• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » LMH0341 and LMH0394 Connection
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 4 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 5 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 11 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Ran Feldman
Posted by Ran Feldman
on Mar 21 2012 03:39 AM
Intellectual360 points
Our customer is using the LMH0394 equalizer connected to LMH0341 deserializer (the distance between two components is about 1cm):
  1. Does ac coupling capacitor at the connection between them? Or can it be left out?
  2. Is there a for need 100 ohm parallel termination between them? Or the internal termination resistor is sufficient?
  3. is there any difference in connection between RX0 to RX1? I intend to use RX0.
Ran
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Nasser Mohammadi
    Posted by Nasser Mohammadi
    on Mar 21 2012 11:02 AM
    Verified Answer
    Verified by Mark Sauerwald88474
    Expert4765 points
    Hi Ran,
    Please below note responses to your questions:
    1). LMH0394 to LMH0341 could be DC or AC coupled. LMH0341 has internal 100 Ohm R between positive and negative differential pair and a weak bias. So you can DC couple or AC couple between these two devices. If you decide to AC couple please use large Cap values(4.7uF or higher) in order to pass pathological video pattern.
    2). No need for external 100 Ohm R since this is already integrated within LMH0341 as mentioned above.
    3). LMH0341 has two inputs: RXIN0 and RXIN1. By grounding RX_MUX_Sel pin you would be able to use RXIN0. Similarly you can pull RX_MUX_SEL high and use RXIN1. As such, you can switch between these inputs if desired(rather than having external switch).
    Regards,,nasser
    Report Abuse
    • Reply
  • Ran Feldman
    on Mar 25 2012 09:55 AM
    Hi Nasser,
    Thanks, another question is regarding the SDALTEVK. In this evaluation kit there are several options for setups.
    Could you please explain how should the EVK be configured in order that a 3G SDI video output will be produced?
    Ran
    Report Abuse
    • Reply
  • Mark Sauerwald88474
    Posted by Mark Sauerwald88474
    on Mar 26 2012 10:06 AM
    Expert5130 points
    The SDALTEVK is plugged in to a host FPGA board with an HSMC connector.   The provided IP includes a pre-compiled image for the Cyclone III development kit, or you can get versions for other host boards.   One you have loaded the software, there is program that you can access with the altera "NIOS2-Terminal" program, which will put the system into various different modes - mode 6 is as a standalone pattern generator where you can select the test pattern to be generated and the video format desired.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
