[FAQ] DS110DF1610: How to setup DS126DF1610 to lock to different data rates
Part Number: DS110DF1610
Other Parts Discussed in Thread: DS125DF1610, SIGCONARCHITECT
For example, there is certain data rate within DS125DF1610 VCO range but it is not a standard rate. How do you setup the device to lock to this data rate?
  • In the attached presentation, we go over how to setup DS125DF1610 to lock to custom data rates. Please note this custom data rate custom data rate must e within the VCO range.
    Additionally we have attached SigconArchitect configuration file for these custom data rate as well.
    Regards,, NasserHow to set DS125DF1610 to lock to different data rates.pdf
    DS125DF1610 SigconArchitect GUI configuration file to enable lock to 10p1376Gbps and 4p9125Gbps data rates.txt
    0x0	Shared Registers_0x00	00
    0x1	Shared Registers_0x01	51
    0x2	Shared Registers_0x02	00
    0x3	Shared Registers_0x03	00
    0x4	Shared Registers_0x04	01
    0x5	Shared Registers_0x05	08
    0x6	Shared Registers_0x06	00
    0x7	Shared Registers_0x07	05
    0x8	Shared Registers_0x08	00
    0x9	Shared Registers_0x09	00
    0xA	Shared Registers_0x0A	01
    0xB	Shared Registers_0x0B	40
    0xC	Shared Registers_0x0C	00
    0xD	Shared Registers_0x0D	A0
    0xE	Shared Registers_0x0E	01
    0xF	Shared Registers_0x0F	FF
    0x10	Shared Registers_0x10	FF
    0x11	Shared Registers_0x11	00
    0xFC	Global Registers_0xFC	00
    0xFD	Global Registers_0xFD	80
    0xFE	Global Registers_0xFE	03
    0xFF	Global Registers_0xFF	00
    0x0	Rx/Tx 0A_0x00	00
    0x1	Rx/Tx 0A_0x01	00
    0x2	Rx/Tx 0A_0x02	00
    0x3	Rx/Tx 0A_0x03	00
    0x4	Rx/Tx 0A_0x04	01
    0x5	Rx/Tx 0A_0x05	01
    0x6	Rx/Tx 0A_0x06	01
    0x7	Rx/Tx 0A_0x07	01
    0x8	Rx/Tx 0A_0x08	60
    0x9	Rx/Tx 0A_0x09	00
    0xA	Rx/Tx 0A_0x0A	10
    0xB	Rx/Tx 0A_0x0B	6F
    0xC	Rx/Tx 0A_0x0C	08
    0xD	Rx/Tx 0A_0x0D	B4
    0xE	Rx/Tx 0A_0x0E	93
    0xF	Rx/Tx 0A_0x0F	69
    0x10	Rx/Tx 0A_0x10	3A
    0x11	Rx/Tx 0A_0x11	20
    0x12	Rx/Tx 0A_0x12	E0
    0x13	Rx/Tx 0A_0x13	90
    0x14	Rx/Tx 0A_0x14	00
    0x15	Rx/Tx 0A_0x15	10
    0x16	Rx/Tx 0A_0x16	7A
    0x17	Rx/Tx 0A_0x17	36
    0x18	Rx/Tx 0A_0x18	40
    0x19	Rx/Tx 0A_0x19	25
    0x1A	Rx/Tx 0A_0x1A	A0
    0x1B	Rx/Tx 0A_0x1B	03
    0x1C	Rx/Tx 0A_0x1C	24
    0x1D	Rx/Tx 0A_0x1D	00
    0x1E	Rx/Tx 0A_0x1E	E9
    0x1F	Rx/Tx 0A_0x1F	55
    0x20	Rx/Tx 0A_0x20	00
    0x21	Rx/Tx 0A_0x21	00
    0x22	Rx/Tx 0A_0x22	00
    0x23	Rx/Tx 0A_0x23	40
    0x24	Rx/Tx 0A_0x24	40
    0x25	Rx/Tx 0A_0x25	10
    0x26	Rx/Tx 0A_0x26	02
    0x27	Rx/Tx 0A_0x27	00
    0x28	Rx/Tx 0A_0x28	00
    0x29	Rx/Tx 0A_0x29	00
    0x2A	Rx/Tx 0A_0x2A	30
    0x2B	Rx/Tx 0A_0x2B	00
    0x2C	Rx/Tx 0A_0x2C	F2
    0x2D	Rx/Tx 0A_0x2D	04
    0x2E	Rx/Tx 0A_0x2E	00
    0x2F	Rx/Tx 0A_0x2F	F6
    0x30	Rx/Tx 0A_0x30	00
    0x31	Rx/Tx 0A_0x31	20
    0x32	Rx/Tx 0A_0x32	11
    0x33	Rx/Tx 0A_0x33	88
    0x34	Rx/Tx 0A_0x34	3F
    0x35	Rx/Tx 0A_0x35	1F
    0x36	Rx/Tx 0A_0x36	30
    0x37	Rx/Tx 0A_0x37	00
    0x38	Rx/Tx 0A_0x38	00
    0x39	Rx/Tx 0A_0x39	00
    0x3A	Rx/Tx 0A_0x3A	A5
    0x3B	Rx/Tx 0A_0x3B	00
    0x3C	Rx/Tx 0A_0x3C	00
    0x3D	Rx/Tx 0A_0x3D	3F
    0x3E	Rx/Tx 0A_0x3E	40
    0x3F	Rx/Tx 0A_0x3F	C0
    0x40	Rx/Tx 0A_0x40	00
    0x41	Rx/Tx 0A_0x41	01
    0x42	Rx/Tx 0A_0x42	04
    0x43	Rx/Tx 0A_0x43	10
    0x44	Rx/Tx 0A_0x44	40
    0x45	Rx/Tx 0A_0x45	08
    0x46	Rx/Tx 0A_0x46	02
    0x47	Rx/Tx 0A_0x47	80
    0x48	Rx/Tx 0A_0x48	03
    0x49	Rx/Tx 0A_0x49	0C
    0x4A	Rx/Tx 0A_0x4A	30
    0x4B	Rx/Tx 0A_0x4B	41
    0x4C	Rx/Tx 0A_0x4C	50
    0x4D	Rx/Tx 0A_0x4D	C0
    0x4E	Rx/Tx 0A_0x4E	60
    0x4F	Rx/Tx 0A_0x4F	90
    0x50	Rx/Tx 0A_0x50	88
    0x51	Rx/Tx 0A_0x51	82
    0x52	Rx/Tx 0A_0x52	A0
    0x53	Rx/Tx 0A_0x53	46
    0x54	Rx/Tx 0A_0x54	52
    0x55	Rx/Tx 0A_0x55	8C
    0x56	Rx/Tx 0A_0x56	B0
    0x57	Rx/Tx 0A_0x57	C8
    0x58	Rx/Tx 0A_0x58	57
    0x59	Rx/Tx 0A_0x59	5D
    0x5A	Rx/Tx 0A_0x5A	69
    0x5B	Rx/Tx 0A_0x5B	75
    0x5C	Rx/Tx 0A_0x5C	D5
    0x5D	Rx/Tx 0A_0x5D	99
    0x5E	Rx/Tx 0A_0x5E	96
    0x5F	Rx/Tx 0A_0x5F	A5
    0x60	Rx/Tx 0A_0x60	B0
    0x61	Rx/Tx 0A_0x61	B2
    0x62	Rx/Tx 0A_0x62	20
    0x63	Rx/Tx 0A_0x63	B1
    0x64	Rx/Tx 0A_0x64	11
    0x65	Rx/Tx 0A_0x65	00
    0x66	Rx/Tx 0A_0x66	00
    0x67	Rx/Tx 0A_0x67	20
    0x68	Rx/Tx 0A_0x68	00
    0x69	Rx/Tx 0A_0x69	0A
    0x6A	Rx/Tx 0A_0x6A	22
    0x6B	Rx/Tx 0A_0x6B	40
    0x6C	Rx/Tx 0A_0x6C	00
    0x6D	Rx/Tx 0A_0x6D	00
    0x6E	Rx/Tx 0A_0x6E	00
    0x6F	Rx/Tx 0A_0x6F	00
    0x70	Rx/Tx 0A_0x70	03
    0x71	Rx/Tx 0A_0x71	20
    0x72	Rx/Tx 0A_0x72	00
    0x73	Rx/Tx 0A_0x73	00
    0x74	Rx/Tx 0A_0x74	00
    0x75	Rx/Tx 0A_0x75	00
    0x76	Rx/Tx 0A_0x76	22
    0x77	Rx/Tx 0A_0x77	1A
    0x78	Rx/Tx 0A_0x78	00
    0x79	Rx/Tx 0A_0x79	10
    0x7A	Rx/Tx 0A_0x7A	00
    0x7B	Rx/Tx 0A_0x7B	00
    0x7C	Rx/Tx 0A_0x7C	00
    0x7D	Rx/Tx 0A_0x7D	48
    0x7E	Rx/Tx 0A_0x7E	13
    0x7F	Rx/Tx 0A_0x7F	3A
    0x80	Rx/Tx 0A_0x80	00
    0x81	Rx/Tx 0A_0x81	E4
    0x82	Rx/Tx 0A_0x82	00
    0x83	Rx/Tx 0A_0x83	00
    0x84	Rx/Tx 0A_0x84	00
    0x85	Rx/Tx 0A_0x85	00
    0x86	Rx/Tx 0A_0x86	00
    0x87	Rx/Tx 0A_0x87	00
    0x88	Rx/Tx 0A_0x88	00
    0x89	Rx/Tx 0A_0x89	00
    0x8A	Rx/Tx 0A_0x8A	05
    0x8B	Rx/Tx 0A_0x8B	00
    0x8C	Rx/Tx 0A_0x8C	00
    0x8D	Rx/Tx 0A_0x8D	02
    0x8E	Rx/Tx 0A_0x8E	1C
    0x8F	Rx/Tx 0A_0x8F	00
    0x90	Rx/Tx 0A_0x90	00
    0x91	Rx/Tx 0A_0x91	00
    0x92	Rx/Tx 0A_0x92	00
    0x93	Rx/Tx 0A_0x93	00
    0x94	Rx/Tx 0A_0x94	00
    0x95	Rx/Tx 0A_0x95	00
    0x96	Rx/Tx 0A_0x96	04
    0x97	Rx/Tx 0A_0x97	00
    0x98	Rx/Tx 0A_0x98	3F
    0x99	Rx/Tx 0A_0x99	3F
    0x9A	Rx/Tx 0A_0x9A	3F
    0x9B	Rx/Tx 0A_0x9B	00
    0x0	Rx/Tx 0B_0x00	00
    0x1	Rx/Tx 0B_0x01	00
    0x2	Rx/Tx 0B_0x02	00
    0x3	Rx/Tx 0B_0x03	00
    0x4	Rx/Tx 0B_0x04	01
    0x5	Rx/Tx 0B_0x05	01
    0x6	Rx/Tx 0B_0x06	01
    0x7	Rx/Tx 0B_0x07	01
    0x8	Rx/Tx 0B_0x08	60
    0x9	Rx/Tx 0B_0x09	00
    0xA	Rx/Tx 0B_0x0A	10
    0xB	Rx/Tx 0B_0x0B	6F
    0xC	Rx/Tx 0B_0x0C	08
    0xD	Rx/Tx 0B_0x0D	B4
    0xE	Rx/Tx 0B_0x0E	93
    0xF	Rx/Tx 0B_0x0F	69
    0x10	Rx/Tx 0B_0x10	3A
    0x11	Rx/Tx 0B_0x11	20
    0x12	Rx/Tx 0B_0x12	E0
    0x13	Rx/Tx 0B_0x13	90
    0x14	Rx/Tx 0B_0x14	00
    0x15	Rx/Tx 0B_0x15	10
    0x16	Rx/Tx 0B_0x16	7A
    0x17	Rx/Tx 0B_0x17	36
    0x18	Rx/Tx 0B_0x18	40
    0x19	Rx/Tx 0B_0x19	25
    0x1A	Rx/Tx 0B_0x1A	A0
    0x1B	Rx/Tx 0B_0x1B	03
    0x1C	Rx/Tx 0B_0x1C	24
    0x1D	Rx/Tx 0B_0x1D	00
    0x1E	Rx/Tx 0B_0x1E	E9
    0x1F	Rx/Tx 0B_0x1F	55
    0x20	Rx/Tx 0B_0x20	00
    0x21	Rx/Tx 0B_0x21	00
    0x22	Rx/Tx 0B_0x22	00
    0x23	Rx/Tx 0B_0x23	40
    0x24	Rx/Tx 0B_0x24	40
    0x25	Rx/Tx 0B_0x25	01
    0x26	Rx/Tx 0B_0x26	00
    0x27	Rx/Tx 0B_0x27	00
    0x28	Rx/Tx 0B_0x28	00
    0x29	Rx/Tx 0B_0x29	00
    0x2A	Rx/Tx 0B_0x2A	30
    0x2B	Rx/Tx 0B_0x2B	00
    0x2C	Rx/Tx 0B_0x2C	F2
    0x2D	Rx/Tx 0B_0x2D	04
    0x2E	Rx/Tx 0B_0x2E	00
    0x2F	Rx/Tx 0B_0x2F	F6
    0x30	Rx/Tx 0B_0x30	00
    0x31	Rx/Tx 0B_0x31	20
    0x32	Rx/Tx 0B_0x32	11
    0x33	Rx/Tx 0B_0x33	88
    0x34	Rx/Tx 0B_0x34	3F
    0x35	Rx/Tx 0B_0x35	1F
    0x36	Rx/Tx 0B_0x36	30
    0x37	Rx/Tx 0B_0x37	00
    0x38	Rx/Tx 0B_0x38	00
    0x39	Rx/Tx 0B_0x39	00
    0x3A	Rx/Tx 0B_0x3A	A5
    0x3B	Rx/Tx 0B_0x3B	00
    0x3C	Rx/Tx 0B_0x3C	00
    0x3D	Rx/Tx 0B_0x3D	3F
    0x3E	Rx/Tx 0B_0x3E	40
    0x3F	Rx/Tx 0B_0x3F	C0
    0x40	Rx/Tx 0B_0x40	00
    0x41	Rx/Tx 0B_0x41	01
    0x42	Rx/Tx 0B_0x42	04
    0x43	Rx/Tx 0B_0x43	10
    0x44	Rx/Tx 0B_0x44	40
    0x45	Rx/Tx 0B_0x45	08
    0x46	Rx/Tx 0B_0x46	02
    0x47	Rx/Tx 0B_0x47	80
    0x48	Rx/Tx 0B_0x48	03
    0x49	Rx/Tx 0B_0x49	0C
    0x4A	Rx/Tx 0B_0x4A	30
    0x4B	Rx/Tx 0B_0x4B	41
    0x4C	Rx/Tx 0B_0x4C	50
    0x4D	Rx/Tx 0B_0x4D	C0
    0x4E	Rx/Tx 0B_0x4E	60
    0x4F	Rx/Tx 0B_0x4F	90
    0x50	Rx/Tx 0B_0x50	88
    0x51	Rx/Tx 0B_0x51	82
    0x52	Rx/Tx 0B_0x52	A0
    0x53	Rx/Tx 0B_0x53	46
    0x54	Rx/Tx 0B_0x54	52
    0x55	Rx/Tx 0B_0x55	8C
    0x56	Rx/Tx 0B_0x56	B0
    0x57	Rx/Tx 0B_0x57	C8
    0x58	Rx/Tx 0B_0x58	57
    0x59	Rx/Tx 0B_0x59	5D
    0x5A	Rx/Tx 0B_0x5A	69
    0x5B	Rx/Tx 0B_0x5B	75
    0x5C	Rx/Tx 0B_0x5C	D5
    0x5D	Rx/Tx 0B_0x5D	99
    0x5E	Rx/Tx 0B_0x5E	96
    0x5F	Rx/Tx 0B_0x5F	A5
    0x60	Rx/Tx 0B_0x60	B0
    0x61	Rx/Tx 0B_0x61	B2
    0x62	Rx/Tx 0B_0x62	20
    0x63	Rx/Tx 0B_0x63	B1
    0x64	Rx/Tx 0B_0x64	11
    0x65	Rx/Tx 0B_0x65	00
    0x66	Rx/Tx 0B_0x66	00
    0x67	Rx/Tx 0B_0x67	20
    0x68	Rx/Tx 0B_0x68	00
