DS250DF230: Could you tell me difference between Beta(A0) and Beta(A1)?
Guru 29690 points
Part Number: DS250DF230
Hi Team,
My customer has DS250DF230EVM and mounted device is DS250DF230 Beta(A0) that REG_F0 is 0x00.
I think DS250DF230 Beta(A1) that REG_F0 is 0x01 is new version so could you tell me the difference?
Yaita
  • someone will reply soon
  • May I have your reply?
    Yaita
  • Hi Yaita-san,
    The DS250DFD230 Rev A0 vs A1 designs are nearly identical. There are only three small functional changes in A1 production silicon over A0, as listed below.
    • Improved eye opening margin at extreme high temperature
    • Optimization to tighten CDR lock time distribution across PVT
    • Added bit control to the Tx output amplitude for when the channel is configured in CDR bypass mode
    Cordially,
    Rodrigo Natal
    HSSC Applications Engineer
  • Hi Rodrigo-san,
    Thank you for your kind support.
    I would like to ask additional questions as following.
    •Improved eye opening margin at extreme high temperature
    [Yaita] I understand.
    •Optimization to tighten CDR lock time distribution across PVT
    [Yaita] What does "PVT" mean?
    •Added bit control to the Tx output amplitude for when the channel is configured in CDR bypass mode
    [Yaita] I confirmed programmer's guide page 49 and understand it. Does A0 design fix at default setting (REG_0x1A[7:6] = 1)?
    Yaita
  • PVT stands for "process voltage and temperature"
    For A0 version when the retimer is set to CDR bypass mode the output amplitude is fixed and not adjustable; this value is around ~700mVpp.
    Rodrigo Natal
