• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » LMH1982 - PLL Lock Detection
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 2 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 3 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 9 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Kawai
Posted by Kawai
on Jun 15 2012 08:49 AM
Intellectual695 points
I understand the "LOCK_CTRL" (Register 01h) programs the maximum phase error between PLL1's Phase Detector inputs.
Is the allowable phase error set by LOCK_CTRL  based on (Hsync input / reference divider) or (VCXO clock / feedback divider) ?
I am thinking the allowable phase error is based on (Hsync input / reference divider).
If the (VCXO clock / feedback divider) timing is inside +/- allowable phase error, PLL1 is locked.
LMH1982
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Alan Ocampo
    Posted by Alan Ocampo
    on Jun 21 2012 03:27 AM
    Expert4110 points
    Hi Kawai,
    Again, answers to these questions can be found in the following E2E forum post:
    http://e2e.ti.com/support/interface/high_speed_interface/int-high_speed_interface/f/140/p/178827/691492.aspx#691492
    Alan
    Report Abuse
    • Reply
  • Kawai
    Posted by Kawai
    on Jun 21 2012 04:54 AM
    Hi, Alan-san,
    Thanks for your comment, but I could not find the page which you had told me.
    When I jump to the URL, the page shows,
    "Group Not Found
    The requested Group cannot be found."
    Do you need permission to access the page ?
    Kawai
    Report Abuse
    • Reply
  • Alan Ocampo
    on Jun 21 2012 12:03 PM
    Verified Answer
    Verified by Kawai
    Expert4110 points
    Hi Kawai-san,
    Sorry, the link I sent was for an internal website.  Here are some answers to your questions:
    Lock Detection for PLL1
    The phase differences between phase detector (PD) inputs produce different up/down output pulses to drive the charge pump and servo the loop filter / VCXO control voltage.  When the PLL is in a "locked" state, the up/down pulses will present equal pulses with minimum width to the charge pump inputs.  For PLL1, the up/down pulse width is compared against the time window (delay circuit) programmed via LOCK_CTRL register.  When the pulse width is within the window for 3 consecutive PD cycles, then valid lock is indicated (SD_LOCK = 1).  When the pulse width is outside the window for 3 consecutive PD cycles, then loss of lock is indicated (SD_LOCK = 0).
    Lock Detection for PLLs 2/3/4
    The phase differences between the PD inputs produce different up/down output pulses to drive the charge pump and servo the internal loop filter/VCO control voltage.  When the PLL is in a "locked" state, the up/down pulses should be equal with minimal width to charge pump inputs.  For PLLs 2/3/4, the time window is based on 2 inverter delays (~50 ps window, default), but this can be programmed to 6 inverter delays (~150 ps window) via a Reserved register 0x1Ch[bit 2].  Valid register values are 0x00h (2 inverter delays) or 0x04h (6 inverter delays).  When the pulse width is within the window for 3 consecutive PD cycles, then valid lock is indicated (SD_LOCK = 1 for PLL4, or HD_LOCK = 1 for PLLs 2/3).  When the pulse width is outside the window for 3 consecutive PD cycles, then loss of lock is indicated (SD_LOCK = 0 for PLL4, or HD_LOCK = 0 for PLLs 2/3).
    Alan
    Report Abuse
    • Reply
  • Kawai
    Posted by Kawai
    on Jun 27 2012 19:33 PM
    Alan-san,
    Thank you for the answer.
    Kawai
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
