Hi technical support team,
1. For the case of Figure 27 in datasheet, both HPD pins are High, Channel A and Channel B is switched by Priority pin. In this case is the data output simply switched from Channel A to Channel B? Is SN75DP128A not watching Link Training status?
2. A customer use case is attached. Is this use case feasible?
UI Display in the diagram has customized DisplayPort which does not have AUX and HPD pin. Main Link is single lane. UI Display is on DP_B. ANX1122 (analogix) is connected to DP_A where EDID/DPCD read and Link Training is proceeded. After Link Training completion, SN75DP128A switches to DP_B from DP_A and data (video signal) is displayed on UI Display. Please look into the attached diagram where every detail is described in.
SN75DP128A with Customized DP Display.xlsx
Katsuhiro
