• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » LMH1983 Video CLock Generator
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 19 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question is not answered
James Josey
Posted by James Josey
on Apr 04 2012 10:51 AM
Prodigy80 points
Excessive Jitter Using National's LMH1983 Video Clock Generator. Only using the differential Clkout1+/- output but currently no I2C access so all CLKouts enabled. Datasheet states: TIE Deterministic Jitter = 250 fs and TIE random jitter = 2.7ps. Using Tektronix MSO72004C oscope (20GHz-100GS/s) measured: TIE Deterministic Jitter = 692 fs and TIE random jitter = 203ps(see attached jpeg image RefClk_27MHZ_r1.jpg). The NO_LOCK output is asserted. PLL1 Mode is in GENLOCK and I have Hsync, Vsync and Field present. It appears that there's a slight time shift in the output clock around 400ps (see attached jpeg image RefCLK_27MHZ_r2.jpg). Currently setting up the I2C interface so I can shut down the other three VCOs and mask the NO_LOCK signals from PLL2-4. Could you please provide any debug tips for this problem? The final 3G HD-SDI signall has twice the amount of jitter thats allowed for SMPTE 424 specification. ]
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Mark Sauerwald88474
    Posted by Mark Sauerwald88474
    on Apr 09 2012 17:18 PM
    Expert5200 points
    James,  measuring sub ps jitter is very tricky - any small impedance discontinuity could account for the fs difference that you are seeing on the DJ, but 203ps of random jitter indicates that something is very wrong.   Your post refers to images, but the images did not seem to come through so I am not sure what they are referring to.   If NO_LOCK is asserted, then the part is not locking to your reference - can you give me details as to the reference that you are supplying to the part - what format is it, and where is it coming from?
    Another thing that I would do is to look at the noise spectrum on a spectrum analyzer.  Often the frequency of the jitter gives you a good clue as to where it is coming from.
    Mark
    Report Abuse
    • Reply
  • James Josey
    on Apr 10 2012 11:12 AM
    Prodigy80 points
    Mark,
    The Hsync and Vsync signals are sourced from an HD Digital Image sensor from Aptina Imaging.  The Hsync (or Line Valid) and Hsync (Frame Valid) are generated and embedded into the Sensor's High Speed Serial Pixel (HiSPI) output Interface using sync codes.  A Lattice FPGA uses a HiSPI Receiver module (Verilog) to recover the pixel clock and Line/Frame Valid signals.  The sensor is configured for 1080P60 (2200 horizontal pixels by 1125 Lines).    At 60 Hz Frame rate using 1125 lines the line rate is (1/60) / 1125 lines = 14.8148 usec.  Now since the horizontal line is blanked for 220 out of the 2200 horizontal pixels, using the pixel rate (tpixel = 6.734ns) the horizontal blank period is 220 * 6.734ns = 1.48148 usec.  The vertical blanking period is 45 lines out of 1125 or 14.8148usec * 45 = 666.66 usec.  Since we're using progressive here the field is zero.  This format code would be #12 on page 10 in the data sheet.  We're not using CLock 2-4 output only clock 1 (27MHz) as the external reference applied to the Aptina Sensor.  The Sensor then creates the pixel clock and line/frame valid signals.
    Report Abuse
    • Reply
    on Apr 10 2012 16:04 PM
    Expert5200 points
    James
    My understanding is that you are using the 27 MHz output clock from the LMH1983 and using that to drive the Aptina sensor - the Aptina sensor will multiply this up to the 148.5MHz pixel clock rate internally, and then divide the pixel clock rate down to get the H and V outputs - you shouldn't need (or indeed want) to then use these as a reference for the 1983, since they will already be locked to the 27MHz output.   I don't think that you would want to have the LMH1983 in locked mode - but rather allow it to free run.  You can fine tune the frequency by writing to the 0x19 and 0x18 registers.   Regardless, NO_LOCK will be asserted since the LMH1983 is going to be free-running.   If you want the sensor output to be synchronized to a second reference signal, then you can provide the H, V, F signals from the reference signal to the LMH1983, and the sensor output will then be locked to the reference.
    If you want to get a SMPTE 424  signal out, you can use the 148.5MHz clock output from the LMH1983, and it will already be synchronized to your sensor output.
    In looking at the scope shots that you sent to John, I am concerned about the 'hitch' that is on the edges of your clock - this looks like some sort of a reflection, and might indicate that there is an impedance mismatch on the trace  connecting the 27MHz output to the sensor.   That is almost certainly the cause of the unusually high jitter measurements that you are seeing.  It looks like the CLK1 output goes directly to the FPGA - does the FPGA have the 100 Ohm termination resistor internal and enabled?
    Mark
    Report Abuse
    • Reply
  • James Josey
    on Apr 10 2012 18:39 PM
    Prodigy80 points
    Mark,
    No the internal FPGA 100 ohm differential termination is not enabled.  I'm using LVCMOSD33 IO_TYPE and the FPGA software tools won't let me set any differential resistor value?  However on the HiSPI interface (DDR 297MHz) which uses IO_TYPE LVDS25 I can select either 80, 100 or 120 OHMS.  I sent an email to the Lattice FAE to ask how one uses 100 Ohm Differential resistor value when using IO_TYPE = LVCMOSD33.  Maybe I should use the LVDS25 IO_TYPE? We'll see!
    jimj
    Report Abuse
    • Reply
  • James Josey
    on Apr 10 2012 21:59 PM
    Prodigy80 points
    Mark,
    Enabled the LVDS IO type for the differential clock input and then selected 100 Ohm internal input termination.  No change still seeing the jitter on clock.  We still have the LMH1983 in GEN_LOCK mode.  Tommorrow will place in Free run and set the control voltage.
    jimj
    Report Abuse
    • Reply
    on Apr 11 2012 09:15 AM
    Expert5200 points
    JimJ
    Did you notice any difference to the shape of the rising edge on your clock signal after you enabled the 100Ohm termination - there was a little shelf at about the midpoint of the transition.
