Dear,
we use TUSB9261, but have probability cannot find SATA device.
Is normal?
below as schematic:
If any suggestion, Please advise me.
Lawrence.
Dear,
Is normal?
below as schematic:
Lawrence.
Dear Brian,
Currently we use TUSB926x_FW_v1.06_USB3_only.bin , checksum:9271 and OS: Win10 64bit.
TUSB926x_FW_v1.06_USB3_only.bin.zip
If any, Please advise me.
Lawrence.
Hi, Brian
it's 40Mhz.
have other item to check? firmware need to update?
Lawrence.
Hi, Brian
end customer is PEGATRON Corp, so your mean the firmware version was not unofficial release?
Lawrence.
Hi Lawrence,
None of the firmware files we release for the TUSB9261 have the text "USB3_only" in the file name. Where does this firmware come from?
Also, would you please try the solution presented in the E2E issue, TUSB9261: Software Question? It explains which firmware should be used for your system.
Based on your schematic, it looks like the SATA polarity is not swapped. The default firmware assumes there is a polarity swap on the TX SATA signal similar to the way it is done in our TUSB9261DEMO EVM. This may be why the SATA device is not found.
Hi, Brian
cannot found STAT device , we need reset computer could be workable.
now we will try A-B-A TUSB9261 EVM to verify.
Lawrence.
