• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » DVI to LVDS converter
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 20 hours ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 7 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Appala Raju Gottipilli
Posted by Appala Raju Gottipilli
on Apr 05 2012 10:22 AM
Intellectual280 points
I am Raju from India.
On my embeded board, have DVI out port (from TFP410). I want to connect my LCD panel (LP154W01-A5) to board via DVI to LVDS bridge.
LCD panel configuration is as follows.
Resolution: 1280x800
Color depth: 6 - bit, 262,144 colors
Pixel Pitch: 0.25875 mm × 0.25875 mm
Can I use TI two chip DVI to LVDS bridge (TFP401a-ep as DVI Rx and SN75LVDS83B as LVDS Tx) solution for this.
If yes, could you please provide me the schematic for DVI Rx (TFP401a-ep).
Raju.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • RossE
    Posted by RossE
    on Apr 05 2012 17:22 PM
    Expert7555 points
    Hi Raju, see these documents.  The second one isn't for the TFP401A-EP exactly, but it still applies.
    http://www.ti.com/litv/pdf/slla325
    http://focus.ti.com/lit/an/slla134/slla134.pdf
    RE
    Report Abuse
    • Reply
  • Appala Raju Gottipilli
    on Apr 06 2012 05:44 AM
    Hi RoosE,
    Thanks for the reply.
    I assume, TFP401A-EP and SN75LVDS83B combination will be suitable for my LCD panel (LP154W01-A5).
    Could you please confirm on this.
    Raju
    Report Abuse
    • Reply
  • DHarmon
    Posted by DHarmon
    on Apr 09 2012 09:07 AM
    Genius13985 points
    Appala,
    I will defer to Ross on the technical aspects on if the combination will work with your panel.
    However, I noticed you are using the -EP version of the TFP410A.  This is the enhanced plastic package typical for hi-reliability applications (speced for -55 to +125C operation).  The SN75LVDS83B is only speced for commercail temperature (0 to +70 C) operation so from a "temperature" basis, this seems to be a mis-match,  If you need extended temperature range, the SN65LVDS93A is the same functionality and performance as the LVDS83B, only it is speced for industrial temperature (-45 to +85 C operation).  On the other hand if commercial tempearture is fine, then the TFP410A is available in commercial temperature options for less than half the cost.
    Regards, Dan
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Apr 09 2012 21:40 PM
    Verified Answer
    Verified by Appala Raju Gottipilli
    Expert7555 points
    Raju, I took a look at that panel and it looks fine.  The SN75LVDS83B is commonly used with 1280x800 panels.
    Dan brings up a good point, that you might also consider using the SN65LVDS93A--the same device with a wider temperature range.
    RE
    Report Abuse
    • Reply
    on May 11 2012 09:19 AM
    DVI to LVDS Bridge.pdf
    Hi RossE,
    Thanks for the clarification. I will go with chips which supports commercial temperature range.
    I have prepared schematic for this HDMI/DVI to LVDS Bridge. Here I attached document.
    Could you please review it and provide me your suggestions or modifications.
    Raju.
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    Posted by ELIAS VILLEGAS
    on May 14 2012 11:30 AM
    Mastermind22725 points
    Hello Raju,
    I have reviewed the schematic and found two issues:
    1) /STAG pin on the TFP401A should be tied high.
    2) Since they are selecting OCK_INV=low on the TFP401A, they should also connect CLKSEL=low on the LVDS83B.
    Also, please check the document on the below link for design recommendations.
    Regards.
    http://www.ti.com/lit/an/slla136/slla136.pdf
    Report Abuse
    • Reply
    on May 15 2012 10:12 AM
    Hi ELIAS VILLEGAS,
    1) Connected STAG# to VCC_3.3V through 10K resistor.
    2) Pulled down CLKSEL to ground through 1K resistor.
    I used NXP "PCA9633DP1" IC as Back-light controller.
    Is there any IC from TI, which suitable for the same operation?
    I found "TLC59108F". But, LED control outputs are Active low and I looking for Active high.
    Could you please suggest me the suitable IC from TI.
    Raju.
    Report Abuse
    • Reply
    on May 23 2012 09:15 AM
    Hi ELIAS VILLEGAS,
    May I have any update on this.
    Raju.
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on May 23 2012 16:44 PM
    Hello Raju,
    I am not familiar with back light controllers, but you may want to visit the below link.
    Regards.
    http://www.ti.com/product/ucc25710
    Report Abuse
    • Reply
    on Jul 23 2012 10:28 AM
    Hi ELIAS VILLEGAS,
    After long time, I am posting question on this again. Sorry for the long gap
    From Design recommendation document (http://www.ti.com/lit/an/slla136/slla136.pdf), we should use 22uF, 0.01uF capacitors for DVDD, OVDD, AVDD and PVCC.
    But I used 10uF, 0.01uF capacitors. Based on following document.
    http://www.ti.com/lit/an/slla134/slla134.pdf
    Could you please confirm on this. I mean, need to change my design or I can go with it.
    Raju.
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Jul 23 2012 15:35 PM
    There should be not a big issue.
    Regards.
    Report Abuse
    • Reply
    on Aug 10 2012 06:02 AM
    Hi Elias Villegas,
    What are specification for Ferrite beads which are user to connect to OVDD, AVDD, DVDD and PVDD pins on TFP401A IC.
    Raju.
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Aug 10 2012 14:33 PM
    That usually depends on the power supply used, but the evaluation module for the TFP401 uses a 600ohm, 200mA @100MHz ferrite bead.
    Regards.
    Report Abuse
    • Reply
    on Aug 10 2012 14:45 PM
    I used 3.3V to connect these pins.
    Shell I proceed with 600ohm, 200mA @100MHz ferrite bead?
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Aug 10 2012 14:48 PM
    Well, I was talking more about the quality of the power supply, but yes, I think that ferrite bead should be fine.
    Regards.
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
