10G TIA support low cut off frequency 5kHz function.
Hi Sir,
our customer look for 10G TIA support low cut off frequency 5kHz function.
Does TI have this solution or any plan?
Hugo
  • Hi Sir,
    May I have your support for check this question?
    Hugo
  • In reply to Hugo Liu:
    Hi Hugo,
    For clarification, are you looking for a part that has a high pass response with a 5kHz cut off, or are you referring to the power supply filtering?
    Jacob
    Jacob Freet
    High Speed Amplifiers
  • In reply to Jacob Freet:
    Hello ,Jacob,
    Could you please recommend 12G TIA (Transimpedance Amplifiers) for 12G-SDI Video SFP?
    Spec requirement as below is the best.
    Data rate :270M~12Gbps
    Overload: better than 0dBm
    Sensitivity: better than -14dBm
    Low frequency cut off <1kHz
    If you have 10G TIA to meet Low frequency cut off <1kHz, it is also ok.
    Thank you.
