SN75DP130: Which pins would be affected by VDDD power supply ?
Guru 19775 points
Part Number: SN75DP130
Hi Team,
Could you please allow us to ask you which pins would be affected by VDDD pin ?
Regarding the datasheet, we understand that they affects main links which are IN0,IN1,IN2,IN3, OUT0, OUT1, OUT2, OUT3.
Since VDDD is also supplied to the low voltage core, which other pins would be affected by VDDD ?
Kawai
