSettings.c_cflag |= CS8; /* Set the data bits = 8 */ SerialPortSettings.c_cflag &= ~CRTSCTS; /* No Hardware flow Control */ SerialPortSettings.c_cflag |= CREAD | CLOCAL; /* Enable receiver,Ignore Modem Control lines */ SerialPortSettings.c_iflag &= ~(IXON | IXOFF | IXANY); /* Disable XON/XOFF flow control both i/p and o/p */ SerialPortSettings.c_iflag &= ~(ICANON | ECHO | ECHOE | ISIG); /* Non Cannonical mode */ SerialPortSettings.c_oflag &= ~OPOST;/*No Output Processing*/ /* Setting Time outs */ SerialPortSettings.c_cc[VMIN] = 10; /* Read at least 10 characters */ SerialPortSettings.c_cc[VTIME] = 0; /* Wait indefinetly */ if((tcsetattr(fd,TCSANOW,&SerialPortSettings)) != 0) /* Set the attributes to the termios structure*/ printf("\n ERROR ! in Setting attributes"); else printf("\n BaudRate = 115200 \n StopBits = 1 \n Parity = none"); /*------------------------------- Read data from serial port -----------------------------*/ tcflush(fd, TCIFLUSH); /* Discards old data in the rx buffer */ char read_buffer[128]; /* Buffer to store the data received */ int bytes_read = 0; /* Number of bytes read by the read() system call */ int i = 0; while (1) { if ((bytes_read = read(fd,&read_buffer,127)) > 0) { printf("%s", read_buffer); } } close(fd); /* Close the serial port */ }
