• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » DS10CP154A Failsafe Operation
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 6 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is not answered
David Escandon
Posted by David Escandon
on Apr 05 2012 14:14 PM
Expert2145 points
TI Team,
I would like to get some clarification on the operation of the DS10CP154A 4x4 cross-point switch. In particular, I would like to know your recommendations on how to connect unused inputs.
According to Application Note AN-1194, the recommended approach for internally terminated lines is to generate a external bias voltage using a pullup and pulldown resistor of 8k and 5k respectively.
Could you confirm that this is indeed the best approach to handle unused inputs for this device. Thanks.
-David
termination resistance DS10CP154A failsafe
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • John Goldie
    Posted by John Goldie
    on Apr 09 2012 16:58 PM
    Expert4995 points
    Greetings:
    Please advise what you are wanting to protect from, is it preventing noise switching and  additional power in the input, or is the part set up more for say a 4 channel buffer and the concern is over a channel that is enabled without an input applied?  Understanding the use case better, might change the recommendation.
    Since this is a 4x4, the unused channels are ignored by the switch settings.
    If the part is used in SMBus mode, additional functionality is obtained and the smartPWRD mode can be used shutdown the unused IN and OUT stages.
    If there is concern over a unused channel and it is enabled, the external failsafe pull up (plus to VCC) and pull down (minus to GND) can be used.  Select resistors to set the desired VOS and VID.  Typically a 1k up and down will work for most applications.  They can be raised if too strong or too much bias current.
    Best Regards;
    John Goldie
    DPS APPS / SVA
    LVDS
    Report Abuse
    • Reply
  • David Escandon
    on Apr 11 2012 12:50 PM
    Expert2145 points
    John,
    Thanks for your response. I have additional information I would like to provide you to see if your recommendation will change one way or the other.
    • For the unused input, I am looking for information on how/if they should be connected. We will never switch to the unused input (input #2), but I want to understand whether I need to provide any biasing or protection for the unused input. This is really about preventing any damage or unwanted operating conditions.
    •  For the three inputs we are using, two of them are driven from devices whose outputs are high impedance until configured by a processor. I want understand whether we need to provide any protection against this, especially as one of these is input #0, which is selected by default on power up. The concern is really that we will not cause any damage to the part, as this will not be a normal use case, just what happens for a couple of minutes during each boot.
    -David
    failsafe DS10CP154
    Report Abuse
    • Reply
  • Mark Sauerwald88474
    Posted by Mark Sauerwald88474
    on Apr 12 2012 15:42 PM
    Expert5170 points
    David
    The concern with unused inputs on LVDS is that if they are floating near the threshold, then the part will be switching internally which 1) generates noise, and 2) burns extra power.  Given your explanation, I would bias the unused input as John suggested so that it doesn't create issues, and I would not worry about the three other inputs that you are using since having these at the high impedance state is not the normal use case.
    Mark
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