    0x69	Rx/Tx 0B_0x69	0A
    0x6A	Rx/Tx 0B_0x6A	22
    0x6B	Rx/Tx 0B_0x6B	40
    0x6C	Rx/Tx 0B_0x6C	00
    0x6D	Rx/Tx 0B_0x6D	00
    0x6E	Rx/Tx 0B_0x6E	00
    0x6F	Rx/Tx 0B_0x6F	00
    0x70	Rx/Tx 0B_0x70	03
    0x71	Rx/Tx 0B_0x71	20
    0x72	Rx/Tx 0B_0x72	00
    0x73	Rx/Tx 0B_0x73	00
    0x74	Rx/Tx 0B_0x74	00
    0x75	Rx/Tx 0B_0x75	00
    0x76	Rx/Tx 0B_0x76	22
    0x77	Rx/Tx 0B_0x77	1A
    0x78	Rx/Tx 0B_0x78	00
    0x79	Rx/Tx 0B_0x79	10
    0x7A	Rx/Tx 0B_0x7A	00
    0x7B	Rx/Tx 0B_0x7B	00
    0x7C	Rx/Tx 0B_0x7C	00
    0x7D	Rx/Tx 0B_0x7D	48
    0x7E	Rx/Tx 0B_0x7E	13
    0x7F	Rx/Tx 0B_0x7F	3A
    0x80	Rx/Tx 0B_0x80	00
    0x81	Rx/Tx 0B_0x81	E4
    0x82	Rx/Tx 0B_0x82	00
    0x83	Rx/Tx 0B_0x83	00
    0x84	Rx/Tx 0B_0x84	00
    0x85	Rx/Tx 0B_0x85	00
    0x86	Rx/Tx 0B_0x86	00
    0x87	Rx/Tx 0B_0x87	00
    0x88	Rx/Tx 0B_0x88	00
    0x89	Rx/Tx 0B_0x89	00
    0x8A	Rx/Tx 0B_0x8A	6E
    0x8B	Rx/Tx 0B_0x8B	00
    0x8C	Rx/Tx 0B_0x8C	00
    0x8D	Rx/Tx 0B_0x8D	02
    0x8E	Rx/Tx 0B_0x8E	1C
    0x8F	Rx/Tx 0B_0x8F	00
    0x90	Rx/Tx 0B_0x90	00
    0x91	Rx/Tx 0B_0x91	00
    0x92	Rx/Tx 0B_0x92	00
    0x93	Rx/Tx 0B_0x93	00
    0x94	Rx/Tx 0B_0x94	00
    0x95	Rx/Tx 0B_0x95	00
    0x96	Rx/Tx 0B_0x96	04
    0x97	Rx/Tx 0B_0x97	00
    0x98	Rx/Tx 0B_0x98	3F
    0x99	Rx/Tx 0B_0x99	3F
    0x9A	Rx/Tx 0B_0x9A	3F
    0x9B	Rx/Tx 0B_0x9B	00
    0x0	Rx/Tx 1A_0x00	00
    0x1	Rx/Tx 1A_0x01	00
    0x2	Rx/Tx 1A_0x02	00
    0x3	Rx/Tx 1A_0x03	00
    0x4	Rx/Tx 1A_0x04	01
    0x5	Rx/Tx 1A_0x05	01
    0x6	Rx/Tx 1A_0x06	01
    0x7	Rx/Tx 1A_0x07	01
    0x8	Rx/Tx 1A_0x08	60
    0x9	Rx/Tx 1A_0x09	00
    0xA	Rx/Tx 1A_0x0A	10
    0xB	Rx/Tx 1A_0x0B	6F
    0xC	Rx/Tx 1A_0x0C	08
    0xD	Rx/Tx 1A_0x0D	B4
    0xE	Rx/Tx 1A_0x0E	93
    0xF	Rx/Tx 1A_0x0F	69
    0x10	Rx/Tx 1A_0x10	3A
    0x11	Rx/Tx 1A_0x11	20
    0x12	Rx/Tx 1A_0x12	E0
    0x13	Rx/Tx 1A_0x13	90
    0x14	Rx/Tx 1A_0x14	00
    0x15	Rx/Tx 1A_0x15	10
    0x16	Rx/Tx 1A_0x16	7A
    0x17	Rx/Tx 1A_0x17	36
    0x18	Rx/Tx 1A_0x18	40
    0x19	Rx/Tx 1A_0x19	25
    0x1A	Rx/Tx 1A_0x1A	A0
    0x1B	Rx/Tx 1A_0x1B	03
    0x1C	Rx/Tx 1A_0x1C	24
    0x1D	Rx/Tx 1A_0x1D	00
    0x1E	Rx/Tx 1A_0x1E	E9
    0x1F	Rx/Tx 1A_0x1F	55
    0x20	Rx/Tx 1A_0x20	00
    0x21	Rx/Tx 1A_0x21	00
    0x22	Rx/Tx 1A_0x22	00
    0x23	Rx/Tx 1A_0x23	40
    0x24	Rx/Tx 1A_0x24	40
    0x25	Rx/Tx 1A_0x25	20
    0x26	Rx/Tx 1A_0x26	00
    0x27	Rx/Tx 1A_0x27	00
    0x28	Rx/Tx 1A_0x28	00
    0x29	Rx/Tx 1A_0x29	00
    0x2A	Rx/Tx 1A_0x2A	30
    0x2B	Rx/Tx 1A_0x2B	00
    0x2C	Rx/Tx 1A_0x2C	F2
    0x2D	Rx/Tx 1A_0x2D	04
    0x2E	Rx/Tx 1A_0x2E	00
    0x2F	Rx/Tx 1A_0x2F	F6
    0x30	Rx/Tx 1A_0x30	00
    0x31	Rx/Tx 1A_0x31	20
    0x32	Rx/Tx 1A_0x32	11
    0x33	Rx/Tx 1A_0x33	88
    0x34	Rx/Tx 1A_0x34	3F
    0x35	Rx/Tx 1A_0x35	1F
    0x36	Rx/Tx 1A_0x36	30
    0x37	Rx/Tx 1A_0x37	00
    0x38	Rx/Tx 1A_0x38	00
    0x39	Rx/Tx 1A_0x39	00
    0x3A	Rx/Tx 1A_0x3A	A5
    0x3B	Rx/Tx 1A_0x3B	00
    0x3C	Rx/Tx 1A_0x3C	00
    0x3D	Rx/Tx 1A_0x3D	3F
    0x3E	Rx/Tx 1A_0x3E	40
    0x3F	Rx/Tx 1A_0x3F	C0
    0x40	Rx/Tx 1A_0x40	00
    0x41	Rx/Tx 1A_0x41	01
    0x42	Rx/Tx 1A_0x42	04
    0x43	Rx/Tx 1A_0x43	10
    0x44	Rx/Tx 1A_0x44	40
    0x45	Rx/Tx 1A_0x45	08
    0x46	Rx/Tx 1A_0x46	02
    0x47	Rx/Tx 1A_0x47	80
    0x48	Rx/Tx 1A_0x48	03
    0x49	Rx/Tx 1A_0x49	0C
    0x4A	Rx/Tx 1A_0x4A	30
    0x4B	Rx/Tx 1A_0x4B	41
    0x4C	Rx/Tx 1A_0x4C	50
    0x4D	Rx/Tx 1A_0x4D	C0
    0x4E	Rx/Tx 1A_0x4E	60
    0x4F	Rx/Tx 1A_0x4F	90
    0x50	Rx/Tx 1A_0x50	88
    0x51	Rx/Tx 1A_0x51	82
    0x52	Rx/Tx 1A_0x52	A0
    0x53	Rx/Tx 1A_0x53	46
    0x54	Rx/Tx 1A_0x54	52
    0x55	Rx/Tx 1A_0x55	8C
    0x56	Rx/Tx 1A_0x56	B0
    0x57	Rx/Tx 1A_0x57	C8
    0x58	Rx/Tx 1A_0x58	57
    0x59	Rx/Tx 1A_0x59	5D
    0x5A	Rx/Tx 1A_0x5A	69
    0x5B	Rx/Tx 1A_0x5B	75
    0x5C	Rx/Tx 1A_0x5C	D5
    0x5D	Rx/Tx 1A_0x5D	99
    0x5E	Rx/Tx 1A_0x5E	96
    0x5F	Rx/Tx 1A_0x5F	A5
    0x60	Rx/Tx 1A_0x60	B0
    0x61	Rx/Tx 1A_0x61	B2
    0x62	Rx/Tx 1A_0x62	20
    0x63	Rx/Tx 1A_0x63	B1
    0x64	Rx/Tx 1A_0x64	11
    0x65	Rx/Tx 1A_0x65	00
    0x66	Rx/Tx 1A_0x66	00
    0x67	Rx/Tx 1A_0x67	20
    0x68	Rx/Tx 1A_0x68	00
    0x69	Rx/Tx 1A_0x69	0A
    0x6A	Rx/Tx 1A_0x6A	22
    0x6B	Rx/Tx 1A_0x6B	40
    0x6C	Rx/Tx 1A_0x6C	00
    0x6D	Rx/Tx 1A_0x6D	00
    0x6E	Rx/Tx 1A_0x6E	00
    0x6F	Rx/Tx 1A_0x6F	00
    0x70	Rx/Tx 1A_0x70	03
    0x71	Rx/Tx 1A_0x71	20
    0x72	Rx/Tx 1A_0x72	00
    0x73	Rx/Tx 1A_0x73	00
    0x74	Rx/Tx 1A_0x74	00
    0x75	Rx/Tx 1A_0x75	00
    0x76	Rx/Tx 1A_0x76	22
    0x77	Rx/Tx 1A_0x77	1A
    0x78	Rx/Tx 1A_0x78	00
    0x79	Rx/Tx 1A_0x79	10
    0x7A	Rx/Tx 1A_0x7A	00
    0x7B	Rx/Tx 1A_0x7B	00
    0x7C	Rx/Tx 1A_0x7C	00
    0x7D	Rx/Tx 1A_0x7D	48
    0x7E	Rx/Tx 1A_0x7E	13
    0x7F	Rx/Tx 1A_0x7F	3A
    0x80	Rx/Tx 1A_0x80	00
    0x81	Rx/Tx 1A_0x81	E4
    0x82	Rx/Tx 1A_0x82	00
    0x83	Rx/Tx 1A_0x83	00
    0x84	Rx/Tx 1A_0x84	03
    0x85	Rx/Tx 1A_0x85	00
    0x86	Rx/Tx 1A_0x86	00
    0x87	Rx/Tx 1A_0x87	00
    0x88	Rx/Tx 1A_0x88	00
    0x89	Rx/Tx 1A_0x89	00
    0x8A	Rx/Tx 1A_0x8A	19
    0x8B	Rx/Tx 1A_0x8B	00
    0x8C	Rx/Tx 1A_0x8C	00
    0x8D	Rx/Tx 1A_0x8D	02
    0x8E	Rx/Tx 1A_0x8E	1C
    0x8F	Rx/Tx 1A_0x8F	00
    0x90	Rx/Tx 1A_0x90	00
    0x91	Rx/Tx 1A_0x91	00
    0x92	Rx/Tx 1A_0x92	00
    0x93	Rx/Tx 1A_0x93	00
    0x94	Rx/Tx 1A_0x94	00
    0x95	Rx/Tx 1A_0x95	00
    0x96	Rx/Tx 1A_0x96	04
    0x97	Rx/Tx 1A_0x97	00
    0x98	Rx/Tx 1A_0x98	3F
    0x99	Rx/Tx 1A_0x99	3F
    0x9A	Rx/Tx 1A_0x9A	3F
    0x9B	Rx/Tx 1A_0x9B	00
    0x0	Rx/Tx 1B_0x00	00
    0x1	Rx/Tx 1B_0x01	00
    0x2	Rx/Tx 1B_0x02	00
    0x3	Rx/Tx 1B_0x03	00
    0x4	Rx/Tx 1B_0x04	01
    0x5	Rx/Tx 1B_0x05	01
    0x6	Rx/Tx 1B_0x06	01
    0x7	Rx/Tx 1B_0x07	01
    0x8	Rx/Tx 1B_0x08	60
    0x9	Rx/Tx 1B_0x09	00
    0xA	Rx/Tx 1B_0x0A	10
    0xB	Rx/Tx 1B_0x0B	6F
    0xC	Rx/Tx 1B_0x0C	08
    0xD	Rx/Tx 1B_0x0D	B4
    0xE	Rx/Tx 1B_0x0E	93
    0xF	Rx/Tx 1B_0x0F	69
    0x10	Rx/Tx 1B_0x10	3A
    0x11	Rx/Tx 1B_0x11	20
    0x12	Rx/Tx 1B_0x12	E0
    0x13	Rx/Tx 1B_0x13	90
    0x14	Rx/Tx 1B_0x14	00
    0x15	Rx/Tx 1B_0x15	10
    0x16	Rx/Tx 1B_0x16	7A
    0x17	Rx/Tx 1B_0x17	36
    0x18	Rx/Tx 1B_0x18	40
    0x19	Rx/Tx 1B_0x19	25
    0x1A	Rx/Tx 1B_0x1A	A0
    0x1B	Rx/Tx 1B_0x1B	03
    0x1C	Rx/Tx 1B_0x1C	24
    0x1D	Rx/Tx 1B_0x1D	00
    0x1E	Rx/Tx 1B_0x1E	E9
    0x1F	Rx/Tx 1B_0x1F	55
    0x20	Rx/Tx 1B_0x20	00
    0x21	Rx/Tx 1B_0x21	00
    0x22	Rx/Tx 1B_0x22	00
    0x23	Rx/Tx 1B_0x23	40
    0x24	Rx/Tx 1B_0x24	40
    0x25	Rx/Tx 1B_0x25	00
    0x26	Rx/Tx 1B_0x26	00
    0x27	Rx/Tx 1B_0x27	00
    0x28	Rx/Tx 1B_0x28	00
    0x29	Rx/Tx 1B_0x29	00
    0x2A	Rx/Tx 1B_0x2A	30
    0x2B	Rx/Tx 1B_0x2B	00
    0x2C	Rx/Tx 1B_0x2C	F2
    0x2D	Rx/Tx 1B_0x2D	04
    0x2E	Rx/Tx 1B_0x2E	00
    0x2F	Rx/Tx 1B_0x2F	F6
    0x30	Rx/Tx 1B_0x30	00
    0x31	Rx/Tx 1B_0x31	20
    0x32	Rx/Tx 1B_0x32	11
    0x33	Rx/Tx 1B_0x33	88
    0x34	Rx/Tx 1B_0x34	3F
    0x35	Rx/Tx 1B_0x35	1F
    0x36	Rx/Tx 1B_0x36	30
    0x37	Rx/Tx 1B_0x37	00
    0x38	Rx/Tx 1B_0x38	00
    0x39	Rx/Tx 1B_0x39	00
    0x3A	Rx/Tx 1B_0x3A	A5
    0x3B	Rx/Tx 1B_0x3B	00
    0x3C	Rx/Tx 1B_0x3C	00
    0x3D	Rx/Tx 1B_0x3D	3F
    0x3E	Rx/Tx 1B_0x3E	40
    0x3F	Rx/Tx 1B_0x3F	C0
    0x40	Rx/Tx 1B_0x40	00
    0x41	Rx/Tx 1B_0x41	01
    0x42	Rx/Tx 1B_0x42	04
    0x43	Rx/Tx 1B_0x43	10
    0x44	Rx/Tx 1B_0x44	40
    0x45	Rx/Tx 1B_0x45	08
    0x46	Rx/Tx 1B_0x46	02
    0x47	Rx/Tx 1B_0x47	80
    0x48	Rx/Tx 1B_0x48	03
    0x49	Rx/Tx 1B_0x49	0C
    0x4A	Rx/Tx 1B_0x4A	30
    0x4B	Rx/Tx 1B_0x4B	41
    0x4C	Rx/Tx 1B_0x4C	50
    0x4D	Rx/Tx 1B_0x4D	C0
    0x4E	Rx/Tx 1B_0x4E	60
    0x4F	Rx/Tx 1B_0x4F	90
    0x50	Rx/Tx 1B_0x50	88
    0x51	Rx/Tx 1B_0x51	82
    0x52	Rx/Tx 1B_0x52	A0
    0x53	Rx/Tx 1B_0x53	46
    0x54	Rx/Tx 1B_0x54	52
    0x55	Rx/Tx 1B_0x55	8C
    0x56	Rx/Tx 1B_0x56	B0
    0x57	Rx/Tx 1B_0x57	C8
    0x58	Rx/Tx 1B_0x58	57
    0x59	Rx/Tx 1B_0x59	5D
    0x5A	Rx/Tx 1B_0x5A	69
    0x5B	Rx/Tx 1B_0x5B	75
    0x5C	Rx/Tx 1B_0x5C	D5
    0x5D	Rx/Tx 1B_0x5D	99
    0x5E	Rx/Tx 1B_0x5E	96
    0x5F	Rx/Tx 1B_0x5F	A5
    0x60	Rx/Tx 1B_0x60	B0
    0x61	Rx/Tx 1B_0x61	B2
    0x62	Rx/Tx 1B_0x62	20
    0x63	Rx/Tx 1B_0x63	B1
    0x64	Rx/Tx 1B_0x64	11
    0x65	Rx/Tx 1B_0x65	00
    0x66	Rx/Tx 1B_0x66	00
    0x67	Rx/Tx 1B_0x67	20
    0x68	Rx/Tx 1B_0x68	00
    0x69	Rx/Tx 1B_0x69	0A
    0x6A	Rx/Tx 1B_0x6A	22
    0x6B	Rx/Tx 1B_0x6B	40
    0x6C	Rx/Tx 1B_0x6C	00
    0x6D	Rx/Tx 1B_0x6D	00
    0x6E	Rx/Tx 1B_0x6E	00
    0x6F	Rx/Tx 1B_0x6F	00