    Mark
    Report Abuse
    • Reply
  • James Josey
    on Apr 11 2012 15:07 PM
    Prodigy80 points
    Mark,
    I don't see the little shelf at about the midpoint of the transition but the amplitude is cut in half from 2.1V to 920mv (measured differential.  ALso the jitter is significantly reduced.
    With termination;
    Total JItter = 67.2ps; Random jitter 2.8ps(spec 2.7ps); Deterministic JItter = 27.2ps(spec 250fs)
    Without Termination:
    Total JItter = 1641ps; Random jitter 65.7ps(spec 2.7ps); Deterministic JItter = 721ps(spec 250fs)
     IF I run the PLL1 in the free run mode versus Genlock won't I have a significant increase in phase noise leading to more jitter?
    jimj
    Report Abuse
    • Reply
    on Apr 12 2012 11:17 AM
    Expert5200 points
    It looks like properly terminating your clock line has helped quite a bit with your jitter.
    Free run should not increase jitter at all, if the PLL is locked, you can expect noise at a frequency which is below the loop bandwidth of the PLL to track through the part (the loop bandwidth should be set to a frequency below the lowest frequency that you need to worry about), but in free run, the control voltage to the VCXO will be a DC voltage, eliminating that as a noise path to the output.
    Report Abuse
    • Reply
  • James Josey
    on Apr 12 2012 14:37 PM
    Prodigy80 points
    Mark,
    I really think this problem has to do with the fact that the LMH1983 PLL1 is on the GENLOCK mode and since it isn't locking it goes into HOLDOVER by default.  Even after I enabled the 100 ohm termination and saw a significant reduction in the CLKOUT1 jitter, the 3G SDI outputs changed very little.  I can trace the poor jitter performance all the way back to the input differential serial clock (297MHZ) to the Lattice FPGA from sensor.  See the image (screenshot) thats inserted.  It looks like the frequency is wandering back and forth around 400ps.  Could this be from the PLL1 in free run mode and the holdover value changing ever so slightly back and forth?
    jimj
    Report Abuse
    • Reply
    on Apr 12 2012 15:35 PM
    Expert5200 points
    JimJ
    As I understand your system, you CANNOT operate in Genlock mode - Genlock synchronizes PLL1 to an external reference.  In your system, the reference is the H.V.F from your sensor, but the sensor is referenced to the PLL1 output - so the LMH1983 is chasing it's own tail, trying to lock itself to itself, which is only generating jitter and instability.   In your application, I believe that you should run the LMH1983 in free-run or holdover mode, and it will then generate a stable 27MHz clock that you can provide to your sensor, and it will also generate a 148.5 MHz clock which will be locked to the 27MHz clock.   Since the sensor is being clocked synchronously, the data will be aligned with the 148.5 MHz clock.
    Mark
    Report Abuse
    • Reply
  • James Josey
    on Apr 12 2012 17:00 PM
    Prodigy80 points
    Mark,
    We complete our I2C C function for the LMH1983, added it to our main app running on the embedded processor within the Lattice FPGA.  Now we have PLL1 configured for Free run mode and all the clocks except CLKOUT1 in HiZ mode since we're only using the 27MHz.  The 27MHz reference clock goes through the FPGA to the sensor connector.  I had a sysCLOCK PLL inbetween the input and output ports (to connector).  I removed the PLL because I thought it might be producing the time shifting in the output sensor HiSPI interface serial clock(297MHz) since its not an analog but digital synthesized PLL.  Take a look at the inserted image still getting the clock shifting in time coming out of the aptina .
    You see the sensor has a PLL, Multiplier and Dividers in the clock path between the 27MHz input and the HiSPI serial output(297MHz).
    Report Abuse
    • Reply
    on Apr 12 2012 17:24 PM
    Expert5200 points
    Jim
    I am not familiar enough with the Aptina sensor but one thought would be rather than using the jittery 297MHz output, use the 148.5MHz output from the LMH1983 coming from the CLK2 output - this clock should be phase locked (you can verify by looking at the 297MHz output and the 148.5 MHz outputs on the scope at the same time.)
    Mark
    Report Abuse
    • Reply
  • James Josey
    on Apr 13 2012 10:08 AM
    Prodigy80 points
    Mark,
    Since I've run out of ideas using the external LMH1983 148.5MHz for the pixel clock is a graet one to try.  The HiSPI interface within the Lattice FPGA does have a Dual Port RAM that I can use the external 148.5MHz as the read clock instead of the 297MHz/2.  Great suggestion hope it removes the excessive jitter on the input sclk (297MHz).
    jimj
    Report Abuse
    • Reply
    on Apr 13 2012 10:24 AM
    Expert5200 points
    Let me know how it turns out.
    Thank you
    Mark
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
