For MIPI input, customer's DP to MIPI bridge IC is designated for to two separated LCD for left & right eye, so that there is a skew(tSK) 1.88us between mipi port 00 & mipi port 10
May I know if it is ok for SN65DSI85?
Thanks!
Antony
Thanks!
Antony
Hi Antony,
If that is less than 9 DSI HS clock cycles as the image depicts, then it should be fine.
I.K.
Hi I.K.,
Thanks for your reply.
But since customer project is dual panel 1280*720, with DSI clock cycle is around 4.4ns.
Their DP to MIPI bridge IC skew could achieve 1.88us which is larger than 9*cycles…
What would be the risk for this ? Anyway to solve or improve it?
Thanks!
Antony
Hi Antony,
They should try and reduce the skew so that it is within datasheet recommendations. 1.88us is very excessive.
I.K.
HI I.K.,
May we know what could the exactly application issue from such a long skew? No display? Display with lots of noise.....?
Thanks!
Antony
