my customer is using DP83867IR and sees voltage differences higher 1%, mostly 2 % which is a problem.
they use the 1000BASE-T STandard with our DP83867IRRGZ and use the TDSET3 Ethernet Compliance test.
DO we also test that on our devices?
If yes, can you send me the results?
What could be a cause of this percentage voltage deviation?
Thank you for your help,
kind regards,
Marion