    0x70	Rx/Tx 1B_0x70	03
    0x71	Rx/Tx 1B_0x71	20
    0x72	Rx/Tx 1B_0x72	00
    0x73	Rx/Tx 1B_0x73	00
    0x74	Rx/Tx 1B_0x74	00
    0x75	Rx/Tx 1B_0x75	00
    0x76	Rx/Tx 1B_0x76	22
    0x77	Rx/Tx 1B_0x77	1A
    0x78	Rx/Tx 1B_0x78	00
    0x79	Rx/Tx 1B_0x79	10
    0x7A	Rx/Tx 1B_0x7A	00
    0x7B	Rx/Tx 1B_0x7B	00
    0x7C	Rx/Tx 1B_0x7C	00
    0x7D	Rx/Tx 1B_0x7D	48
    0x7E	Rx/Tx 1B_0x7E	13
    0x7F	Rx/Tx 1B_0x7F	3A
    0x80	Rx/Tx 1B_0x80	00
    0x81	Rx/Tx 1B_0x81	E4
    0x82	Rx/Tx 1B_0x82	00
    0x83	Rx/Tx 1B_0x83	00
    0x84	Rx/Tx 1B_0x84	00
    0x85	Rx/Tx 1B_0x85	00
    0x86	Rx/Tx 1B_0x86	00
    0x87	Rx/Tx 1B_0x87	00
    0x88	Rx/Tx 1B_0x88	00
    0x89	Rx/Tx 1B_0x89	00
    0x8A	Rx/Tx 1B_0x8A	07
    0x8B	Rx/Tx 1B_0x8B	00
    0x8C	Rx/Tx 1B_0x8C	00
    0x8D	Rx/Tx 1B_0x8D	02
    0x8E	Rx/Tx 1B_0x8E	1C
    0x8F	Rx/Tx 1B_0x8F	00
    0x90	Rx/Tx 1B_0x90	00
    0x91	Rx/Tx 1B_0x91	00
    0x92	Rx/Tx 1B_0x92	00
    0x93	Rx/Tx 1B_0x93	00
    0x94	Rx/Tx 1B_0x94	00
    0x95	Rx/Tx 1B_0x95	00
    0x96	Rx/Tx 1B_0x96	04
    0x97	Rx/Tx 1B_0x97	00
    0x98	Rx/Tx 1B_0x98	3F
    0x99	Rx/Tx 1B_0x99	3F
    0x9A	Rx/Tx 1B_0x9A	3F
    0x9B	Rx/Tx 1B_0x9B	00
    0x0	Rx/Tx 2A_0x00	00
    0x1	Rx/Tx 2A_0x01	00
    0x2	Rx/Tx 2A_0x02	00
    0x3	Rx/Tx 2A_0x03	00
    0x4	Rx/Tx 2A_0x04	01
    0x5	Rx/Tx 2A_0x05	01
    0x6	Rx/Tx 2A_0x06	01
    0x7	Rx/Tx 2A_0x07	01
    0x8	Rx/Tx 2A_0x08	60
    0x9	Rx/Tx 2A_0x09	00
    0xA	Rx/Tx 2A_0x0A	10
    0xB	Rx/Tx 2A_0x0B	6F
    0xC	Rx/Tx 2A_0x0C	08
    0xD	Rx/Tx 2A_0x0D	B4
    0xE	Rx/Tx 2A_0x0E	93
    0xF	Rx/Tx 2A_0x0F	69
    0x10	Rx/Tx 2A_0x10	3A
    0x11	Rx/Tx 2A_0x11	20
    0x12	Rx/Tx 2A_0x12	E0
    0x13	Rx/Tx 2A_0x13	90
    0x14	Rx/Tx 2A_0x14	00
    0x15	Rx/Tx 2A_0x15	10
    0x16	Rx/Tx 2A_0x16	7A
    0x17	Rx/Tx 2A_0x17	36
    0x18	Rx/Tx 2A_0x18	40
    0x19	Rx/Tx 2A_0x19	25
    0x1A	Rx/Tx 2A_0x1A	A0
    0x1B	Rx/Tx 2A_0x1B	03
    0x1C	Rx/Tx 2A_0x1C	24
    0x1D	Rx/Tx 2A_0x1D	00
    0x1E	Rx/Tx 2A_0x1E	E9
    0x1F	Rx/Tx 2A_0x1F	55
    0x20	Rx/Tx 2A_0x20	00
    0x21	Rx/Tx 2A_0x21	00
    0x22	Rx/Tx 2A_0x22	00
    0x23	Rx/Tx 2A_0x23	40
    0x24	Rx/Tx 2A_0x24	40
    0x25	Rx/Tx 2A_0x25	36
    0x26	Rx/Tx 2A_0x26	0A
    0x27	Rx/Tx 2A_0x27	00
    0x28	Rx/Tx 2A_0x28	00
    0x29	Rx/Tx 2A_0x29	00
    0x2A	Rx/Tx 2A_0x2A	30
    0x2B	Rx/Tx 2A_0x2B	00
    0x2C	Rx/Tx 2A_0x2C	F2
    0x2D	Rx/Tx 2A_0x2D	04
    0x2E	Rx/Tx 2A_0x2E	00
    0x2F	Rx/Tx 2A_0x2F	F6
    0x30	Rx/Tx 2A_0x30	00
    0x31	Rx/Tx 2A_0x31	20
    0x32	Rx/Tx 2A_0x32	11
    0x33	Rx/Tx 2A_0x33	88
    0x34	Rx/Tx 2A_0x34	3F
    0x35	Rx/Tx 2A_0x35	1F
    0x36	Rx/Tx 2A_0x36	30
    0x37	Rx/Tx 2A_0x37	00
    0x38	Rx/Tx 2A_0x38	00
    0x39	Rx/Tx 2A_0x39	00
    0x3A	Rx/Tx 2A_0x3A	A5
    0x3B	Rx/Tx 2A_0x3B	00
    0x3C	Rx/Tx 2A_0x3C	00
    0x3D	Rx/Tx 2A_0x3D	3F
    0x3E	Rx/Tx 2A_0x3E	40
    0x3F	Rx/Tx 2A_0x3F	C0
    0x40	Rx/Tx 2A_0x40	00
    0x41	Rx/Tx 2A_0x41	01
    0x42	Rx/Tx 2A_0x42	04
    0x43	Rx/Tx 2A_0x43	10
    0x44	Rx/Tx 2A_0x44	40
    0x45	Rx/Tx 2A_0x45	08
    0x46	Rx/Tx 2A_0x46	02
    0x47	Rx/Tx 2A_0x47	80
    0x48	Rx/Tx 2A_0x48	03
    0x49	Rx/Tx 2A_0x49	0C
    0x4A	Rx/Tx 2A_0x4A	30
    0x4B	Rx/Tx 2A_0x4B	41
    0x4C	Rx/Tx 2A_0x4C	50
    0x4D	Rx/Tx 2A_0x4D	C0
    0x4E	Rx/Tx 2A_0x4E	60
    0x4F	Rx/Tx 2A_0x4F	90
    0x50	Rx/Tx 2A_0x50	88
    0x51	Rx/Tx 2A_0x51	82
    0x52	Rx/Tx 2A_0x52	A0
    0x53	Rx/Tx 2A_0x53	46
    0x54	Rx/Tx 2A_0x54	52
    0x55	Rx/Tx 2A_0x55	8C
    0x56	Rx/Tx 2A_0x56	B0
    0x57	Rx/Tx 2A_0x57	C8
    0x58	Rx/Tx 2A_0x58	57
    0x59	Rx/Tx 2A_0x59	5D
    0x5A	Rx/Tx 2A_0x5A	69
    0x5B	Rx/Tx 2A_0x5B	75
    0x5C	Rx/Tx 2A_0x5C	D5
    0x5D	Rx/Tx 2A_0x5D	99
    0x5E	Rx/Tx 2A_0x5E	96
    0x5F	Rx/Tx 2A_0x5F	A5
    0x60	Rx/Tx 2A_0x60	B0
    0x61	Rx/Tx 2A_0x61	B2
    0x62	Rx/Tx 2A_0x62	20
    0x63	Rx/Tx 2A_0x63	B1
    0x64	Rx/Tx 2A_0x64	11
    0x65	Rx/Tx 2A_0x65	00
    0x66	Rx/Tx 2A_0x66	00
    0x67	Rx/Tx 2A_0x67	20
    0x68	Rx/Tx 2A_0x68	00
    0x69	Rx/Tx 2A_0x69	0A
    0x6A	Rx/Tx 2A_0x6A	22
    0x6B	Rx/Tx 2A_0x6B	40
    0x6C	Rx/Tx 2A_0x6C	00
    0x6D	Rx/Tx 2A_0x6D	00
    0x6E	Rx/Tx 2A_0x6E	00
    0x6F	Rx/Tx 2A_0x6F	00
    0x70	Rx/Tx 2A_0x70	03
    0x71	Rx/Tx 2A_0x71	20
    0x72	Rx/Tx 2A_0x72	00
    0x73	Rx/Tx 2A_0x73	00
    0x74	Rx/Tx 2A_0x74	00
    0x75	Rx/Tx 2A_0x75	00
    0x76	Rx/Tx 2A_0x76	22
    0x77	Rx/Tx 2A_0x77	1A
    0x78	Rx/Tx 2A_0x78	00
    0x79	Rx/Tx 2A_0x79	10
    0x7A	Rx/Tx 2A_0x7A	00
    0x7B	Rx/Tx 2A_0x7B	00
    0x7C	Rx/Tx 2A_0x7C	00
    0x7D	Rx/Tx 2A_0x7D	48
    0x7E	Rx/Tx 2A_0x7E	13
    0x7F	Rx/Tx 2A_0x7F	3A
    0x80	Rx/Tx 2A_0x80	00
    0x81	Rx/Tx 2A_0x81	E4
    0x82	Rx/Tx 2A_0x82	00
    0x83	Rx/Tx 2A_0x83	00
    0x84	Rx/Tx 2A_0x84	00
    0x85	Rx/Tx 2A_0x85	00
    0x86	Rx/Tx 2A_0x86	00
    0x87	Rx/Tx 2A_0x87	00
    0x88	Rx/Tx 2A_0x88	00
    0x89	Rx/Tx 2A_0x89	00
    0x8A	Rx/Tx 2A_0x8A	1C
    0x8B	Rx/Tx 2A_0x8B	00
    0x8C	Rx/Tx 2A_0x8C	00
    0x8D	Rx/Tx 2A_0x8D	02
    0x8E	Rx/Tx 2A_0x8E	1C
    0x8F	Rx/Tx 2A_0x8F	00
    0x90	Rx/Tx 2A_0x90	00
    0x91	Rx/Tx 2A_0x91	00
    0x92	Rx/Tx 2A_0x92	00
    0x93	Rx/Tx 2A_0x93	00
    0x94	Rx/Tx 2A_0x94	00
    0x95	Rx/Tx 2A_0x95	00
    0x96	Rx/Tx 2A_0x96	04
    0x97	Rx/Tx 2A_0x97	00
    0x98	Rx/Tx 2A_0x98	3F
    0x99	Rx/Tx 2A_0x99	3F
    0x9A	Rx/Tx 2A_0x9A	3F
    0x9B	Rx/Tx 2A_0x9B	00
    0x0	Rx/Tx 2B_0x00	00
    0x1	Rx/Tx 2B_0x01	00
    0x2	Rx/Tx 2B_0x02	00
    0x3	Rx/Tx 2B_0x03	00
    0x4	Rx/Tx 2B_0x04	01
    0x5	Rx/Tx 2B_0x05	01
    0x6	Rx/Tx 2B_0x06	01
    0x7	Rx/Tx 2B_0x07	01
    0x8	Rx/Tx 2B_0x08	60
    0x9	Rx/Tx 2B_0x09	00
    0xA	Rx/Tx 2B_0x0A	10
    0xB	Rx/Tx 2B_0x0B	6F
    0xC	Rx/Tx 2B_0x0C	08
    0xD	Rx/Tx 2B_0x0D	B4
    0xE	Rx/Tx 2B_0x0E	93
    0xF	Rx/Tx 2B_0x0F	69
    0x10	Rx/Tx 2B_0x10	3A
    0x11	Rx/Tx 2B_0x11	20
    0x12	Rx/Tx 2B_0x12	E0
    0x13	Rx/Tx 2B_0x13	90
    0x14	Rx/Tx 2B_0x14	00
    0x15	Rx/Tx 2B_0x15	10
    0x16	Rx/Tx 2B_0x16	7A
    0x17	Rx/Tx 2B_0x17	36
    0x18	Rx/Tx 2B_0x18	40
    0x19	Rx/Tx 2B_0x19	25
    0x1A	Rx/Tx 2B_0x1A	A0
    0x1B	Rx/Tx 2B_0x1B	03
    0x1C	Rx/Tx 2B_0x1C	24
    0x1D	Rx/Tx 2B_0x1D	00
    0x1E	Rx/Tx 2B_0x1E	E9
    0x1F	Rx/Tx 2B_0x1F	55
    0x20	Rx/Tx 2B_0x20	00
    0x21	Rx/Tx 2B_0x21	00
    0x22	Rx/Tx 2B_0x22	00
    0x23	Rx/Tx 2B_0x23	40
    0x24	Rx/Tx 2B_0x24	40
    0x25	Rx/Tx 2B_0x25	34
    0x26	Rx/Tx 2B_0x26	0A
    0x27	Rx/Tx 2B_0x27	00
    0x28	Rx/Tx 2B_0x28	00
    0x29	Rx/Tx 2B_0x29	00
    0x2A	Rx/Tx 2B_0x2A	30
    0x2B	Rx/Tx 2B_0x2B	00
    0x2C	Rx/Tx 2B_0x2C	F2
    0x2D	Rx/Tx 2B_0x2D	04
    0x2E	Rx/Tx 2B_0x2E	00
    0x2F	Rx/Tx 2B_0x2F	F6
    0x30	Rx/Tx 2B_0x30	00
    0x31	Rx/Tx 2B_0x31	20
    0x32	Rx/Tx 2B_0x32	11
    0x33	Rx/Tx 2B_0x33	88
    0x34	Rx/Tx 2B_0x34	3F
    0x35	Rx/Tx 2B_0x35	1F
    0x36	Rx/Tx 2B_0x36	30
    0x37	Rx/Tx 2B_0x37	00
    0x38	Rx/Tx 2B_0x38	00
    0x39	Rx/Tx 2B_0x39	00
    0x3A	Rx/Tx 2B_0x3A	A5
    0x3B	Rx/Tx 2B_0x3B	00
    0x3C	Rx/Tx 2B_0x3C	00
    0x3D	Rx/Tx 2B_0x3D	3F
    0x3E	Rx/Tx 2B_0x3E	40
    0x3F	Rx/Tx 2B_0x3F	C0
    0x40	Rx/Tx 2B_0x40	00
    0x41	Rx/Tx 2B_0x41	01
    0x42	Rx/Tx 2B_0x42	04
    0x43	Rx/Tx 2B_0x43	10
    0x44	Rx/Tx 2B_0x44	40
    0x45	Rx/Tx 2B_0x45	08
    0x46	Rx/Tx 2B_0x46	02
    0x47	Rx/Tx 2B_0x47	80
    0x48	Rx/Tx 2B_0x48	03
    0x49	Rx/Tx 2B_0x49	0C
    0x4A	Rx/Tx 2B_0x4A	30
    0x4B	Rx/Tx 2B_0x4B	41
    0x4C	Rx/Tx 2B_0x4C	50
    0x4D	Rx/Tx 2B_0x4D	C0
    0x4E	Rx/Tx 2B_0x4E	60
    0x4F	Rx/Tx 2B_0x4F	90
    0x50	Rx/Tx 2B_0x50	88
    0x51	Rx/Tx 2B_0x51	82
    0x52	Rx/Tx 2B_0x52	A0
    0x53	Rx/Tx 2B_0x53	46
    0x54	Rx/Tx 2B_0x54	52
    0x55	Rx/Tx 2B_0x55	8C
    0x56	Rx/Tx 2B_0x56	B0
    0x57	Rx/Tx 2B_0x57	C8
    0x58	Rx/Tx 2B_0x58	57
    0x59	Rx/Tx 2B_0x59	5D
    0x5A	Rx/Tx 2B_0x5A	69
    0x5B	Rx/Tx 2B_0x5B	75
    0x5C	Rx/Tx 2B_0x5C	D5
    0x5D	Rx/Tx 2B_0x5D	99
    0x5E	Rx/Tx 2B_0x5E	96
    0x5F	Rx/Tx 2B_0x5F	A5
    0x60	Rx/Tx 2B_0x60	B0
    0x61	Rx/Tx 2B_0x61	B2
    0x62	Rx/Tx 2B_0x62	20
    0x63	Rx/Tx 2B_0x63	B1
    0x64	Rx/Tx 2B_0x64	11
    0x65	Rx/Tx 2B_0x65	00
    0x66	Rx/Tx 2B_0x66	00
    0x67	Rx/Tx 2B_0x67	20
    0x68	Rx/Tx 2B_0x68	00
    0x69	Rx/Tx 2B_0x69	0A
    0x6A	Rx/Tx 2B_0x6A	22
    0x6B	Rx/Tx 2B_0x6B	40
    0x6C	Rx/Tx 2B_0x6C	00
    0x6D	Rx/Tx 2B_0x6D	00
    0x6E	Rx/Tx 2B_0x6E	00
    0x6F	Rx/Tx 2B_0x6F	00
    0x70	Rx/Tx 2B_0x70	03
    0x71	Rx/Tx 2B_0x71	20
    0x72	Rx/Tx 2B_0x72	00
    0x73	Rx/Tx 2B_0x73	00
    0x74	Rx/Tx 2B_0x74	00
    0x75	Rx/Tx 2B_0x75	00
    0x76	Rx/Tx 2B_0x76	22
