• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » 1000BASE-BX
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 4 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 5 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 11 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
1000BASE-BX
1000BASE-BX
This question is not answered
Wenjun Huang
Posted by Wenjun Huang
on May 30 2012 11:59 AM
Expert1770 points
Does anyone know how to design for 1000BASE-BX?
Is 1000BASE-BX fiber optic Ethernet? Could it be routed through the backplane, or only come out through fiber optic SFP?
Is there any Ethernet PHY suitable for 1000BASE-BX
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Avi Chami1
    Posted by Avi Chami1
    on May 30 2012 12:29 PM
    Mastermind7385 points
    1000BASE-BX is indeed for fiber communications
    If you need to implement in a backplane, consider using 1000BASE-T which has a long experience on backplanes, including base fabric for ATCA.
    Report Abuse
    • Reply
  • Atul Patel
    Posted by Atul Patel
    on May 30 2012 17:15 PM
    Expert7440 points
    Wenjun,
    As mentioned before, 1000Base-BX is a part of the Gigabit Ethernet standard related to transmission over fiber optic cable.  Typically, the electrical serial data signal feeding the optical module is coming from a serializer/de-serializer (SerDes) device.  If  the SerDes is like TI's TLK2201B (1G Ethernet SerDes)  then the serial output of the SerDes can be driven over a backplane.  SerDes that  incorporate 1000BaseT functionality use multi-level signaling that is more optimal for cable based Ethernet links.
    Atul Patel
    Texas Instruments
    1000Base-BX
    Report Abuse
    • Reply
  • Wenjun Huang
    on May 31 2012 01:00 AM
    Expert1770 points
    Yes. Actually 1000BASE-BX is the Gigabit Ethernet protocol used for openVPX, VITA65, a backplane technology created by VITA committee. I m now trying to design a card that will provide 1000BASE-BX Ethernet that will be routed through the backplane to another card at a different slot.
    Does TI have a recommended Ethernet PHY for 1000BASE-BX?
    Report Abuse
    • Reply
  • Nic Norbert
    Posted by Nic Norbert
    on Jul 12 2012 21:55 PM
    Prodigy20 points
    Hello Atul & Wenjun, what was the solution for 1000BASE-BX on a VITA65 backplane.  Was a TLK2201B used?  Can two modules in a OpenVPX backplane interface directly using 1000BASE-BX without a PHY?  Thank you.
    Report Abuse
    • Reply
  • Wenjun Huang
    on Jul 13 2012 05:09 AM
    Expert1770 points
    I am actually guessing that 1000BASE-X can be used for 1000BASE-BX since they are all fiber standard, uses 4 wires (2 pairs of differential signals) vs 8 wires for 1000BASE-T which is twisted pair interface.
    Report Abuse
    • Reply
  • Nic Norbert
    on Jul 13 2012 14:58 PM
    Prodigy20 points
    Thanks. How should the physical interface be implemented across the backplane?  If they are SerDes, do I need a PHY on the BP or can I run the traces directly between modules? Unlike a traditional 1000BASE-BX interface, I do not intend to route the board traces to an SFP type interface.
    Report Abuse
    • Reply
  • Wenjun Huang
    on Jul 13 2012 22:41 PM
    Expert1770 points
    I think u will have 2 plug-in cards. Use 1000BASE-X PHYs on both the plug-in card. The backplane should be just routing. The connection is:
    MAC -> PHY -> VPX connector -> backplane -> VPX connector -> PHY -> MAC
    Report Abuse
    • Reply
  • Avi Chami1
    on Jul 14 2012 11:27 AM
    I don't know of no case where an active backplane is used. Think that if any of the active elements in the backplane failed, you would have to disassemble all the cards to dismount the backplane, a huge time for system down and an operation that cannot be made at the field anyway. People think it twice even to include resistors or capacitors in a BP... active devices in a BP are 99% out of the question.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
