Other Parts Discussed in Thread: ONET1131EC
Where is the ONET1130EC GUI located?
Hi Scott,
I have shared the ONET1131EC EVM GUI files to Josh Conn internally. He will send them to you soon.
Thank you for your patience, the EVM kit somehow missed the CD in it, which is unusual.
Please let me know if you have issues running the software once you receive it.
Sri
Hi Scott,
Please remove the ONET1131EC part and replace it with a new sample- Josh can help you get a new ONET1131EC sample.
As long as the USB - I2C digital interface is working and the TEC is not open circuit, the EVM board should be good. The optical EVM is designed to work with the TOSA attached, so please solder back the TOSA on the EVM board carefully.
Please follow the setup instructions provided in he userguide of the ONET1131EC EVM while using the EVM.
Sri
Thank you for the detailed and professional help. The component was changed.
Can you please send me the specifications for the TOSA? I am mainly looking for the specifications of the diodes and pin-outs.
-Scott Jenney
Hi Scott,
Any XMD MSA-compatible 10Gbps EML TOSA will work. You can refer to the following two examples for basic specs and pin-out:
http://www.mitsubishielectric.com/news/2011/1018.html
Please let me know for any further questions.
Thanks!
Sri
Hi Scott,
I guess you're using the electrical EVM, correct? Are you able to see any output from the MOD outputs (MOD+/-) at least?
Also, please check the I_bias_monitor from the ADC option in the EVM GUI core configuration page, and see if you're reading a meaningful value in the corresponding register output.
If you don't read a non-zero, meaningful value, you may want to replace the ONET1130EC sample and try.
Sri
Hi Nicholas,
Sorry to hear that you did not receive the software CD along with your EVM kit. Can you please email us at onet1130ex_evm@list.ti.com with your full details (company name, address, contact details and date of your orders etc.,)? We will contact your local sales representative and arrange for the software right away.
Sorry again for the inconvenience, and thank you for your interest in TI devices. We look forward to providing you with the best support.
Sri