    0x77	Rx/Tx 2B_0x77	1A
    0x78	Rx/Tx 2B_0x78	00
    0x79	Rx/Tx 2B_0x79	10
    0x7A	Rx/Tx 2B_0x7A	00
    0x7B	Rx/Tx 2B_0x7B	00
    0x7C	Rx/Tx 2B_0x7C	00
    0x7D	Rx/Tx 2B_0x7D	48
    0x7E	Rx/Tx 2B_0x7E	13
    0x7F	Rx/Tx 2B_0x7F	3A
    0x80	Rx/Tx 2B_0x80	00
    0x81	Rx/Tx 2B_0x81	E4
    0x82	Rx/Tx 2B_0x82	00
    0x83	Rx/Tx 2B_0x83	00
    0x84	Rx/Tx 2B_0x84	00
    0x85	Rx/Tx 2B_0x85	00
    0x86	Rx/Tx 2B_0x86	00
    0x87	Rx/Tx 2B_0x87	00
    0x88	Rx/Tx 2B_0x88	00
    0x89	Rx/Tx 2B_0x89	01
    0x8A	Rx/Tx 2B_0x8A	84
    0x8B	Rx/Tx 2B_0x8B	00
    0x8C	Rx/Tx 2B_0x8C	00
    0x8D	Rx/Tx 2B_0x8D	02
    0x8E	Rx/Tx 2B_0x8E	1C
    0x8F	Rx/Tx 2B_0x8F	00
    0x90	Rx/Tx 2B_0x90	00
    0x91	Rx/Tx 2B_0x91	00
    0x92	Rx/Tx 2B_0x92	00
    0x93	Rx/Tx 2B_0x93	00
    0x94	Rx/Tx 2B_0x94	00
    0x95	Rx/Tx 2B_0x95	00
    0x96	Rx/Tx 2B_0x96	04
    0x97	Rx/Tx 2B_0x97	00
    0x98	Rx/Tx 2B_0x98	3F
    0x99	Rx/Tx 2B_0x99	3F
    0x9A	Rx/Tx 2B_0x9A	3F
    0x9B	Rx/Tx 2B_0x9B	00
    0x0	Rx/Tx 3A_0x00	00
    0x1	Rx/Tx 3A_0x01	00
    0x2	Rx/Tx 3A_0x02	00
    0x3	Rx/Tx 3A_0x03	00
    0x4	Rx/Tx 3A_0x04	01
    0x5	Rx/Tx 3A_0x05	01
    0x6	Rx/Tx 3A_0x06	01
    0x7	Rx/Tx 3A_0x07	01
    0x8	Rx/Tx 3A_0x08	60
    0x9	Rx/Tx 3A_0x09	00
    0xA	Rx/Tx 3A_0x0A	10
    0xB	Rx/Tx 3A_0x0B	6F
    0xC	Rx/Tx 3A_0x0C	08
    0xD	Rx/Tx 3A_0x0D	B4
    0xE	Rx/Tx 3A_0x0E	93
    0xF	Rx/Tx 3A_0x0F	69
    0x10	Rx/Tx 3A_0x10	3A
    0x11	Rx/Tx 3A_0x11	20
    0x12	Rx/Tx 3A_0x12	E0
    0x13	Rx/Tx 3A_0x13	90
    0x14	Rx/Tx 3A_0x14	00
    0x15	Rx/Tx 3A_0x15	10
    0x16	Rx/Tx 3A_0x16	7A
    0x17	Rx/Tx 3A_0x17	36
    0x18	Rx/Tx 3A_0x18	40
    0x19	Rx/Tx 3A_0x19	25
    0x1A	Rx/Tx 3A_0x1A	A0
    0x1B	Rx/Tx 3A_0x1B	03
    0x1C	Rx/Tx 3A_0x1C	24
    0x1D	Rx/Tx 3A_0x1D	00
    0x1E	Rx/Tx 3A_0x1E	E9
    0x1F	Rx/Tx 3A_0x1F	55
    0x20	Rx/Tx 3A_0x20	00
    0x21	Rx/Tx 3A_0x21	00
    0x22	Rx/Tx 3A_0x22	00
    0x23	Rx/Tx 3A_0x23	40
    0x24	Rx/Tx 3A_0x24	40
    0x25	Rx/Tx 3A_0x25	00
    0x26	Rx/Tx 3A_0x26	0A
    0x27	Rx/Tx 3A_0x27	00
    0x28	Rx/Tx 3A_0x28	00
    0x29	Rx/Tx 3A_0x29	00
    0x2A	Rx/Tx 3A_0x2A	30
    0x2B	Rx/Tx 3A_0x2B	00
    0x2C	Rx/Tx 3A_0x2C	F2
    0x2D	Rx/Tx 3A_0x2D	04
    0x2E	Rx/Tx 3A_0x2E	00
    0x2F	Rx/Tx 3A_0x2F	F6
    0x30	Rx/Tx 3A_0x30	00
    0x31	Rx/Tx 3A_0x31	20
    0x32	Rx/Tx 3A_0x32	11
    0x33	Rx/Tx 3A_0x33	88
    0x34	Rx/Tx 3A_0x34	3F
    0x35	Rx/Tx 3A_0x35	1F
    0x36	Rx/Tx 3A_0x36	30
    0x37	Rx/Tx 3A_0x37	00
    0x38	Rx/Tx 3A_0x38	00
    0x39	Rx/Tx 3A_0x39	00
    0x3A	Rx/Tx 3A_0x3A	A5
    0x3B	Rx/Tx 3A_0x3B	00
    0x3C	Rx/Tx 3A_0x3C	00
    0x3D	Rx/Tx 3A_0x3D	3F
    0x3E	Rx/Tx 3A_0x3E	40
    0x3F	Rx/Tx 3A_0x3F	C0
    0x40	Rx/Tx 3A_0x40	00
    0x41	Rx/Tx 3A_0x41	01
    0x42	Rx/Tx 3A_0x42	04
    0x43	Rx/Tx 3A_0x43	10
    0x44	Rx/Tx 3A_0x44	40
    0x45	Rx/Tx 3A_0x45	08
    0x46	Rx/Tx 3A_0x46	02
    0x47	Rx/Tx 3A_0x47	80
    0x48	Rx/Tx 3A_0x48	03
    0x49	Rx/Tx 3A_0x49	0C
    0x4A	Rx/Tx 3A_0x4A	30
    0x4B	Rx/Tx 3A_0x4B	41
    0x4C	Rx/Tx 3A_0x4C	50
    0x4D	Rx/Tx 3A_0x4D	C0
    0x4E	Rx/Tx 3A_0x4E	60
    0x4F	Rx/Tx 3A_0x4F	90
    0x50	Rx/Tx 3A_0x50	88
    0x51	Rx/Tx 3A_0x51	82
    0x52	Rx/Tx 3A_0x52	A0
    0x53	Rx/Tx 3A_0x53	46
    0x54	Rx/Tx 3A_0x54	52
    0x55	Rx/Tx 3A_0x55	8C
    0x56	Rx/Tx 3A_0x56	B0
    0x57	Rx/Tx 3A_0x57	C8
    0x58	Rx/Tx 3A_0x58	57
    0x59	Rx/Tx 3A_0x59	5D
    0x5A	Rx/Tx 3A_0x5A	69
    0x5B	Rx/Tx 3A_0x5B	75
    0x5C	Rx/Tx 3A_0x5C	D5
    0x5D	Rx/Tx 3A_0x5D	99
    0x5E	Rx/Tx 3A_0x5E	96
    0x5F	Rx/Tx 3A_0x5F	A5
    0x60	Rx/Tx 3A_0x60	B0
    0x61	Rx/Tx 3A_0x61	B2
    0x62	Rx/Tx 3A_0x62	20
    0x63	Rx/Tx 3A_0x63	B1
    0x64	Rx/Tx 3A_0x64	11
    0x65	Rx/Tx 3A_0x65	00
    0x66	Rx/Tx 3A_0x66	00
    0x67	Rx/Tx 3A_0x67	20
    0x68	Rx/Tx 3A_0x68	00
    0x69	Rx/Tx 3A_0x69	0A
    0x6A	Rx/Tx 3A_0x6A	22
    0x6B	Rx/Tx 3A_0x6B	40
    0x6C	Rx/Tx 3A_0x6C	00
    0x6D	Rx/Tx 3A_0x6D	00
    0x6E	Rx/Tx 3A_0x6E	00
    0x6F	Rx/Tx 3A_0x6F	00
    0x70	Rx/Tx 3A_0x70	03
    0x71	Rx/Tx 3A_0x71	20
    0x72	Rx/Tx 3A_0x72	00
    0x73	Rx/Tx 3A_0x73	00
    0x74	Rx/Tx 3A_0x74	00
    0x75	Rx/Tx 3A_0x75	00
    0x76	Rx/Tx 3A_0x76	22
    0x77	Rx/Tx 3A_0x77	1A
    0x78	Rx/Tx 3A_0x78	00
    0x79	Rx/Tx 3A_0x79	10
    0x7A	Rx/Tx 3A_0x7A	00
    0x7B	Rx/Tx 3A_0x7B	00
    0x7C	Rx/Tx 3A_0x7C	00
    0x7D	Rx/Tx 3A_0x7D	48
    0x7E	Rx/Tx 3A_0x7E	13
    0x7F	Rx/Tx 3A_0x7F	3A
    0x80	Rx/Tx 3A_0x80	00
    0x81	Rx/Tx 3A_0x81	E4
    0x82	Rx/Tx 3A_0x82	00
    0x83	Rx/Tx 3A_0x83	00
    0x84	Rx/Tx 3A_0x84	00
    0x85	Rx/Tx 3A_0x85	00
    0x86	Rx/Tx 3A_0x86	00
    0x87	Rx/Tx 3A_0x87	00
    0x88	Rx/Tx 3A_0x88	00
    0x89	Rx/Tx 3A_0x89	00
    0x8A	Rx/Tx 3A_0x8A	09
    0x8B	Rx/Tx 3A_0x8B	00
    0x8C	Rx/Tx 3A_0x8C	00
    0x8D	Rx/Tx 3A_0x8D	02
    0x8E	Rx/Tx 3A_0x8E	1C
    0x8F	Rx/Tx 3A_0x8F	00
    0x90	Rx/Tx 3A_0x90	00
    0x91	Rx/Tx 3A_0x91	00
    0x92	Rx/Tx 3A_0x92	00
    0x93	Rx/Tx 3A_0x93	00
    0x94	Rx/Tx 3A_0x94	00
    0x95	Rx/Tx 3A_0x95	00
    0x96	Rx/Tx 3A_0x96	04
    0x97	Rx/Tx 3A_0x97	00
    0x98	Rx/Tx 3A_0x98	3F
    0x99	Rx/Tx 3A_0x99	3F
    0x9A	Rx/Tx 3A_0x9A	3F
    0x9B	Rx/Tx 3A_0x9B	00
    0x0	Rx/Tx 3B_0x00	00
    0x1	Rx/Tx 3B_0x01	00
    0x2	Rx/Tx 3B_0x02	00
    0x3	Rx/Tx 3B_0x03	00
    0x4	Rx/Tx 3B_0x04	01
    0x5	Rx/Tx 3B_0x05	01
    0x6	Rx/Tx 3B_0x06	01
    0x7	Rx/Tx 3B_0x07	01
    0x8	Rx/Tx 3B_0x08	60
    0x9	Rx/Tx 3B_0x09	00
    0xA	Rx/Tx 3B_0x0A	10
    0xB	Rx/Tx 3B_0x0B	6F
    0xC	Rx/Tx 3B_0x0C	08
    0xD	Rx/Tx 3B_0x0D	B4
    0xE	Rx/Tx 3B_0x0E	93
    0xF	Rx/Tx 3B_0x0F	69
    0x10	Rx/Tx 3B_0x10	3A
    0x11	Rx/Tx 3B_0x11	20
    0x12	Rx/Tx 3B_0x12	E0
    0x13	Rx/Tx 3B_0x13	90
    0x14	Rx/Tx 3B_0x14	00
    0x15	Rx/Tx 3B_0x15	10
    0x16	Rx/Tx 3B_0x16	7A
    0x17	Rx/Tx 3B_0x17	36
    0x18	Rx/Tx 3B_0x18	40
    0x19	Rx/Tx 3B_0x19	25
    0x1A	Rx/Tx 3B_0x1A	A0
    0x1B	Rx/Tx 3B_0x1B	03
    0x1C	Rx/Tx 3B_0x1C	24
    0x1D	Rx/Tx 3B_0x1D	00
    0x1E	Rx/Tx 3B_0x1E	E9
    0x1F	Rx/Tx 3B_0x1F	55
    0x20	Rx/Tx 3B_0x20	00
    0x21	Rx/Tx 3B_0x21	00
    0x22	Rx/Tx 3B_0x22	00
    0x23	Rx/Tx 3B_0x23	40
    0x24	Rx/Tx 3B_0x24	40
    0x25	Rx/Tx 3B_0x25	00
    0x26	Rx/Tx 3B_0x26	00
    0x27	Rx/Tx 3B_0x27	00
    0x28	Rx/Tx 3B_0x28	00
    0x29	Rx/Tx 3B_0x29	00
    0x2A	Rx/Tx 3B_0x2A	30
    0x2B	Rx/Tx 3B_0x2B	00
    0x2C	Rx/Tx 3B_0x2C	F2
    0x2D	Rx/Tx 3B_0x2D	04
    0x2E	Rx/Tx 3B_0x2E	00
    0x2F	Rx/Tx 3B_0x2F	F6
    0x30	Rx/Tx 3B_0x30	00
    0x31	Rx/Tx 3B_0x31	20
    0x32	Rx/Tx 3B_0x32	11
    0x33	Rx/Tx 3B_0x33	88
    0x34	Rx/Tx 3B_0x34	3F
    0x35	Rx/Tx 3B_0x35	1F
    0x36	Rx/Tx 3B_0x36	30
    0x37	Rx/Tx 3B_0x37	00
    0x38	Rx/Tx 3B_0x38	00
    0x39	Rx/Tx 3B_0x39	00
    0x3A	Rx/Tx 3B_0x3A	A5
    0x3B	Rx/Tx 3B_0x3B	00
    0x3C	Rx/Tx 3B_0x3C	00
    0x3D	Rx/Tx 3B_0x3D	3F
    0x3E	Rx/Tx 3B_0x3E	40
    0x3F	Rx/Tx 3B_0x3F	C0
    0x40	Rx/Tx 3B_0x40	00
    0x41	Rx/Tx 3B_0x41	01
    0x42	Rx/Tx 3B_0x42	04
    0x43	Rx/Tx 3B_0x43	10
    0x44	Rx/Tx 3B_0x44	40
    0x45	Rx/Tx 3B_0x45	08
    0x46	Rx/Tx 3B_0x46	02
    0x47	Rx/Tx 3B_0x47	80
    0x48	Rx/Tx 3B_0x48	03
    0x49	Rx/Tx 3B_0x49	0C
    0x4A	Rx/Tx 3B_0x4A	30
    0x4B	Rx/Tx 3B_0x4B	41
    0x4C	Rx/Tx 3B_0x4C	50
    0x4D	Rx/Tx 3B_0x4D	C0
    0x4E	Rx/Tx 3B_0x4E	60
    0x4F	Rx/Tx 3B_0x4F	90
    0x50	Rx/Tx 3B_0x50	88
    0x51	Rx/Tx 3B_0x51	82
    0x52	Rx/Tx 3B_0x52	A0
    0x53	Rx/Tx 3B_0x53	46
    0x54	Rx/Tx 3B_0x54	52
    0x55	Rx/Tx 3B_0x55	8C
    0x56	Rx/Tx 3B_0x56	B0
    0x57	Rx/Tx 3B_0x57	C8
    0x58	Rx/Tx 3B_0x58	57
    0x59	Rx/Tx 3B_0x59	5D
    0x5A	Rx/Tx 3B_0x5A	69
    0x5B	Rx/Tx 3B_0x5B	75
    0x5C	Rx/Tx 3B_0x5C	D5
    0x5D	Rx/Tx 3B_0x5D	99
    0x5E	Rx/Tx 3B_0x5E	96
    0x5F	Rx/Tx 3B_0x5F	A5
    0x60	Rx/Tx 3B_0x60	B0
    0x61	Rx/Tx 3B_0x61	B2
    0x62	Rx/Tx 3B_0x62	20
    0x63	Rx/Tx 3B_0x63	B1
    0x64	Rx/Tx 3B_0x64	11
    0x65	Rx/Tx 3B_0x65	00
    0x66	Rx/Tx 3B_0x66	00
    0x67	Rx/Tx 3B_0x67	20
    0x68	Rx/Tx 3B_0x68	00
    0x69	Rx/Tx 3B_0x69	0A
    0x6A	Rx/Tx 3B_0x6A	22
    0x6B	Rx/Tx 3B_0x6B	40
    0x6C	Rx/Tx 3B_0x6C	00
    0x6D	Rx/Tx 3B_0x6D	00
    0x6E	Rx/Tx 3B_0x6E	00
    0x6F	Rx/Tx 3B_0x6F	00
    0x70	Rx/Tx 3B_0x70	03
    0x71	Rx/Tx 3B_0x71	20
    0x72	Rx/Tx 3B_0x72	00
    0x73	Rx/Tx 3B_0x73	00
    0x74	Rx/Tx 3B_0x74	00
    0x75	Rx/Tx 3B_0x75	00
    0x76	Rx/Tx 3B_0x76	22
    0x77	Rx/Tx 3B_0x77	1A
    0x78	Rx/Tx 3B_0x78	00
    0x79	Rx/Tx 3B_0x79	10
    0x7A	Rx/Tx 3B_0x7A	00
    0x7B	Rx/Tx 3B_0x7B	00
    0x7C	Rx/Tx 3B_0x7C	00
    0x7D	Rx/Tx 3B_0x7D	48
    0x7E	Rx/Tx 3B_0x7E	13
