• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » SN65LVDT41 problems
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 7 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
SN65LVDT41 problems
SN65LVDT41 problems
This question is not answered
Mitesh narothan
Posted by Mitesh narothan
on May 23 2012 01:55 AM
Prodigy30 points
HiTI
I am using a PIC 18F4221 to drive Serial clock into 2 SN65LVDT41's drivers.Are you allowed to drive 1 clock into 2 separate drivers? The clock output only comes through on one of the drivers,although both using the same clock.Do you need to drive the each driver from separate pin(clock) from the PIC or is one clock sufficient?
Regards Mitesh
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Max Robertson
    Posted by Max Robertson
    on May 23 2012 09:36 AM
    Expert5975 points
    Hi Mitesh,
    It should be fine to send a single clock output signal to two of the "D" inputs of the SN65LVDT41.  I would suggest that when routing the traces, you use one trace to route the clock from the MCU to the first driver input, then continue the same trace to the next driver input.  If instead you split the signal into two traces at the MCU's clock output, you may end up with the signal reflecting back from one of the branches and interfering with the other branch.
    If the clock signal needs to be synchronous and phase-aligned to a data bus, then you should make sure that the phase delay through the different path lengths (from MCU to driver 1 and driver 2) is not large enough to violate set-up and hold timing margins.
    I couldn't tell exactly from your message whether you had tried this already and were seeing some issues.  If the clock is not coming out of one of the driver outputs, it would be a good idea to probe both the output and input signals and view them on an oscilloscope.  That way, we can double-check and make sure a valid signal is present on the SN65LVDT41 input.
    Max Robertson
    Analog Applications Engineer
    Texas Instruments
    m-robertson@ti.com
    Report Abuse
    • Reply
  • Mitesh narothan
    on May 24 2012 03:36 AM
    Prodigy30 points
    Hi Max
    Thanks for your reply, are you saying that
    Report Abuse
    • Reply
  • Mitesh narothan
    on May 24 2012 03:44 AM
    Prodigy30 points
    Hi Max
    Thanks for your reply ....Are you saying that on the PCB that if the tracks of the clock on 1 line is too long it will reflect back? I did  check the input and output on the oscilloscope,the input is a 5V clock and output just sits at 3V. Also when i put E2p_Cs low on Pin 7 of U2  i got a high on pin 13 and pin 14 of U2.I would have expected pin 14 to be low and pin 13 to be high,is this correct?I attached a circuit diagram for clarity.
    Regards Mitesh
    Report Abuse
    • Reply
  • Max Robertson
    on May 24 2012 13:56 PM
    Expert5975 points
    Mitesh,
    Yes, past a certain length a PCB trace will start to behave as a transmission line rather than just a lumped electrical net.  This length depends on how fast the signal transitions and how fast it moves along the trace.  If you have a very fast signal or a long trace, then you may need to have some termination in your circuit to prevent reflections from interfering with your signal.
    A bigger concern in this design might be the signaling levels, though.  The LVDT41 driver inputs are designed for 3.3-V LVTTL levels, so a 5-V input voltage may be too high.  Also, I am surprised you are seeing an output level of 3 V.  How are you measuring this signal (single-ended or differential)?  What is the probe impedance, and is there any termination resistance connected in the circuit during the measurement?  The outputs of the LVDT41 should be LVDS levels, meaning a ~340 mV differential swing and a 1.2-V common mode voltage.
    Also, what supply voltage are you using?  I couldn't read it in the image you posted.  Please double-check to make sure it is within the recommended range (3.0 V to 3.6 V).
    You are correct that a high-level voltage on one of the "D" pins should result in a high-level output on the corresponding "Y" output and a low-level output on the corresponding "Z" output.  You mentioned that both output pins were at a high level - is the voltage exactly the same between the two?  What is the voltage level?
    Max Robertson
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
