I am setting some of the mode pins on the ONET4201LD (specifically the fault mode pin) and the datasheet says to tie this to VCC. or to GND. My question is, can I tie this pin up to VCC with a pull up resistor (4.7K) or is a direct connection to VCC required? I like putting pull-ups when a pin is tied. This gives me a way of disconnecting the pin after the board has been fabricated (flexibility).
Thank you,
Mike Nycz