    0x7F	Rx/Tx 3B_0x7F	3A
    0x80	Rx/Tx 3B_0x80	00
    0x81	Rx/Tx 3B_0x81	E4
    0x82	Rx/Tx 3B_0x82	00
    0x83	Rx/Tx 3B_0x83	00
    0x84	Rx/Tx 3B_0x84	00
    0x85	Rx/Tx 3B_0x85	00
    0x86	Rx/Tx 3B_0x86	00
    0x87	Rx/Tx 3B_0x87	00
    0x88	Rx/Tx 3B_0x88	00
    0x89	Rx/Tx 3B_0x89	00
    0x8A	Rx/Tx 3B_0x8A	13
    0x8B	Rx/Tx 3B_0x8B	00
    0x8C	Rx/Tx 3B_0x8C	00
    0x8D	Rx/Tx 3B_0x8D	02
    0x8E	Rx/Tx 3B_0x8E	1C
    0x8F	Rx/Tx 3B_0x8F	00
    0x90	Rx/Tx 3B_0x90	00
    0x91	Rx/Tx 3B_0x91	00
    0x92	Rx/Tx 3B_0x92	00
    0x93	Rx/Tx 3B_0x93	00
    0x94	Rx/Tx 3B_0x94	00
    0x95	Rx/Tx 3B_0x95	00
    0x96	Rx/Tx 3B_0x96	04
    0x97	Rx/Tx 3B_0x97	00
    0x98	Rx/Tx 3B_0x98	3F
    0x99	Rx/Tx 3B_0x99	3F
    0x9A	Rx/Tx 3B_0x9A	3F
    0x9B	Rx/Tx 3B_0x9B	00
    0x0	Rx/Tx 4A_0x00	00
    0x1	Rx/Tx 4A_0x01	00
    0x2	Rx/Tx 4A_0x02	00
    0x3	Rx/Tx 4A_0x03	00
    0x4	Rx/Tx 4A_0x04	01
    0x5	Rx/Tx 4A_0x05	01
    0x6	Rx/Tx 4A_0x06	01
    0x7	Rx/Tx 4A_0x07	01
    0x8	Rx/Tx 4A_0x08	60
    0x9	Rx/Tx 4A_0x09	00
    0xA	Rx/Tx 4A_0x0A	10
    0xB	Rx/Tx 4A_0x0B	6F
    0xC	Rx/Tx 4A_0x0C	08
    0xD	Rx/Tx 4A_0x0D	B4
    0xE	Rx/Tx 4A_0x0E	93
    0xF	Rx/Tx 4A_0x0F	69
    0x10	Rx/Tx 4A_0x10	3A
    0x11	Rx/Tx 4A_0x11	20
    0x12	Rx/Tx 4A_0x12	E0
    0x13	Rx/Tx 4A_0x13	90
    0x14	Rx/Tx 4A_0x14	00
    0x15	Rx/Tx 4A_0x15	10
    0x16	Rx/Tx 4A_0x16	7A
    0x17	Rx/Tx 4A_0x17	36
    0x18	Rx/Tx 4A_0x18	40
    0x19	Rx/Tx 4A_0x19	25
    0x1A	Rx/Tx 4A_0x1A	A0
    0x1B	Rx/Tx 4A_0x1B	03
    0x1C	Rx/Tx 4A_0x1C	24
    0x1D	Rx/Tx 4A_0x1D	00
    0x1E	Rx/Tx 4A_0x1E	E9
    0x1F	Rx/Tx 4A_0x1F	55
    0x20	Rx/Tx 4A_0x20	00
    0x21	Rx/Tx 4A_0x21	00
    0x22	Rx/Tx 4A_0x22	00
    0x23	Rx/Tx 4A_0x23	40
    0x24	Rx/Tx 4A_0x24	40
    0x25	Rx/Tx 4A_0x25	16
    0x26	Rx/Tx 4A_0x26	00
    0x27	Rx/Tx 4A_0x27	00
    0x28	Rx/Tx 4A_0x28	00
    0x29	Rx/Tx 4A_0x29	00
    0x2A	Rx/Tx 4A_0x2A	30
    0x2B	Rx/Tx 4A_0x2B	00
    0x2C	Rx/Tx 4A_0x2C	F2
    0x2D	Rx/Tx 4A_0x2D	04
    0x2E	Rx/Tx 4A_0x2E	00
    0x2F	Rx/Tx 4A_0x2F	F6
    0x30	Rx/Tx 4A_0x30	00
    0x31	Rx/Tx 4A_0x31	20
    0x32	Rx/Tx 4A_0x32	11
    0x33	Rx/Tx 4A_0x33	88
    0x34	Rx/Tx 4A_0x34	3F
    0x35	Rx/Tx 4A_0x35	1F
    0x36	Rx/Tx 4A_0x36	30
    0x37	Rx/Tx 4A_0x37	00
    0x38	Rx/Tx 4A_0x38	00
    0x39	Rx/Tx 4A_0x39	00
    0x3A	Rx/Tx 4A_0x3A	A5
    0x3B	Rx/Tx 4A_0x3B	00
    0x3C	Rx/Tx 4A_0x3C	00
    0x3D	Rx/Tx 4A_0x3D	3F
    0x3E	Rx/Tx 4A_0x3E	40
    0x3F	Rx/Tx 4A_0x3F	C0
    0x40	Rx/Tx 4A_0x40	00
    0x41	Rx/Tx 4A_0x41	01
    0x42	Rx/Tx 4A_0x42	04
    0x43	Rx/Tx 4A_0x43	10
    0x44	Rx/Tx 4A_0x44	40
    0x45	Rx/Tx 4A_0x45	08
    0x46	Rx/Tx 4A_0x46	02
    0x47	Rx/Tx 4A_0x47	80
    0x48	Rx/Tx 4A_0x48	03
    0x49	Rx/Tx 4A_0x49	0C
    0x4A	Rx/Tx 4A_0x4A	30
    0x4B	Rx/Tx 4A_0x4B	41
    0x4C	Rx/Tx 4A_0x4C	50
    0x4D	Rx/Tx 4A_0x4D	C0
    0x4E	Rx/Tx 4A_0x4E	60
    0x4F	Rx/Tx 4A_0x4F	90
    0x50	Rx/Tx 4A_0x50	88
    0x51	Rx/Tx 4A_0x51	82
    0x52	Rx/Tx 4A_0x52	A0
    0x53	Rx/Tx 4A_0x53	46
    0x54	Rx/Tx 4A_0x54	52
    0x55	Rx/Tx 4A_0x55	8C
    0x56	Rx/Tx 4A_0x56	B0
    0x57	Rx/Tx 4A_0x57	C8
    0x58	Rx/Tx 4A_0x58	57
    0x59	Rx/Tx 4A_0x59	5D
    0x5A	Rx/Tx 4A_0x5A	69
    0x5B	Rx/Tx 4A_0x5B	75
    0x5C	Rx/Tx 4A_0x5C	D5
    0x5D	Rx/Tx 4A_0x5D	99
    0x5E	Rx/Tx 4A_0x5E	96
    0x5F	Rx/Tx 4A_0x5F	A5
    0x60	Rx/Tx 4A_0x60	B0
    0x61	Rx/Tx 4A_0x61	B2
    0x62	Rx/Tx 4A_0x62	20
    0x63	Rx/Tx 4A_0x63	B1
    0x64	Rx/Tx 4A_0x64	11
    0x65	Rx/Tx 4A_0x65	00
    0x66	Rx/Tx 4A_0x66	00
    0x67	Rx/Tx 4A_0x67	20
    0x68	Rx/Tx 4A_0x68	00
    0x69	Rx/Tx 4A_0x69	0A
    0x6A	Rx/Tx 4A_0x6A	22
    0x6B	Rx/Tx 4A_0x6B	40
    0x6C	Rx/Tx 4A_0x6C	00
    0x6D	Rx/Tx 4A_0x6D	00
    0x6E	Rx/Tx 4A_0x6E	00
    0x6F	Rx/Tx 4A_0x6F	00
    0x70	Rx/Tx 4A_0x70	03
    0x71	Rx/Tx 4A_0x71	20
    0x72	Rx/Tx 4A_0x72	00
    0x73	Rx/Tx 4A_0x73	00
    0x74	Rx/Tx 4A_0x74	00
    0x75	Rx/Tx 4A_0x75	00
    0x76	Rx/Tx 4A_0x76	22
    0x77	Rx/Tx 4A_0x77	1A
    0x78	Rx/Tx 4A_0x78	00
    0x79	Rx/Tx 4A_0x79	10
    0x7A	Rx/Tx 4A_0x7A	00
    0x7B	Rx/Tx 4A_0x7B	00
    0x7C	Rx/Tx 4A_0x7C	00
    0x7D	Rx/Tx 4A_0x7D	48
    0x7E	Rx/Tx 4A_0x7E	13
    0x7F	Rx/Tx 4A_0x7F	3A
    0x80	Rx/Tx 4A_0x80	00
    0x81	Rx/Tx 4A_0x81	E4
    0x82	Rx/Tx 4A_0x82	00
    0x83	Rx/Tx 4A_0x83	00
    0x84	Rx/Tx 4A_0x84	00
    0x85	Rx/Tx 4A_0x85	00
    0x86	Rx/Tx 4A_0x86	00
    0x87	Rx/Tx 4A_0x87	00
    0x88	Rx/Tx 4A_0x88	00
    0x89	Rx/Tx 4A_0x89	00
    0x8A	Rx/Tx 4A_0x8A	31
    0x8B	Rx/Tx 4A_0x8B	00
    0x8C	Rx/Tx 4A_0x8C	00
    0x8D	Rx/Tx 4A_0x8D	02
    0x8E	Rx/Tx 4A_0x8E	1C
    0x8F	Rx/Tx 4A_0x8F	00
    0x90	Rx/Tx 4A_0x90	00
    0x91	Rx/Tx 4A_0x91	00
    0x92	Rx/Tx 4A_0x92	00
    0x93	Rx/Tx 4A_0x93	00
    0x94	Rx/Tx 4A_0x94	00
    0x95	Rx/Tx 4A_0x95	00
    0x96	Rx/Tx 4A_0x96	04
    0x97	Rx/Tx 4A_0x97	00
    0x98	Rx/Tx 4A_0x98	3F
    0x99	Rx/Tx 4A_0x99	3F
    0x9A	Rx/Tx 4A_0x9A	3F
    0x9B	Rx/Tx 4A_0x9B	00
    0x0	Rx/Tx 4B_0x00	00
    0x1	Rx/Tx 4B_0x01	80
    0x2	Rx/Tx 4B_0x02	DC
    0x3	Rx/Tx 4B_0x03	00
    0x4	Rx/Tx 4B_0x04	01
    0x5	Rx/Tx 4B_0x05	01
    0x6	Rx/Tx 4B_0x06	01
    0x7	Rx/Tx 4B_0x07	01
    0x8	Rx/Tx 4B_0x08	60
    0x9	Rx/Tx 4B_0x09	00
    0xA	Rx/Tx 4B_0x0A	10
    0xB	Rx/Tx 4B_0x0B	6F
    0xC	Rx/Tx 4B_0x0C	08
    0xD	Rx/Tx 4B_0x0D	B4
    0xE	Rx/Tx 4B_0x0E	93
    0xF	Rx/Tx 4B_0x0F	69
    0x10	Rx/Tx 4B_0x10	3A
    0x11	Rx/Tx 4B_0x11	20
    0x12	Rx/Tx 4B_0x12	E0
    0x13	Rx/Tx 4B_0x13	90
    0x14	Rx/Tx 4B_0x14	00
    0x15	Rx/Tx 4B_0x15	10
    0x16	Rx/Tx 4B_0x16	7A
    0x17	Rx/Tx 4B_0x17	36
    0x18	Rx/Tx 4B_0x18	40
    0x19	Rx/Tx 4B_0x19	25
    0x1A	Rx/Tx 4B_0x1A	A0
    0x1B	Rx/Tx 4B_0x1B	03
    0x1C	Rx/Tx 4B_0x1C	24
    0x1D	Rx/Tx 4B_0x1D	00
    0x1E	Rx/Tx 4B_0x1E	E9
    0x1F	Rx/Tx 4B_0x1F	55
    0x20	Rx/Tx 4B_0x20	00
    0x21	Rx/Tx 4B_0x21	00
    0x22	Rx/Tx 4B_0x22	00
    0x23	Rx/Tx 4B_0x23	40
    0x24	Rx/Tx 4B_0x24	00
    0x25	Rx/Tx 4B_0x25	03
    0x26	Rx/Tx 4B_0x26	35
    0x27	Rx/Tx 4B_0x27	3D
    0x28	Rx/Tx 4B_0x28	B1
    0x29	Rx/Tx 4B_0x29	40
    0x2A	Rx/Tx 4B_0x2A	30
    0x2B	Rx/Tx 4B_0x2B	00
    0x2C	Rx/Tx 4B_0x2C	F2
    0x2D	Rx/Tx 4B_0x2D	04
    0x2E	Rx/Tx 4B_0x2E	00
    0x2F	Rx/Tx 4B_0x2F	F6
    0x30	Rx/Tx 4B_0x30	00
    0x31	Rx/Tx 4B_0x31	20
    0x32	Rx/Tx 4B_0x32	11
    0x33	Rx/Tx 4B_0x33	88
    0x34	Rx/Tx 4B_0x34	BF
    0x35	Rx/Tx 4B_0x35	1F
    0x36	Rx/Tx 4B_0x36	30
    0x37	Rx/Tx 4B_0x37	01
    0x38	Rx/Tx 4B_0x38	00
    0x39	Rx/Tx 4B_0x39	00
    0x3A	Rx/Tx 4B_0x3A	A5
    0x3B	Rx/Tx 4B_0x3B	31
    0x3C	Rx/Tx 4B_0x3C	1E
    0x3D	Rx/Tx 4B_0x3D	3F
    0x3E	Rx/Tx 4B_0x3E	40
    0x3F	Rx/Tx 4B_0x3F	C0
    0x40	Rx/Tx 4B_0x40	00
    0x41	Rx/Tx 4B_0x41	01
    0x42	Rx/Tx 4B_0x42	04
    0x43	Rx/Tx 4B_0x43	10
    0x44	Rx/Tx 4B_0x44	40
    0x45	Rx/Tx 4B_0x45	08
    0x46	Rx/Tx 4B_0x46	02
    0x47	Rx/Tx 4B_0x47	80
    0x48	Rx/Tx 4B_0x48	03
    0x49	Rx/Tx 4B_0x49	0C
    0x4A	Rx/Tx 4B_0x4A	30
    0x4B	Rx/Tx 4B_0x4B	41
    0x4C	Rx/Tx 4B_0x4C	50
    0x4D	Rx/Tx 4B_0x4D	C0
    0x4E	Rx/Tx 4B_0x4E	60
    0x4F	Rx/Tx 4B_0x4F	90
    0x50	Rx/Tx 4B_0x50	88
    0x51	Rx/Tx 4B_0x51	82
    0x52	Rx/Tx 4B_0x52	A0
    0x53	Rx/Tx 4B_0x53	46
    0x54	Rx/Tx 4B_0x54	52
    0x55	Rx/Tx 4B_0x55	8C
    0x56	Rx/Tx 4B_0x56	B0
    0x57	Rx/Tx 4B_0x57	C8
    0x58	Rx/Tx 4B_0x58	57
    0x59	Rx/Tx 4B_0x59	5D
    0x5A	Rx/Tx 4B_0x5A	69
    0x5B	Rx/Tx 4B_0x5B	75
    0x5C	Rx/Tx 4B_0x5C	D5
    0x5D	Rx/Tx 4B_0x5D	99
    0x5E	Rx/Tx 4B_0x5E	96
    0x5F	Rx/Tx 4B_0x5F	A5
    0x60	Rx/Tx 4B_0x60	B0
    0x61	Rx/Tx 4B_0x61	B2
    0x62	Rx/Tx 4B_0x62	20
    0x63	Rx/Tx 4B_0x63	B1
    0x64	Rx/Tx 4B_0x64	FF
    0x65	Rx/Tx 4B_0x65	00
    0x66	Rx/Tx 4B_0x66	00
    0x67	Rx/Tx 4B_0x67	E0
    0x68	Rx/Tx 4B_0x68	00
    0x69	Rx/Tx 4B_0x69	0A
    0x6A	Rx/Tx 4B_0x6A	22
    0x6B	Rx/Tx 4B_0x6B	40
    0x6C	Rx/Tx 4B_0x6C	00
    0x6D	Rx/Tx 4B_0x6D	00
    0x6E	Rx/Tx 4B_0x6E	00
    0x6F	Rx/Tx 4B_0x6F	00
    0x70	Rx/Tx 4B_0x70	03
    0x71	Rx/Tx 4B_0x71	20
    0x72	Rx/Tx 4B_0x72	00
    0x73	Rx/Tx 4B_0x73	00
    0x74	Rx/Tx 4B_0x74	00
    0x75	Rx/Tx 4B_0x75	00
    0x76	Rx/Tx 4B_0x76	22
    0x77	Rx/Tx 4B_0x77	1A
    0x78	Rx/Tx 4B_0x78	30
    0x79	Rx/Tx 4B_0x79	10
    0x7A	Rx/Tx 4B_0x7A	00
    0x7B	Rx/Tx 4B_0x7B	00
    0x7C	Rx/Tx 4B_0x7C	00
    0x7D	Rx/Tx 4B_0x7D	48
    0x7E	Rx/Tx 4B_0x7E	13
    0x7F	Rx/Tx 4B_0x7F	3A
    0x80	Rx/Tx 4B_0x80	17
    0x81	Rx/Tx 4B_0x81	E4
    0x82	Rx/Tx 4B_0x82	00
    0x83	Rx/Tx 4B_0x83	00
    0x84	Rx/Tx 4B_0x84	00
    0x85	Rx/Tx 4B_0x85	00
