I'm performing measurements on clock source in order to verify if its quality is sufficient to be used as GTX_CLK of TLK2521.
However I'm having difficulties to compare my results to your spec.
The thing is that sla149 application note and TLK2521 datasheet specifies the peak-peak values of jitter. But due to unbounded nature of peak-peak jitter these values are of little use without specifying the period of time over which those values were obtained.
Can you please advise in more details how the peak-peak values were measured?
David.
