Other Parts Discussed in Thread: TPS65987D
Hi team,
My customer is desiging our TPS65987DDJ in their monitor application and they are testing for type C Vbus short circuit.
The short circuit timing is 1 ~ 3 seconds. However, in our Global System Config, the max "Error Recovery Time" is 1 seconds.
In this case, when the short circuit is longer than 1 seconds, the PD will not be able to automatically recover from the fault, and need to perform cable unplug-replug.
Is there any other way to recover the fault?
could we issue reset command from EC or scalar? what will be a good delay time if do so?
Any different in term of behaviour if we use internal power path, vs external MosFET path?
SK Loo