    0x86	Rx/Tx 4B_0x86	00
    0x87	Rx/Tx 4B_0x87	00
    0x88	Rx/Tx 4B_0x88	00
    0x89	Rx/Tx 4B_0x89	00
    0x8A	Rx/Tx 4B_0x8A	05
    0x8B	Rx/Tx 4B_0x8B	00
    0x8C	Rx/Tx 4B_0x8C	00
    0x8D	Rx/Tx 4B_0x8D	02
    0x8E	Rx/Tx 4B_0x8E	1C
    0x8F	Rx/Tx 4B_0x8F	01
    0x90	Rx/Tx 4B_0x90	00
    0x91	Rx/Tx 4B_0x91	00
    0x92	Rx/Tx 4B_0x92	00
    0x93	Rx/Tx 4B_0x93	00
    0x94	Rx/Tx 4B_0x94	00
    0x95	Rx/Tx 4B_0x95	00
    0x96	Rx/Tx 4B_0x96	04
    0x97	Rx/Tx 4B_0x97	00
    0x98	Rx/Tx 4B_0x98	3F
    0x99	Rx/Tx 4B_0x99	3F
    0x9A	Rx/Tx 4B_0x9A	3F
    0x9B	Rx/Tx 4B_0x9B	00
    0x0	Rx/Tx 5A_0x00	00
    0x1	Rx/Tx 5A_0x01	00
    0x2	Rx/Tx 5A_0x02	00
    0x3	Rx/Tx 5A_0x03	00
    0x4	Rx/Tx 5A_0x04	01
    0x5	Rx/Tx 5A_0x05	01
    0x6	Rx/Tx 5A_0x06	01
    0x7	Rx/Tx 5A_0x07	01
    0x8	Rx/Tx 5A_0x08	60
    0x9	Rx/Tx 5A_0x09	00
    0xA	Rx/Tx 5A_0x0A	10
    0xB	Rx/Tx 5A_0x0B	6F
    0xC	Rx/Tx 5A_0x0C	08
    0xD	Rx/Tx 5A_0x0D	B4
    0xE	Rx/Tx 5A_0x0E	93
    0xF	Rx/Tx 5A_0x0F	69
    0x10	Rx/Tx 5A_0x10	3A
    0x11	Rx/Tx 5A_0x11	20
    0x12	Rx/Tx 5A_0x12	E0
    0x13	Rx/Tx 5A_0x13	90
    0x14	Rx/Tx 5A_0x14	00
    0x15	Rx/Tx 5A_0x15	10
    0x16	Rx/Tx 5A_0x16	7A
    0x17	Rx/Tx 5A_0x17	36
    0x18	Rx/Tx 5A_0x18	40
    0x19	Rx/Tx 5A_0x19	25
    0x1A	Rx/Tx 5A_0x1A	A0
    0x1B	Rx/Tx 5A_0x1B	03
    0x1C	Rx/Tx 5A_0x1C	24
    0x1D	Rx/Tx 5A_0x1D	00
    0x1E	Rx/Tx 5A_0x1E	E9
    0x1F	Rx/Tx 5A_0x1F	55
    0x20	Rx/Tx 5A_0x20	00
    0x21	Rx/Tx 5A_0x21	00
    0x22	Rx/Tx 5A_0x22	00
    0x23	Rx/Tx 5A_0x23	40
    0x24	Rx/Tx 5A_0x24	40
    0x25	Rx/Tx 5A_0x25	00
    0x26	Rx/Tx 5A_0x26	00
    0x27	Rx/Tx 5A_0x27	00
    0x28	Rx/Tx 5A_0x28	00
    0x29	Rx/Tx 5A_0x29	00
    0x2A	Rx/Tx 5A_0x2A	30
    0x2B	Rx/Tx 5A_0x2B	00
    0x2C	Rx/Tx 5A_0x2C	F2
    0x2D	Rx/Tx 5A_0x2D	04
    0x2E	Rx/Tx 5A_0x2E	00
    0x2F	Rx/Tx 5A_0x2F	F6
    0x30	Rx/Tx 5A_0x30	00
    0x31	Rx/Tx 5A_0x31	20
    0x32	Rx/Tx 5A_0x32	11
    0x33	Rx/Tx 5A_0x33	88
    0x34	Rx/Tx 5A_0x34	3F
    0x35	Rx/Tx 5A_0x35	1F
    0x36	Rx/Tx 5A_0x36	30
    0x37	Rx/Tx 5A_0x37	00
    0x38	Rx/Tx 5A_0x38	00
    0x39	Rx/Tx 5A_0x39	00
    0x3A	Rx/Tx 5A_0x3A	A5
    0x3B	Rx/Tx 5A_0x3B	00
    0x3C	Rx/Tx 5A_0x3C	00
    0x3D	Rx/Tx 5A_0x3D	3F
    0x3E	Rx/Tx 5A_0x3E	40
    0x3F	Rx/Tx 5A_0x3F	C0
    0x40	Rx/Tx 5A_0x40	00
    0x41	Rx/Tx 5A_0x41	01
    0x42	Rx/Tx 5A_0x42	04
    0x43	Rx/Tx 5A_0x43	10
    0x44	Rx/Tx 5A_0x44	40
    0x45	Rx/Tx 5A_0x45	08
    0x46	Rx/Tx 5A_0x46	02
    0x47	Rx/Tx 5A_0x47	80
    0x48	Rx/Tx 5A_0x48	03
    0x49	Rx/Tx 5A_0x49	0C
    0x4A	Rx/Tx 5A_0x4A	30
    0x4B	Rx/Tx 5A_0x4B	41
    0x4C	Rx/Tx 5A_0x4C	50
    0x4D	Rx/Tx 5A_0x4D	C0
    0x4E	Rx/Tx 5A_0x4E	60
    0x4F	Rx/Tx 5A_0x4F	90
    0x50	Rx/Tx 5A_0x50	88
    0x51	Rx/Tx 5A_0x51	82
    0x52	Rx/Tx 5A_0x52	A0
    0x53	Rx/Tx 5A_0x53	46
    0x54	Rx/Tx 5A_0x54	52
    0x55	Rx/Tx 5A_0x55	8C
    0x56	Rx/Tx 5A_0x56	B0
    0x57	Rx/Tx 5A_0x57	C8
    0x58	Rx/Tx 5A_0x58	57
    0x59	Rx/Tx 5A_0x59	5D
    0x5A	Rx/Tx 5A_0x5A	69
    0x5B	Rx/Tx 5A_0x5B	75
    0x5C	Rx/Tx 5A_0x5C	D5
    0x5D	Rx/Tx 5A_0x5D	99
    0x5E	Rx/Tx 5A_0x5E	96
    0x5F	Rx/Tx 5A_0x5F	A5
    0x60	Rx/Tx 5A_0x60	B0
    0x61	Rx/Tx 5A_0x61	B2
    0x62	Rx/Tx 5A_0x62	20
    0x63	Rx/Tx 5A_0x63	B1
    0x64	Rx/Tx 5A_0x64	11
    0x65	Rx/Tx 5A_0x65	00
    0x66	Rx/Tx 5A_0x66	00
    0x67	Rx/Tx 5A_0x67	20
    0x68	Rx/Tx 5A_0x68	00
    0x69	Rx/Tx 5A_0x69	0A
    0x6A	Rx/Tx 5A_0x6A	22
    0x6B	Rx/Tx 5A_0x6B	40
    0x6C	Rx/Tx 5A_0x6C	00
    0x6D	Rx/Tx 5A_0x6D	00
    0x6E	Rx/Tx 5A_0x6E	00
    0x6F	Rx/Tx 5A_0x6F	00
    0x70	Rx/Tx 5A_0x70	03
    0x71	Rx/Tx 5A_0x71	20
    0x72	Rx/Tx 5A_0x72	00
    0x73	Rx/Tx 5A_0x73	00
    0x74	Rx/Tx 5A_0x74	00
    0x75	Rx/Tx 5A_0x75	00
    0x76	Rx/Tx 5A_0x76	22
    0x77	Rx/Tx 5A_0x77	1A
    0x78	Rx/Tx 5A_0x78	00
    0x79	Rx/Tx 5A_0x79	10
    0x7A	Rx/Tx 5A_0x7A	00
    0x7B	Rx/Tx 5A_0x7B	00
    0x7C	Rx/Tx 5A_0x7C	00
    0x7D	Rx/Tx 5A_0x7D	48
    0x7E	Rx/Tx 5A_0x7E	13
    0x7F	Rx/Tx 5A_0x7F	3A
    0x80	Rx/Tx 5A_0x80	00
    0x81	Rx/Tx 5A_0x81	E4
    0x82	Rx/Tx 5A_0x82	00
    0x83	Rx/Tx 5A_0x83	00
    0x84	Rx/Tx 5A_0x84	00
    0x85	Rx/Tx 5A_0x85	00
    0x86	Rx/Tx 5A_0x86	00
    0x87	Rx/Tx 5A_0x87	00
    0x88	Rx/Tx 5A_0x88	00
    0x89	Rx/Tx 5A_0x89	00
    0x8A	Rx/Tx 5A_0x8A	00
    0x8B	Rx/Tx 5A_0x8B	00
    0x8C	Rx/Tx 5A_0x8C	00
    0x8D	Rx/Tx 5A_0x8D	02
    0x8E	Rx/Tx 5A_0x8E	1C
    0x8F	Rx/Tx 5A_0x8F	00
    0x90	Rx/Tx 5A_0x90	00
    0x91	Rx/Tx 5A_0x91	00
    0x92	Rx/Tx 5A_0x92	00
    0x93	Rx/Tx 5A_0x93	00
    0x94	Rx/Tx 5A_0x94	00
    0x95	Rx/Tx 5A_0x95	00
    0x96	Rx/Tx 5A_0x96	04
    0x97	Rx/Tx 5A_0x97	00
    0x98	Rx/Tx 5A_0x98	3F
    0x99	Rx/Tx 5A_0x99	3F
    0x9A	Rx/Tx 5A_0x9A	3F
    0x9B	Rx/Tx 5A_0x9B	00
    0x0	Rx/Tx 5B_0x00	00
    0x1	Rx/Tx 5B_0x01	00
    0x2	Rx/Tx 5B_0x02	00
    0x3	Rx/Tx 5B_0x03	00
    0x4	Rx/Tx 5B_0x04	01
    0x5	Rx/Tx 5B_0x05	01
    0x6	Rx/Tx 5B_0x06	01
    0x7	Rx/Tx 5B_0x07	01
    0x8	Rx/Tx 5B_0x08	60
    0x9	Rx/Tx 5B_0x09	00
    0xA	Rx/Tx 5B_0x0A	10
    0xB	Rx/Tx 5B_0x0B	6F
    0xC	Rx/Tx 5B_0x0C	08
    0xD	Rx/Tx 5B_0x0D	B4
    0xE	Rx/Tx 5B_0x0E	93
    0xF	Rx/Tx 5B_0x0F	69
    0x10	Rx/Tx 5B_0x10	3A
    0x11	Rx/Tx 5B_0x11	20
    0x12	Rx/Tx 5B_0x12	E0
    0x13	Rx/Tx 5B_0x13	90
    0x14	Rx/Tx 5B_0x14	00
    0x15	Rx/Tx 5B_0x15	10
    0x16	Rx/Tx 5B_0x16	7A
    0x17	Rx/Tx 5B_0x17	36
    0x18	Rx/Tx 5B_0x18	40
    0x19	Rx/Tx 5B_0x19	25
    0x1A	Rx/Tx 5B_0x1A	A0
    0x1B	Rx/Tx 5B_0x1B	03
    0x1C	Rx/Tx 5B_0x1C	24
    0x1D	Rx/Tx 5B_0x1D	00
    0x1E	Rx/Tx 5B_0x1E	E9
    0x1F	Rx/Tx 5B_0x1F	55
    0x20	Rx/Tx 5B_0x20	00
    0x21	Rx/Tx 5B_0x21	00
    0x22	Rx/Tx 5B_0x22	00
    0x23	Rx/Tx 5B_0x23	40
    0x24	Rx/Tx 5B_0x24	40
    0x25	Rx/Tx 5B_0x25	00
    0x26	Rx/Tx 5B_0x26	81
    0x27	Rx/Tx 5B_0x27	00
    0x28	Rx/Tx 5B_0x28	00
    0x29	Rx/Tx 5B_0x29	00
    0x2A	Rx/Tx 5B_0x2A	30
    0x2B	Rx/Tx 5B_0x2B	00
    0x2C	Rx/Tx 5B_0x2C	F2
    0x2D	Rx/Tx 5B_0x2D	04
    0x2E	Rx/Tx 5B_0x2E	00
    0x2F	Rx/Tx 5B_0x2F	F6
    0x30	Rx/Tx 5B_0x30	00
    0x31	Rx/Tx 5B_0x31	20
    0x32	Rx/Tx 5B_0x32	11
    0x33	Rx/Tx 5B_0x33	88
    0x34	Rx/Tx 5B_0x34	3F
    0x35	Rx/Tx 5B_0x35	1F
    0x36	Rx/Tx 5B_0x36	30
    0x37	Rx/Tx 5B_0x37	00
    0x38	Rx/Tx 5B_0x38	00
    0x39	Rx/Tx 5B_0x39	00
    0x3A	Rx/Tx 5B_0x3A	A5
    0x3B	Rx/Tx 5B_0x3B	00
    0x3C	Rx/Tx 5B_0x3C	00
    0x3D	Rx/Tx 5B_0x3D	3F
    0x3E	Rx/Tx 5B_0x3E	40
    0x3F	Rx/Tx 5B_0x3F	C0
    0x40	Rx/Tx 5B_0x40	00
    0x41	Rx/Tx 5B_0x41	01
    0x42	Rx/Tx 5B_0x42	04
    0x43	Rx/Tx 5B_0x43	10
    0x44	Rx/Tx 5B_0x44	40
    0x45	Rx/Tx 5B_0x45	08
    0x46	Rx/Tx 5B_0x46	02
    0x47	Rx/Tx 5B_0x47	80
    0x48	Rx/Tx 5B_0x48	03
    0x49	Rx/Tx 5B_0x49	0C
    0x4A	Rx/Tx 5B_0x4A	30
    0x4B	Rx/Tx 5B_0x4B	41
    0x4C	Rx/Tx 5B_0x4C	50
    0x4D	Rx/Tx 5B_0x4D	C0
    0x4E	Rx/Tx 5B_0x4E	60
    0x4F	Rx/Tx 5B_0x4F	90
    0x50	Rx/Tx 5B_0x50	88
    0x51	Rx/Tx 5B_0x51	82
    0x52	Rx/Tx 5B_0x52	A0
    0x53	Rx/Tx 5B_0x53	46
    0x54	Rx/Tx 5B_0x54	52
    0x55	Rx/Tx 5B_0x55	8C
    0x56	Rx/Tx 5B_0x56	B0
    0x57	Rx/Tx 5B_0x57	C8
    0x58	Rx/Tx 5B_0x58	57
    0x59	Rx/Tx 5B_0x59	5D
    0x5A	Rx/Tx 5B_0x5A	69
    0x5B	Rx/Tx 5B_0x5B	75
    0x5C	Rx/Tx 5B_0x5C	D5
    0x5D	Rx/Tx 5B_0x5D	99
    0x5E	Rx/Tx 5B_0x5E	96
    0x5F	Rx/Tx 5B_0x5F	A5
    0x60	Rx/Tx 5B_0x60	B0
    0x61	Rx/Tx 5B_0x61	B2
    0x62	Rx/Tx 5B_0x62	20
    0x63	Rx/Tx 5B_0x63	B1
    0x64	Rx/Tx 5B_0x64	11
    0x65	Rx/Tx 5B_0x65	00
    0x66	Rx/Tx 5B_0x66	00
    0x67	Rx/Tx 5B_0x67	20
    0x68	Rx/Tx 5B_0x68	00
    0x69	Rx/Tx 5B_0x69	0A
    0x6A	Rx/Tx 5B_0x6A	22
    0x6B	Rx/Tx 5B_0x6B	40
    0x6C	Rx/Tx 5B_0x6C	00
    0x6D	Rx/Tx 5B_0x6D	00
    0x6E	Rx/Tx 5B_0x6E	00
    0x6F	Rx/Tx 5B_0x6F	00
    0x70	Rx/Tx 5B_0x70	03
    0x71	Rx/Tx 5B_0x71	20
    0x72	Rx/Tx 5B_0x72	00
    0x73	Rx/Tx 5B_0x73	00
    0x74	Rx/Tx 5B_0x74	00
    0x75	Rx/Tx 5B_0x75	00
    0x76	Rx/Tx 5B_0x76	22
    0x77	Rx/Tx 5B_0x77	1A
    0x78	Rx/Tx 5B_0x78	00
    0x79	Rx/Tx 5B_0x79	10
    0x7A	Rx/Tx 5B_0x7A	00
    0x7B	Rx/Tx 5B_0x7B	00
    0x7C	Rx/Tx 5B_0x7C	00
    0x7D	Rx/Tx 5B_0x7D	48
    0x7E	Rx/Tx 5B_0x7E	13
    0x7F	Rx/Tx 5B_0x7F	3A
    0x80	Rx/Tx 5B_0x80	00
    0x81	Rx/Tx 5B_0x81	E4
    0x82	Rx/Tx 5B_0x82	00
    0x83	Rx/Tx 5B_0x83	00
    0x84	Rx/Tx 5B_0x84	08
    0x85	Rx/Tx 5B_0x85	00
    0x86	Rx/Tx 5B_0x86	00
    0x87	Rx/Tx 5B_0x87	00
    0x88	Rx/Tx 5B_0x88	00
    0x89	Rx/Tx 5B_0x89	00
    0x8A	Rx/Tx 5B_0x8A	1B
    0x8B	Rx/Tx 5B_0x8B	00
    0x8C	Rx/Tx 5B_0x8C	00
