• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » DP83849 DUAL vs 2 TLK110's in an EtherCat design
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 3 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 4 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 9 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Bryan Busacco
Posted by Bryan Busacco
on Jul 16 2012 07:33 AM
Expert1205 points
I am looking at the AM3359 for an Ethercat application. The Industrial Communications eval board uses two TLK110's on it.  The TLK110PT offers "RT" ( RealTime )  Deterministic, Low Latency, Low Jitter ) performance.
It looks like the DP83849IF offers the same "RT" features, however when I look at the datasheets for the two devices, I see slightly different wording that makes me wonder if the DP83849 is suited for EtherCat Industrial COmmunications. My assumption, also, is that the DP83849 was not a released product when the AM3359 board was designed?? -or- perhaps, it's just not a good choice to design in.
Does the DP83849 offer the same performance as two TLK110's? Is there a reason NOT to use a DUAL PHY in an EtherCat application?  This could be a nice space saving way to go.
Thank you,
Bryan Busacco.
EtherCAT
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Patrick O'Farrell
    Posted by Patrick O'Farrell
    on Jul 23 2012 15:19 PM
    Expert8745 points
    Bryan,
    The DP83849 and the TLK110 represent different generations of 10/100 Physical layer devices.  While they share many common features, they do have some differences that may be of interest in some EtherCAT implementations.  Relative to EtherCAT, the TLK110 includes some additional features that may be worthy of consideration, for example, fast link loss and fast RX_DV modes.  If this functionality is important for your design, the TLK110 may be well suited to your needs.  If the space savings of using the dual port device is more important, then the DP83849 could be considered.
    Patrick
    Report Abuse
    • Reply
  • Oren Shalita
    Posted by Oren Shalita
    on Jul 25 2012 07:19 AM
    Verified Answer
    Verified by Oren Shalita
    Intellectual980 points
    Hi Brian,
    Further more, we will release in the following weeks a smaller version of the TLK110 in a 32 QFN package - TLK106.
    Some customers, which has space saving requirements as well, find this package size to be sufficient for their system and in some cases even easier to implement (if the 2 ports for example can be spaced to ease system constraints).
    The TLK110 and TLK106 were drafted in preliminary document by Beckhoff as fully compatible with all Ether-CAT requirements (Fast link drop, RX_ERR in idle, TX_CLK phase shift and more).
    We hope to release in the following weeks a dedicated Aplicaiton note describing the compliancy of the TLK110 /106 with EtherCAT requiremnts.
    Oren
    Report Abuse
    • Reply
  • Harson
    Posted by Harson
    on Oct 31 2012 01:11 AM
    Intellectual1740 points
    Hi, Oren
    Would you please share the document you mentioned?
    Could you please also share the Application note to me?
    Thanks!
    Signal Chain AFA from South China
    Report Abuse
    • Reply
  • Oren Shalita
    on Oct 31 2012 03:59 AM
    Verified Answer
    The application note is still not released, however it will be based on the EtherCAT PHY selection guide, describing the compatibility of the TLK110/105/106 PHYs with the EtherCAT PHY implementation guidelines. You can see the TLK devices already described as compatible in this guide.
    The PHY selection guideline can be found in the following link:
    http://www.beckhoff.com/english.asp?download/ethercat_development_products.htm&anker=appnotes
    Look for - 'Application Note PHY Selection Guide'
    Once the TLK EtherCAT compatibility application note will be ready we will publish it on the TLK product page.
    Thanks & Regards,
    Oren
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
