Hi Support,
Any recommendation for TIA devices for Video application? ONET8551?
Looking for low frequency cut off <5KHz TIA for Video used to fit different module designed customers. Any recommendation?
Thanks.
Hi Support,
Thanks.
What is the maximum bandwidth requirement for the device and what type of signal is it sending? Will it be receiving NRZ?
With a 1.5 GHz bandwidth you will get better performance with a lower bit rate amplifier like the ONET2591TA. However, I will caution that all of the ONET TIA's are sold in die only form without a package, so you will need to be able to accommodate bonding the die onto a substrate.
Jacob
