TPS65987DDJ: Windows 19H2 HLK test failure
Part Number: TPS65987DDJ
Hi, everyone,
We're designing PC using TPS65987DDJ,
OS: Windows 10 (19H2)
Base FW: F807.12.37
and now, we've faced the problem about HLK test:
Fail:  UCSI Power Direction Role command - Reset on PPM-Reset
Fail: UCSI GetPDOs, partner Source Capabilities
Have you heard concerned problems?
By the way, we passed same test by our product using TPS65987DDH.
Base FW: F707.10.05
So we wonder if there're any countermeasure uncontained in DDJ FW against 19H2 HLK test.
  • Hi Maurice,
    Would you be able to share your UCSI test logs for each failure? Also, if you have a logic analyzer, could you capture the I2C communication between the EC and our PD controller during these commands? Finally, if you could share a CC capture between the port under test, and the UCSI tester during each of these UCSI tests. Having these three pieces of information should help us solve the issue.
  • Hi, Adam-san,
    I sent your colleague Yone-san these log files (HLK, I2C, USBPD)
    about these 2 failure:
    So please confirm these files.
    About HLK log file, this software is available.
    Please click the link "Windows HLK, version 1903".
  • Hi, Adam-san,
    Thank you for your reply.
    We've solved these 2 problem by EC.
    So I'll close this topic.
    Thank you for your cooperation.
  • Hello Maurice-san,
    Glad to hear you were able to resolve the issue. Apologize for not replying sooner, I have been out on business travel. Let me know if you have any other questions