    0x8D	Rx/Tx 5B_0x8D	02
    0x8E	Rx/Tx 5B_0x8E	1C
    0x8F	Rx/Tx 5B_0x8F	00
    0x90	Rx/Tx 5B_0x90	00
    0x91	Rx/Tx 5B_0x91	00
    0x92	Rx/Tx 5B_0x92	00
    0x93	Rx/Tx 5B_0x93	00
    0x94	Rx/Tx 5B_0x94	00
    0x95	Rx/Tx 5B_0x95	00
    0x96	Rx/Tx 5B_0x96	04
    0x97	Rx/Tx 5B_0x97	00
    0x98	Rx/Tx 5B_0x98	3F
    0x99	Rx/Tx 5B_0x99	3F
    0x9A	Rx/Tx 5B_0x9A	3F
    0x9B	Rx/Tx 5B_0x9B	00
    0x0	Rx/Tx 6A_0x00	00
    0x1	Rx/Tx 6A_0x01	00
    0x2	Rx/Tx 6A_0x02	00
    0x3	Rx/Tx 6A_0x03	00
    0x4	Rx/Tx 6A_0x04	01
    0x5	Rx/Tx 6A_0x05	01
    0x6	Rx/Tx 6A_0x06	01
    0x7	Rx/Tx 6A_0x07	01
    0x8	Rx/Tx 6A_0x08	60
    0x9	Rx/Tx 6A_0x09	00
    0xA	Rx/Tx 6A_0x0A	10
    0xB	Rx/Tx 6A_0x0B	6F
    0xC	Rx/Tx 6A_0x0C	08
    0xD	Rx/Tx 6A_0x0D	B4
    0xE	Rx/Tx 6A_0x0E	93
    0xF	Rx/Tx 6A_0x0F	69
    0x10	Rx/Tx 6A_0x10	3A
    0x11	Rx/Tx 6A_0x11	20
    0x12	Rx/Tx 6A_0x12	E0
    0x13	Rx/Tx 6A_0x13	90
    0x14	Rx/Tx 6A_0x14	00
    0x15	Rx/Tx 6A_0x15	10
    0x16	Rx/Tx 6A_0x16	7A
    0x17	Rx/Tx 6A_0x17	36
    0x18	Rx/Tx 6A_0x18	40
    0x19	Rx/Tx 6A_0x19	25
    0x1A	Rx/Tx 6A_0x1A	A0
    0x1B	Rx/Tx 6A_0x1B	03
    0x1C	Rx/Tx 6A_0x1C	24
    0x1D	Rx/Tx 6A_0x1D	00
    0x1E	Rx/Tx 6A_0x1E	E9
    0x1F	Rx/Tx 6A_0x1F	55
    0x20	Rx/Tx 6A_0x20	00
    0x21	Rx/Tx 6A_0x21	00
    0x22	Rx/Tx 6A_0x22	00
    0x23	Rx/Tx 6A_0x23	40
    0x24	Rx/Tx 6A_0x24	40
    0x25	Rx/Tx 6A_0x25	00
    0x26	Rx/Tx 6A_0x26	00
    0x27	Rx/Tx 6A_0x27	00
    0x28	Rx/Tx 6A_0x28	00
    0x29	Rx/Tx 6A_0x29	00
    0x2A	Rx/Tx 6A_0x2A	30
    0x2B	Rx/Tx 6A_0x2B	00
    0x2C	Rx/Tx 6A_0x2C	F2
    0x2D	Rx/Tx 6A_0x2D	04
    0x2E	Rx/Tx 6A_0x2E	00
    0x2F	Rx/Tx 6A_0x2F	F6
    0x30	Rx/Tx 6A_0x30	00
    0x31	Rx/Tx 6A_0x31	20
    0x32	Rx/Tx 6A_0x32	11
    0x33	Rx/Tx 6A_0x33	88
    0x34	Rx/Tx 6A_0x34	3F
    0x35	Rx/Tx 6A_0x35	1F
    0x36	Rx/Tx 6A_0x36	30
    0x37	Rx/Tx 6A_0x37	00
    0x38	Rx/Tx 6A_0x38	00
    0x39	Rx/Tx 6A_0x39	00
    0x3A	Rx/Tx 6A_0x3A	A5
    0x3B	Rx/Tx 6A_0x3B	00
    0x3C	Rx/Tx 6A_0x3C	00
    0x3D	Rx/Tx 6A_0x3D	3F
    0x3E	Rx/Tx 6A_0x3E	40
    0x3F	Rx/Tx 6A_0x3F	C0
    0x40	Rx/Tx 6A_0x40	00
    0x41	Rx/Tx 6A_0x41	01
    0x42	Rx/Tx 6A_0x42	04
    0x43	Rx/Tx 6A_0x43	10
    0x44	Rx/Tx 6A_0x44	40
    0x45	Rx/Tx 6A_0x45	08
    0x46	Rx/Tx 6A_0x46	02
    0x47	Rx/Tx 6A_0x47	80
    0x48	Rx/Tx 6A_0x48	03
    0x49	Rx/Tx 6A_0x49	0C
    0x4A	Rx/Tx 6A_0x4A	30
    0x4B	Rx/Tx 6A_0x4B	41
    0x4C	Rx/Tx 6A_0x4C	50
    0x4D	Rx/Tx 6A_0x4D	C0
    0x4E	Rx/Tx 6A_0x4E	60
    0x4F	Rx/Tx 6A_0x4F	90
    0x50	Rx/Tx 6A_0x50	88
    0x51	Rx/Tx 6A_0x51	82
    0x52	Rx/Tx 6A_0x52	A0
    0x53	Rx/Tx 6A_0x53	46
    0x54	Rx/Tx 6A_0x54	52
    0x55	Rx/Tx 6A_0x55	8C
    0x56	Rx/Tx 6A_0x56	B0
    0x57	Rx/Tx 6A_0x57	C8
    0x58	Rx/Tx 6A_0x58	57
    0x59	Rx/Tx 6A_0x59	5D
    0x5A	Rx/Tx 6A_0x5A	69
    0x5B	Rx/Tx 6A_0x5B	75
    0x5C	Rx/Tx 6A_0x5C	D5
    0x5D	Rx/Tx 6A_0x5D	99
    0x5E	Rx/Tx 6A_0x5E	96
    0x5F	Rx/Tx 6A_0x5F	A5
    0x60	Rx/Tx 6A_0x60	B0
    0x61	Rx/Tx 6A_0x61	B2
    0x62	Rx/Tx 6A_0x62	20
    0x63	Rx/Tx 6A_0x63	B1
    0x64	Rx/Tx 6A_0x64	11
    0x65	Rx/Tx 6A_0x65	00
    0x66	Rx/Tx 6A_0x66	00
    0x67	Rx/Tx 6A_0x67	20
    0x68	Rx/Tx 6A_0x68	00
    0x69	Rx/Tx 6A_0x69	0A
    0x6A	Rx/Tx 6A_0x6A	22
    0x6B	Rx/Tx 6A_0x6B	40
    0x6C	Rx/Tx 6A_0x6C	00
    0x6D	Rx/Tx 6A_0x6D	00
    0x6E	Rx/Tx 6A_0x6E	00
    0x6F	Rx/Tx 6A_0x6F	00
    0x70	Rx/Tx 6A_0x70	03
    0x71	Rx/Tx 6A_0x71	20
    0x72	Rx/Tx 6A_0x72	00
    0x73	Rx/Tx 6A_0x73	00
    0x74	Rx/Tx 6A_0x74	00
    0x75	Rx/Tx 6A_0x75	00
    0x76	Rx/Tx 6A_0x76	22
    0x77	Rx/Tx 6A_0x77	1A
    0x78	Rx/Tx 6A_0x78	00
    0x79	Rx/Tx 6A_0x79	10
    0x7A	Rx/Tx 6A_0x7A	00
    0x7B	Rx/Tx 6A_0x7B	00
    0x7C	Rx/Tx 6A_0x7C	00
    0x7D	Rx/Tx 6A_0x7D	48
    0x7E	Rx/Tx 6A_0x7E	13
    0x7F	Rx/Tx 6A_0x7F	3A
    0x80	Rx/Tx 6A_0x80	00
    0x81	Rx/Tx 6A_0x81	E4
    0x82	Rx/Tx 6A_0x82	00
    0x83	Rx/Tx 6A_0x83	00
    0x84	Rx/Tx 6A_0x84	00
    0x85	Rx/Tx 6A_0x85	00
    0x86	Rx/Tx 6A_0x86	00
    0x87	Rx/Tx 6A_0x87	00
    0x88	Rx/Tx 6A_0x88	00
    0x89	Rx/Tx 6A_0x89	00
    0x8A	Rx/Tx 6A_0x8A	14
    0x8B	Rx/Tx 6A_0x8B	00
    0x8C	Rx/Tx 6A_0x8C	00
    0x8D	Rx/Tx 6A_0x8D	02
    0x8E	Rx/Tx 6A_0x8E	1C
    0x8F	Rx/Tx 6A_0x8F	00
    0x90	Rx/Tx 6A_0x90	00
    0x91	Rx/Tx 6A_0x91	00
    0x92	Rx/Tx 6A_0x92	00
    0x93	Rx/Tx 6A_0x93	00
    0x94	Rx/Tx 6A_0x94	00
    0x95	Rx/Tx 6A_0x95	00
    0x96	Rx/Tx 6A_0x96	04
    0x97	Rx/Tx 6A_0x97	00
    0x98	Rx/Tx 6A_0x98	3F
    0x99	Rx/Tx 6A_0x99	3F
    0x9A	Rx/Tx 6A_0x9A	3F
    0x9B	Rx/Tx 6A_0x9B	00
    0x0	Rx/Tx 6B_0x00	00
    0x1	Rx/Tx 6B_0x01	00
    0x2	Rx/Tx 6B_0x02	00
    0x3	Rx/Tx 6B_0x03	00
    0x4	Rx/Tx 6B_0x04	01
    0x5	Rx/Tx 6B_0x05	01
    0x6	Rx/Tx 6B_0x06	01
    0x7	Rx/Tx 6B_0x07	01
    0x8	Rx/Tx 6B_0x08	60
    0x9	Rx/Tx 6B_0x09	00
    0xA	Rx/Tx 6B_0x0A	10
    0xB	Rx/Tx 6B_0x0B	6F
    0xC	Rx/Tx 6B_0x0C	08
    0xD	Rx/Tx 6B_0x0D	B4
    0xE	Rx/Tx 6B_0x0E	93
    0xF	Rx/Tx 6B_0x0F	69
    0x10	Rx/Tx 6B_0x10	3A
    0x11	Rx/Tx 6B_0x11	20
    0x12	Rx/Tx 6B_0x12	E0
    0x13	Rx/Tx 6B_0x13	90
    0x14	Rx/Tx 6B_0x14	00
    0x15	Rx/Tx 6B_0x15	10
    0x16	Rx/Tx 6B_0x16	7A
    0x17	Rx/Tx 6B_0x17	36
    0x18	Rx/Tx 6B_0x18	40
    0x19	Rx/Tx 6B_0x19	25
    0x1A	Rx/Tx 6B_0x1A	A0
    0x1B	Rx/Tx 6B_0x1B	03
    0x1C	Rx/Tx 6B_0x1C	24
    0x1D	Rx/Tx 6B_0x1D	00
    0x1E	Rx/Tx 6B_0x1E	E9
    0x1F	Rx/Tx 6B_0x1F	55
    0x20	Rx/Tx 6B_0x20	00
    0x21	Rx/Tx 6B_0x21	00
    0x22	Rx/Tx 6B_0x22	00
    0x23	Rx/Tx 6B_0x23	40
    0x24	Rx/Tx 6B_0x24	40
    0x25	Rx/Tx 6B_0x25	20
    0x26	Rx/Tx 6B_0x26	00
    0x27	Rx/Tx 6B_0x27	00
    0x28	Rx/Tx 6B_0x28	00
    0x29	Rx/Tx 6B_0x29	00
    0x2A	Rx/Tx 6B_0x2A	30
    0x2B	Rx/Tx 6B_0x2B	00
    0x2C	Rx/Tx 6B_0x2C	F2
    0x2D	Rx/Tx 6B_0x2D	04
    0x2E	Rx/Tx 6B_0x2E	00
    0x2F	Rx/Tx 6B_0x2F	F6
    0x30	Rx/Tx 6B_0x30	00
    0x31	Rx/Tx 6B_0x31	20
    0x32	Rx/Tx 6B_0x32	11
    0x33	Rx/Tx 6B_0x33	88
    0x34	Rx/Tx 6B_0x34	3F
    0x35	Rx/Tx 6B_0x35	1F
    0x36	Rx/Tx 6B_0x36	30
    0x37	Rx/Tx 6B_0x37	00
    0x38	Rx/Tx 6B_0x38	00
    0x39	Rx/Tx 6B_0x39	00
    0x3A	Rx/Tx 6B_0x3A	A5
    0x3B	Rx/Tx 6B_0x3B	00
    0x3C	Rx/Tx 6B_0x3C	00
    0x3D	Rx/Tx 6B_0x3D	3F
    0x3E	Rx/Tx 6B_0x3E	40
    0x3F	Rx/Tx 6B_0x3F	C0
    0x40	Rx/Tx 6B_0x40	00
    0x41	Rx/Tx 6B_0x41	01
    0x42	Rx/Tx 6B_0x42	04
    0x43	Rx/Tx 6B_0x43	10
    0x44	Rx/Tx 6B_0x44	40
    0x45	Rx/Tx 6B_0x45	08
    0x46	Rx/Tx 6B_0x46	02
    0x47	Rx/Tx 6B_0x47	80
    0x48	Rx/Tx 6B_0x48	03
    0x49	Rx/Tx 6B_0x49	0C
    0x4A	Rx/Tx 6B_0x4A	30
    0x4B	Rx/Tx 6B_0x4B	41
    0x4C	Rx/Tx 6B_0x4C	50
    0x4D	Rx/Tx 6B_0x4D	C0
    0x4E	Rx/Tx 6B_0x4E	60
    0x4F	Rx/Tx 6B_0x4F	90
    0x50	Rx/Tx 6B_0x50	88
    0x51	Rx/Tx 6B_0x51	82
    0x52	Rx/Tx 6B_0x52	A0
    0x53	Rx/Tx 6B_0x53	46
    0x54	Rx/Tx 6B_0x54	52
    0x55	Rx/Tx 6B_0x55	8C
    0x56	Rx/Tx 6B_0x56	B0
    0x57	Rx/Tx 6B_0x57	C8
    0x58	Rx/Tx 6B_0x58	57
    0x59	Rx/Tx 6B_0x59	5D
    0x5A	Rx/Tx 6B_0x5A	69
    0x5B	Rx/Tx 6B_0x5B	75
    0x5C	Rx/Tx 6B_0x5C	D5
    0x5D	Rx/Tx 6B_0x5D	99
    0x5E	Rx/Tx 6B_0x5E	96
    0x5F	Rx/Tx 6B_0x5F	A5
    0x60	Rx/Tx 6B_0x60	B0
    0x61	Rx/Tx 6B_0x61	B2
    0x62	Rx/Tx 6B_0x62	20
    0x63	Rx/Tx 6B_0x63	B1
    0x64	Rx/Tx 6B_0x64	11
    0x65	Rx/Tx 6B_0x65	00
    0x66	Rx/Tx 6B_0x66	00
    0x67	Rx/Tx 6B_0x67	20
    0x68	Rx/Tx 6B_0x68	00
    0x69	Rx/Tx 6B_0x69	0A
    0x6A	Rx/Tx 6B_0x6A	22
    0x6B	Rx/Tx 6B_0x6B	40
    0x6C	Rx/Tx 6B_0x6C	00
    0x6D	Rx/Tx 6B_0x6D	00
    0x6E	Rx/Tx 6B_0x6E	00
    0x6F	Rx/Tx 6B_0x6F	00
    0x70	Rx/Tx 6B_0x70	03
    0x71	Rx/Tx 6B_0x71	20
    0x72	Rx/Tx 6B_0x72	00
    0x73	Rx/Tx 6B_0x73	00
    0x74	Rx/Tx 6B_0x74	00
    0x75	Rx/Tx 6B_0x75	00
    0x76	Rx/Tx 6B_0x76	22
    0x77	Rx/Tx 6B_0x77	1A
    0x78	Rx/Tx 6B_0x78	00
    0x79	Rx/Tx 6B_0x79	10
    0x7A	Rx/Tx 6B_0x7A	00
    0x7B	Rx/Tx 6B_0x7B	00
    0x7C	Rx/Tx 6B_0x7C	00
    0x7D	Rx/Tx 6B_0x7D	48
    0x7E	Rx/Tx 6B_0x7E	13
    0x7F	Rx/Tx 6B_0x7F	3A
    0x80	Rx/Tx 6B_0x80	00
    0x81	Rx/Tx 6B_0x81	E4
    0x82	Rx/Tx 6B_0x82	00
    0x83	Rx/Tx 6B_0x83	00
    0x84	Rx/Tx 6B_0x84	00
    0x85	Rx/Tx 6B_0x85	00
    0x86	Rx/Tx 6B_0x86	00
    0x87	Rx/Tx 6B_0x87	00
    0x88	Rx/Tx 6B_0x88	00
    0x89	Rx/Tx 6B_0x89	00
    0x8A	Rx/Tx 6B_0x8A	00
    0x8B	Rx/Tx 6B_0x8B	00
    0x8C	Rx/Tx 6B_0x8C	00
    0x8D	Rx/Tx 6B_0x8D	02
    0x8E	Rx/Tx 6B_0x8E	1C
    0x8F	Rx/Tx 6B_0x8F	00
    0x90	Rx/Tx 6B_0x90	00
    0x91	Rx/Tx 6B_0x91	00
    0x92	Rx/Tx 6B_0x92	00
    0x93	Rx/Tx 6B_0x93	00
    0x94	Rx/Tx 6B_0x94	00
