Other Parts Discussed in Thread: TEST2
Hi Sirs,
Sorry to bother you.
It’s heard from Qualcomm that their reference has pull high at pin “TEST2” it should be determined by our panel used , and then decide the TEST pin pull high/low.
Therefore, we need you to check 2 thing:
- Check schematic (refer to the attached” DSI_TO_DP_BRIDGE.pdf”)
- Check the Test pins high or low with our LCM panel (refer to the attached” LQ125T1JX03.pdf”)
Thanks!!
