• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » About DS10BR150
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    DAC Essentials: What’s with all this glitch-ing?
    Posted 4 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 6 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
    Engineering the world through Analog
    Posted 11 days ago
    by Hagop Kozanian
    Our lives are surrounded by analog everywhere we go. That’s...
About DS10BR150
About DS10BR150
This question is answered
Mass Garp
Posted by Mass Garp
on Apr 25 2012 04:12 AM
Prodigy210 points
Hallo!
Is DS10BR150 suitable for a 100MHz clock too?
Does DS10BR150 require a failsafe solution or not?
Thank you,
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • John Goldie
    Posted by John Goldie
    on Apr 25 2012 08:37 AM
    Expert4995 points
    Greetings -
    The DS10BR150 is a Buffer Repeater and supports DC to 1 Gbps (500MHz) operation.  100MHz Clock is fine.
    I am checking on the failsafe feature and will advise.  If your source, is removed, powered-off, tri-state, and the DS10BR150 is on, failsafe might be desirable.  That can be done with an external pull up on the Plus, and a external pull down on the Minus, the 100 Ohm is internal.  Set for a nominal common-mode point of the driver you are using also and at +100mV bias.  This way the enabled 'BR150 device will sit at a stable known state, high in this case.
    John Goldie
    DPS APPS / SVA
    LVDS
    Report Abuse
    • Reply
  • Mass Garp
    Posted by Mass Garp
    on Apr 25 2012 09:51 AM
    Prodigy210 points
    Well,
    thanks for the answer, but I haven't understood well how I can develop the failsafe. Which are the values of pull down and pull up resistors?
    Report Abuse
    • Reply
  • John Goldie
    on Apr 27 2012 01:29 AM
    Expert4995 points
    Greetings -
    Here is a link to a detailed AP NOTE on Failsafe (AN-1194) http://www.ti.com/lit/an/snla051b/snla051b.pdf
    If you have a 3.3V rail, try 1.5k pull up (plus to VCC) and 1.5k pull down (minus to GND), and assuming you only have the 100 Ohm across the pair (no source termination). This should give you about 1.1mA bias, and that across the 100 Ohm is 110mV Bias for a known HIGH outputs state.
    John
    LVDS Failsafe
    Report Abuse
    • Reply
  • Mass Garp
    Posted by Mass Garp
    on Apr 27 2012 03:18 AM
    Prodigy210 points
    Yeah,
    I've already read the Application note but it explains all the procedure starting from the knowledge of (look at Fig.1)
    1) VTC of device;
    2) value of Vfsb.
    Now I want to know how I can find the Vfsb, what it is and what is its aim, assuming that VTC is the same also for DS10BR150, since it isn't shown on the datasheet.
    Thank you
    Report Abuse
    • Reply
  • John Goldie
    on Apr 27 2012 09:52 AM
    Verified Answer
    Verified by Mass Garp
    Expert4995 points
    As described in the AN, one wants to set the bias to greater than the threshold, eg >+100mV.  The RX input range is GND to VCC, a typical signal will be offset by a VOS, this could be 1.2V or 1.5V for simplicity.  It depends on your driver you are using.  The bias advised on above sets to 1/2 VCC, you can adjust resistors if you want or start there.  The VTC is close to 0V, and inside the threshold range of -100mV to +100mV.  In the example we set Vsfb to >100mV (approx 110mV).
    John
    Report Abuse
    • Reply
  • Mass Garp
    Posted by Mass Garp
    on Apr 30 2012 04:33 AM
    Prodigy210 points
    Thank you very much, John!
    Do you think that a 50 mV bias Voltage could be enough? So, if the bias is >100 mV we are sure that output logic value is high but this causes more distortion on the signal. Since VTC is about 0V and noise is not so high, I think is better set a 50 mV bias. What's your opinion?
    Report Abuse
    • Reply
  • John Goldie
    on Apr 30 2012 13:45 PM
    Expert4995 points
    Hi -
    Spec wise, biasing to 100mV is needed. (note 100mV comes from the LVDS standard not the part)
    Since the thresholds are very tight, many do bias at >50mV without issue, this will distort less as you note, and is likely fine for the application.
    John Goldie
    DPS APPS / SVA
    LVDS
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
