• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » Looking for a LVDS buffer with Vocm= 0mv to 300mv (user Defined) and Vout=200mv pk-pk
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 3 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is not answered
Surender Sharma
Posted by Surender Sharma
on Apr 25 2012 15:10 PM
Prodigy50 points
Looking for a LVDS buffer with Output common mode voltage of 0mv to 300mv (user Defined). Most LVDS buffers have 1.2V VCM Out. Is there a way to create such a buffer using amplifier circuit and be able to simulate the behavior.  Vout pk-pk is required to be 200 mV. Any feedback will be helpful.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Max Robertson
    Posted by Max Robertson
    on Apr 26 2012 16:32 PM
    Expert5945 points
    AC-Coupling Between Differential LVPECL, LVDS, HSTL, and CML.pdf
    Hi Surender,
    The 1.2-V common mode voltage is part of the LVDS specification, so you aren't likely to find any LVDS devices with such a low common mode.  The simplest solution in my opinion is to just use series capacitors to AC-couple the buffer's differential output and then set the common mode to the desired level by using bias resistors at the receiver.  I have attached a TI application note that goes into more detail on how to AC-couple different types of differential buffers to one another.  In particular, you may want to take a look at Figures 9 though 11, which show three different methods of setting a receive-side common mode.
    Please let me know if you have any questions.
    Max Robertson
    Analog Applications Engineer
    Texas Instruments
    m-robertson@ti.com
    Report Abuse
    • Reply
  • Surender Sharma
    on Apr 26 2012 20:11 PM
    Prodigy50 points
    Dear Max,
    First Thanks for your kind response. Problem is that I must DC Couple in order to carry Link Start DC conditions used by the Receiver. This is a Special receiver which looks for such conditions at 200mV. I was planning on using National/TI's ADC Differential Driver Buffers which allow VOCM to be adjustable to a defined Reference. I am not sure whether they will do the job or not? Any ideas using analog devices will be helpful.
    Surender
    Report Abuse
    • Reply
  • Max Robertson
    on Apr 27 2012 13:11 PM
    Expert5945 points
    Surender,
    I understand - if your system needs to be able to support DC levels then AC-coupling is not a viable option.  Your idea of using an amplifier circuit sounds good to me.  TI has several fully differential amplifiers that allow for the output common mode to be set using a CM bias voltage input.  I recommend contacting our high speed amplifiers team to see if they can provide some suggestions.  Here is their support forum:
    http://e2e.ti.com/support/amplifiers/high_speed_amplifiers/f/10.aspx
    One thing to consider when picking out a device is the bandwidth that is needed.  If you are trying to preserve the rise/fall times of your input signal, a rule of thumb for the minimum bandwidth is 0.35 divided by the 10%-to-90% transition time.  You should also make sure that the amplifier's slew rate is fast enough to handle the data transitions.
    Max Robertson
    Report Abuse
    • Reply
  • Surender Sharma
    on Apr 27 2012 14:52 PM
    Prodigy50 points
    Thanks Max, I have posted it there now. Thanks for your feedback.
    Surender
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