    0x95	Rx/Tx 6B_0x95	00
    0x96	Rx/Tx 6B_0x96	04
    0x97	Rx/Tx 6B_0x97	00
    0x98	Rx/Tx 6B_0x98	3F
    0x99	Rx/Tx 6B_0x99	3F
    0x9A	Rx/Tx 6B_0x9A	3F
    0x9B	Rx/Tx 6B_0x9B	00
    0x0	Rx/Tx 7A_0x00	00
    0x1	Rx/Tx 7A_0x01	00
    0x2	Rx/Tx 7A_0x02	00
    0x3	Rx/Tx 7A_0x03	00
    0x4	Rx/Tx 7A_0x04	01
    0x5	Rx/Tx 7A_0x05	01
    0x6	Rx/Tx 7A_0x06	01
    0x7	Rx/Tx 7A_0x07	01
    0x8	Rx/Tx 7A_0x08	60
    0x9	Rx/Tx 7A_0x09	00
    0xA	Rx/Tx 7A_0x0A	10
    0xB	Rx/Tx 7A_0x0B	6F
    0xC	Rx/Tx 7A_0x0C	08
    0xD	Rx/Tx 7A_0x0D	B4
    0xE	Rx/Tx 7A_0x0E	93
    0xF	Rx/Tx 7A_0x0F	69
    0x10	Rx/Tx 7A_0x10	3A
    0x11	Rx/Tx 7A_0x11	20
    0x12	Rx/Tx 7A_0x12	E0
    0x13	Rx/Tx 7A_0x13	90
    0x14	Rx/Tx 7A_0x14	00
    0x15	Rx/Tx 7A_0x15	10
    0x16	Rx/Tx 7A_0x16	7A
    0x17	Rx/Tx 7A_0x17	36
    0x18	Rx/Tx 7A_0x18	40
    0x19	Rx/Tx 7A_0x19	25
    0x1A	Rx/Tx 7A_0x1A	A0
    0x1B	Rx/Tx 7A_0x1B	03
    0x1C	Rx/Tx 7A_0x1C	24
    0x1D	Rx/Tx 7A_0x1D	00
    0x1E	Rx/Tx 7A_0x1E	E9
    0x1F	Rx/Tx 7A_0x1F	55
    0x20	Rx/Tx 7A_0x20	00
    0x21	Rx/Tx 7A_0x21	00
    0x22	Rx/Tx 7A_0x22	00
    0x23	Rx/Tx 7A_0x23	40
    0x24	Rx/Tx 7A_0x24	40
    0x25	Rx/Tx 7A_0x25	00
    0x26	Rx/Tx 7A_0x26	00
    0x27	Rx/Tx 7A_0x27	00
    0x28	Rx/Tx 7A_0x28	00
    0x29	Rx/Tx 7A_0x29	00
    0x2A	Rx/Tx 7A_0x2A	30
    0x2B	Rx/Tx 7A_0x2B	00
    0x2C	Rx/Tx 7A_0x2C	F2
    0x2D	Rx/Tx 7A_0x2D	04
    0x2E	Rx/Tx 7A_0x2E	00
    0x2F	Rx/Tx 7A_0x2F	F6
    0x30	Rx/Tx 7A_0x30	00
    0x31	Rx/Tx 7A_0x31	20
    0x32	Rx/Tx 7A_0x32	11
    0x33	Rx/Tx 7A_0x33	88
    0x34	Rx/Tx 7A_0x34	3F
    0x35	Rx/Tx 7A_0x35	1F
    0x36	Rx/Tx 7A_0x36	30
    0x37	Rx/Tx 7A_0x37	00
    0x38	Rx/Tx 7A_0x38	00
    0x39	Rx/Tx 7A_0x39	00
    0x3A	Rx/Tx 7A_0x3A	A5
    0x3B	Rx/Tx 7A_0x3B	00
    0x3C	Rx/Tx 7A_0x3C	00
    0x3D	Rx/Tx 7A_0x3D	3F
    0x3E	Rx/Tx 7A_0x3E	40
    0x3F	Rx/Tx 7A_0x3F	C0
    0x40	Rx/Tx 7A_0x40	00
    0x41	Rx/Tx 7A_0x41	01
    0x42	Rx/Tx 7A_0x42	04
    0x43	Rx/Tx 7A_0x43	10
    0x44	Rx/Tx 7A_0x44	40
    0x45	Rx/Tx 7A_0x45	08
    0x46	Rx/Tx 7A_0x46	02
    0x47	Rx/Tx 7A_0x47	80
    0x48	Rx/Tx 7A_0x48	03
    0x49	Rx/Tx 7A_0x49	0C
    0x4A	Rx/Tx 7A_0x4A	30
    0x4B	Rx/Tx 7A_0x4B	41
    0x4C	Rx/Tx 7A_0x4C	50
    0x4D	Rx/Tx 7A_0x4D	C0
    0x4E	Rx/Tx 7A_0x4E	60
    0x4F	Rx/Tx 7A_0x4F	90
    0x50	Rx/Tx 7A_0x50	88
    0x51	Rx/Tx 7A_0x51	82
    0x52	Rx/Tx 7A_0x52	A0
    0x53	Rx/Tx 7A_0x53	46
    0x54	Rx/Tx 7A_0x54	52
    0x55	Rx/Tx 7A_0x55	8C
    0x56	Rx/Tx 7A_0x56	B0
    0x57	Rx/Tx 7A_0x57	C8
    0x58	Rx/Tx 7A_0x58	57
    0x59	Rx/Tx 7A_0x59	5D
    0x5A	Rx/Tx 7A_0x5A	69
    0x5B	Rx/Tx 7A_0x5B	75
    0x5C	Rx/Tx 7A_0x5C	D5
    0x5D	Rx/Tx 7A_0x5D	99
    0x5E	Rx/Tx 7A_0x5E	96
    0x5F	Rx/Tx 7A_0x5F	A5
    0x60	Rx/Tx 7A_0x60	B0
    0x61	Rx/Tx 7A_0x61	B2
    0x62	Rx/Tx 7A_0x62	20
    0x63	Rx/Tx 7A_0x63	B1
    0x64	Rx/Tx 7A_0x64	11
    0x65	Rx/Tx 7A_0x65	00
    0x66	Rx/Tx 7A_0x66	00
    0x67	Rx/Tx 7A_0x67	20
    0x68	Rx/Tx 7A_0x68	00
    0x69	Rx/Tx 7A_0x69	0A
    0x6A	Rx/Tx 7A_0x6A	22
    0x6B	Rx/Tx 7A_0x6B	40
    0x6C	Rx/Tx 7A_0x6C	00
    0x6D	Rx/Tx 7A_0x6D	00
    0x6E	Rx/Tx 7A_0x6E	00
    0x6F	Rx/Tx 7A_0x6F	00
    0x70	Rx/Tx 7A_0x70	03
    0x71	Rx/Tx 7A_0x71	20
    0x72	Rx/Tx 7A_0x72	00
    0x73	Rx/Tx 7A_0x73	00
    0x74	Rx/Tx 7A_0x74	00
    0x75	Rx/Tx 7A_0x75	00
    0x76	Rx/Tx 7A_0x76	22
    0x77	Rx/Tx 7A_0x77	1A
    0x78	Rx/Tx 7A_0x78	00
    0x79	Rx/Tx 7A_0x79	10
    0x7A	Rx/Tx 7A_0x7A	00
    0x7B	Rx/Tx 7A_0x7B	00
    0x7C	Rx/Tx 7A_0x7C	00
    0x7D	Rx/Tx 7A_0x7D	48
    0x7E	Rx/Tx 7A_0x7E	13
    0x7F	Rx/Tx 7A_0x7F	3A
    0x80	Rx/Tx 7A_0x80	00
    0x81	Rx/Tx 7A_0x81	E4
    0x82	Rx/Tx 7A_0x82	00
    0x83	Rx/Tx 7A_0x83	00
    0x84	Rx/Tx 7A_0x84	00
    0x85	Rx/Tx 7A_0x85	00
    0x86	Rx/Tx 7A_0x86	00
    0x87	Rx/Tx 7A_0x87	00
    0x88	Rx/Tx 7A_0x88	00
    0x89	Rx/Tx 7A_0x89	00
    0x8A	Rx/Tx 7A_0x8A	16
    0x8B	Rx/Tx 7A_0x8B	00
    0x8C	Rx/Tx 7A_0x8C	00
    0x8D	Rx/Tx 7A_0x8D	02
    0x8E	Rx/Tx 7A_0x8E	1C
    0x8F	Rx/Tx 7A_0x8F	00
    0x90	Rx/Tx 7A_0x90	00
    0x91	Rx/Tx 7A_0x91	00
    0x92	Rx/Tx 7A_0x92	00
    0x93	Rx/Tx 7A_0x93	00
    0x94	Rx/Tx 7A_0x94	00
    0x95	Rx/Tx 7A_0x95	00
    0x96	Rx/Tx 7A_0x96	04
    0x97	Rx/Tx 7A_0x97	00
    0x98	Rx/Tx 7A_0x98	3F
    0x99	Rx/Tx 7A_0x99	3F
    0x9A	Rx/Tx 7A_0x9A	3F
    0x9B	Rx/Tx 7A_0x9B	00
    0x0	Rx/Tx 7B_0x00	00
    0x1	Rx/Tx 7B_0x01	00
    0x2	Rx/Tx 7B_0x02	00
    0x3	Rx/Tx 7B_0x03	00
    0x4	Rx/Tx 7B_0x04	01
    0x5	Rx/Tx 7B_0x05	01
    0x6	Rx/Tx 7B_0x06	01
    0x7	Rx/Tx 7B_0x07	01
    0x8	Rx/Tx 7B_0x08	60
    0x9	Rx/Tx 7B_0x09	00
    0xA	Rx/Tx 7B_0x0A	10
    0xB	Rx/Tx 7B_0x0B	6F
    0xC	Rx/Tx 7B_0x0C	08
    0xD	Rx/Tx 7B_0x0D	B4
    0xE	Rx/Tx 7B_0x0E	93
    0xF	Rx/Tx 7B_0x0F	69
    0x10	Rx/Tx 7B_0x10	3A
    0x11	Rx/Tx 7B_0x11	20
    0x12	Rx/Tx 7B_0x12	E0
    0x13	Rx/Tx 7B_0x13	90
    0x14	Rx/Tx 7B_0x14	00
    0x15	Rx/Tx 7B_0x15	10
    0x16	Rx/Tx 7B_0x16	7A
    0x17	Rx/Tx 7B_0x17	36
    0x18	Rx/Tx 7B_0x18	40
    0x19	Rx/Tx 7B_0x19	25
    0x1A	Rx/Tx 7B_0x1A	A0
    0x1B	Rx/Tx 7B_0x1B	03
    0x1C	Rx/Tx 7B_0x1C	24
    0x1D	Rx/Tx 7B_0x1D	00
    0x1E	Rx/Tx 7B_0x1E	E9
    0x1F	Rx/Tx 7B_0x1F	55
    0x20	Rx/Tx 7B_0x20	00
    0x21	Rx/Tx 7B_0x21	00
    0x22	Rx/Tx 7B_0x22	00
    0x23	Rx/Tx 7B_0x23	40
    0x24	Rx/Tx 7B_0x24	40
    0x25	Rx/Tx 7B_0x25	04
    0x26	Rx/Tx 7B_0x26	08
    0x27	Rx/Tx 7B_0x27	00
    0x28	Rx/Tx 7B_0x28	00
    0x29	Rx/Tx 7B_0x29	00
    0x2A	Rx/Tx 7B_0x2A	30
    0x2B	Rx/Tx 7B_0x2B	00
    0x2C	Rx/Tx 7B_0x2C	F2
    0x2D	Rx/Tx 7B_0x2D	04
    0x2E	Rx/Tx 7B_0x2E	00
    0x2F	Rx/Tx 7B_0x2F	F6
    0x30	Rx/Tx 7B_0x30	00
    0x31	Rx/Tx 7B_0x31	20
    0x32	Rx/Tx 7B_0x32	11
    0x33	Rx/Tx 7B_0x33	88
    0x34	Rx/Tx 7B_0x34	3F
    0x35	Rx/Tx 7B_0x35	1F
    0x36	Rx/Tx 7B_0x36	30
    0x37	Rx/Tx 7B_0x37	00
    0x38	Rx/Tx 7B_0x38	00
    0x39	Rx/Tx 7B_0x39	00
    0x3A	Rx/Tx 7B_0x3A	A5
    0x3B	Rx/Tx 7B_0x3B	00
    0x3C	Rx/Tx 7B_0x3C	00
    0x3D	Rx/Tx 7B_0x3D	3F
    0x3E	Rx/Tx 7B_0x3E	40
    0x3F	Rx/Tx 7B_0x3F	C0
    0x40	Rx/Tx 7B_0x40	00
    0x41	Rx/Tx 7B_0x41	01
    0x42	Rx/Tx 7B_0x42	04
    0x43	Rx/Tx 7B_0x43	10
    0x44	Rx/Tx 7B_0x44	40
    0x45	Rx/Tx 7B_0x45	08
    0x46	Rx/Tx 7B_0x46	02
    0x47	Rx/Tx 7B_0x47	80
    0x48	Rx/Tx 7B_0x48	03
    0x49	Rx/Tx 7B_0x49	0C
    0x4A	Rx/Tx 7B_0x4A	30
    0x4B	Rx/Tx 7B_0x4B	41
    0x4C	Rx/Tx 7B_0x4C	50
    0x4D	Rx/Tx 7B_0x4D	C0
    0x4E	Rx/Tx 7B_0x4E	60
    0x4F	Rx/Tx 7B_0x4F	90
    0x50	Rx/Tx 7B_0x50	88
    0x51	Rx/Tx 7B_0x51	82
    0x52	Rx/Tx 7B_0x52	A0
    0x53	Rx/Tx 7B_0x53	46
    0x54	Rx/Tx 7B_0x54	52
    0x55	Rx/Tx 7B_0x55	8C
    0x56	Rx/Tx 7B_0x56	B0
    0x57	Rx/Tx 7B_0x57	C8
    0x58	Rx/Tx 7B_0x58	57
    0x59	Rx/Tx 7B_0x59	5D
    0x5A	Rx/Tx 7B_0x5A	69
    0x5B	Rx/Tx 7B_0x5B	75
    0x5C	Rx/Tx 7B_0x5C	D5
    0x5D	Rx/Tx 7B_0x5D	99
    0x5E	Rx/Tx 7B_0x5E	96
    0x5F	Rx/Tx 7B_0x5F	A5
    0x60	Rx/Tx 7B_0x60	B0
    0x61	Rx/Tx 7B_0x61	B2
    0x62	Rx/Tx 7B_0x62	20
    0x63	Rx/Tx 7B_0x63	B1
    0x64	Rx/Tx 7B_0x64	11
    0x65	Rx/Tx 7B_0x65	00
    0x66	Rx/Tx 7B_0x66	00
    0x67	Rx/Tx 7B_0x67	20
    0x68	Rx/Tx 7B_0x68	00
    0x69	Rx/Tx 7B_0x69	0A
    0x6A	Rx/Tx 7B_0x6A	22
    0x6B	Rx/Tx 7B_0x6B	40
    0x6C	Rx/Tx 7B_0x6C	00
    0x6D	Rx/Tx 7B_0x6D	00
    0x6E	Rx/Tx 7B_0x6E	00
    0x6F	Rx/Tx 7B_0x6F	00
    0x70	Rx/Tx 7B_0x70	03
    0x71	Rx/Tx 7B_0x71	20
    0x72	Rx/Tx 7B_0x72	00
    0x73	Rx/Tx 7B_0x73	00
    0x74	Rx/Tx 7B_0x74	00
    0x75	Rx/Tx 7B_0x75	00
    0x76	Rx/Tx 7B_0x76	22
    0x77	Rx/Tx 7B_0x77	1A
    0x78	Rx/Tx 7B_0x78	00
    0x79	Rx/Tx 7B_0x79	10
    0x7A	Rx/Tx 7B_0x7A	00
    0x7B	Rx/Tx 7B_0x7B	00
    0x7C	Rx/Tx 7B_0x7C	00
    0x7D	Rx/Tx 7B_0x7D	48
    0x7E	Rx/Tx 7B_0x7E	13
    0x7F	Rx/Tx 7B_0x7F	3A
    0x80	Rx/Tx 7B_0x80	00
    0x81	Rx/Tx 7B_0x81	E4
    0x82	Rx/Tx 7B_0x82	00
    0x83	Rx/Tx 7B_0x83	00
    0x84	Rx/Tx 7B_0x84	00
    0x85	Rx/Tx 7B_0x85	00
    0x86	Rx/Tx 7B_0x86	00
    0x87	Rx/Tx 7B_0x87	00
    0x88	Rx/Tx 7B_0x88	00
    0x89	Rx/Tx 7B_0x89	00
    0x8A	Rx/Tx 7B_0x8A	45
    0x8B	Rx/Tx 7B_0x8B	00
    0x8C	Rx/Tx 7B_0x8C	00
    0x8D	Rx/Tx 7B_0x8D	02
    0x8E	Rx/Tx 7B_0x8E	1C
    0x8F	Rx/Tx 7B_0x8F	00
    0x90	Rx/Tx 7B_0x90	00
    0x91	Rx/Tx 7B_0x91	00
    0x92	Rx/Tx 7B_0x92	00
    0x93	Rx/Tx 7B_0x93	00
    0x94	Rx/Tx 7B_0x94	00
    0x95	Rx/Tx 7B_0x95	00
    0x96	Rx/Tx 7B_0x96	04
    0x97	Rx/Tx 7B_0x97	00
    0x98	Rx/Tx 7B_0x98	3F
    0x99	Rx/Tx 7B_0x99	3F
    0x9A	Rx/Tx 7B_0x9A	3F
    0x9B	Rx/Tx 7B_0x9B	00
