• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » LMH0387 IBIS Model
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 19 hours ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 7 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
LMH0387 IBIS Model
LMH0387 IBIS Model
This question is not answered
Cliff Yeh
Posted by Cliff Yeh
on Apr 17 2012 02:56 AM
Prodigy10 points
I would like to do the PCB simulation with LMH0387(3G-SDI), but I can't find the IBIS model of LMH0387 on the TI web.
I have an idea that merged LMH0344(3G-SDI Cable EQ) & LMH0302(3G-SDI Cable Driver) pin definition and LMH0387 package data.
But, I not sure that can work well.
Dose any body have another idea to solve this problem?
SDI
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • John Goldie
    Posted by John Goldie
    on Apr 20 2012 00:15 AM
    Expert4995 points
    Greetings -
    Here is a two part response to your question.
    IBIS models single-ended and differential two levels drivers pretty well based on V/I and V/T tables.  It is less intended for Signal Conditioning features such as Equalization and transmit emphasis (Pre-E and De-E).  A new extension of IBIS called IBIS-AMI is starting to get developed and will support more of these advanced features better but it is still young and evolving.  The IBIS model will not represent the integrated SMPTE return loss network well or the adaptive equalizer.  It models the board side IO (not the cable side).
    As a starting point, the two models you noted could be used to represent the differential input to the Cable driver, and also the Equalizer output.  The Driver used in the Equalizer output is adjustable and supports various swing and offset settings.  We do not have a model that covers off of the possible settings at this time.  We do have a preliminary IBIS model that I can send to you that represents the default setting of the LVDS output.  Please email me at:  John.Goldie at TI.com to receive it.
    Best Regards;
    John Goldie
    DPS APPS / SVA
    IBIS model SDI
    Report Abuse
    • Reply
  • Pasqualino Axel Donnini
    Posted by Pasqualino Axel Donnini
    on Oct 04 2012 07:22 AM
    Prodigy20 points
    I was also looking for an IBIS/IBIS-AMI or Hspice model for LMH0387 3G-SDI line driver in order to support Signal Integrity analysis. Since this information is not available on the product folder, could you please provide me any detail to support my analysis or provide the model itself?
    Thank you
    Best Regards
    Report Abuse
    • Reply
  • Nasser Mohammadi
    Posted by Nasser Mohammadi
    on Oct 09 2012 19:03 PM
    Expert4755 points
    Hi Axel,
    Could you please let us know about your application and the environment. Or a block diagram of your design so we can comment on this.
    Regards,,nasser
    Report Abuse
    • Reply
    on Oct 10 2012 06:42 AM
    Prodigy20 points
    Hi Nasser,
    We're currently running a board design for video application. We'd use the LMH0387 3 Gbps HD/SD device to interface input video streams (SMPTE 424M, SMPTE 292M, SMPTE 344M, and SMPTE 259M compliant) toward a processing fpga.
    Due to all this high speed interfaces we need to run since the preliminary layout phase a high speed signal integrity analysis. Are there available any IBIS-AMI model or similar availble to support the analysis?
    Thank you
    Axel
    Report Abuse
    • Reply
  • Nasser Mohammadi
    on Oct 10 2012 19:51 PM
    Expert4755 points
    Hi Axel,
    Please send email to the address below and we can send you the IBIS model:
    nasser.mohammadi@ti.com
    Regards,,nasser
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
