Other Parts Discussed in Thread: DP83TC811
Dear TI:
My client used DP83TC811S-Q1, and they found the chip can't into sleep mode.
1, The initial setting: wake pin(pin8) is set to high.
2, And set wake pin to low first, than configure the correlation register of sleep----
0x18b set to 0x5b
0x4e5 set to 0xC3
0x487 set to 0xa01
0x18c set to 0x2
System debug log as below:
But the chip can't into the sleep mode , test the INH pin(pin 10) still low level.
Can you help to give some advice? Does the chip still need to do other configuration?
Thanks!
