• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » USB3 redriver issue using SN65LVPE502
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 21 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question is not answered
John Sherman
Posted by John Sherman
on Jul 24 2012 08:59 AM
I am working with a customer who is using this part as a redriver in a USB3 cabling system.
I read in the datasheet that the part will enter a sleep mode when no traffic is detected on the input. What is the exact mechanism for doing this? How long does it take to wake up? Is it possible to disable this feature?
John
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • ELIAS VILLEGAS
    Posted by ELIAS VILLEGAS
    on Jul 24 2012 15:37 PM
    Mastermind23085 points
    Hello John,
    the exit time from sleep mode is 100us max.
    Can you tell me where exactly did you see the "traffic" note.
    Regards.
    Report Abuse
    • Reply
  • John Sherman
    on Jul 25 2012 08:52 AM
    Mastermind0 points
    On page 1 of the spec in the description of Low Power Modes, I found the following information.
    RX Detect Mode – When no remote device is connected
    Anytime SN65LVPE502 detects a break in link (i.e., when upstream device is disconnected) or after powerup fails to find a remote device, SN65LVPE502 goes to Rx Detect mode and conserves power by shutting down majority of the internal circuitry. In this mode, input termination for both channels are driven to Hi-Z. In Rx Detect mode device power is <10mW(TYP) or less than 5% of its normal operating power This feature is useful in saving system power in mobile applications like notebook PC where battery life is critical.
    The chip is wired such that it will enter Rx Detect Mode during operation. How long does it take to exit Rx Detect Mode? Is it also 100us?
    John
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Jul 25 2012 13:41 PM
     A USB 3.0 device shall exit from RX.Detect and transition to Polling upon detection of a far-end low-impedance receiver termination RRX-DC as defined in the USB 3.0 Specification.
    If  no far-end termination is detected, then the device shall enter to a subsatate (RX.Detect.Quiet) and wait 12ms before looking again for a far-end termination, after 8 attempts of no detecting a far-end termination (80ms aprox.)the device will drop to USB 2.0
    Regards.
    Report Abuse
    • Reply
  • John Sherman
    on Jul 25 2012 15:53 PM
    Mastermind0 points
    Can you provide more details on how the receiver end of the re-driver chip operates? My understanding is the redriver chip basically "amplifies" the USB signal and reconditions it. The redriver does not receive USB packets and then resend them. Instead, it just passes the USB traffic through the part. Is my understanding correct?
    In my application, the USB host will stop transmitting data at various times. It may stop for many minutes before enabling it's transmitter and sending data. What I am observing is that none of the data makes it through the redriver circuit. I suspect the redriver is in a low power state of some sort. Does this sound plausible. If so, how to get the redriver to operate under these conditions?
    John
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Aug 01 2012 16:52 PM
    John,
    Can you provide your schematics for review?
    Regards.
    Report Abuse
    • Reply
  • John Sherman
    on Aug 02 2012 10:53 AM
    Mastermind0 points
    I am using the SN65LVPE502CP Evaluation Board. I have attached the schematics for that board.
    2703.SN65LVPE502CP_EVM_Schem.pdf
    Report Abuse
    • Reply
  • John Sherman
    on Aug 02 2012 13:14 PM
    Mastermind0 points
    I would like to answer my original question in a different manner.
    If I drive a PRBS-7 pattern into the SN65LVPE502 part, will it receive the pattern and re-transmit it? If the pattern turns off for a long time and is then turned back on, what is the part's behavior?
    Are there limitations in the type of patterns that I can transmit through the SN65LVPE502?
    John
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Aug 03 2012 15:42 PM
    Hello John,
    I'd like to take one of your previous posts first.
    Does your system works normally at the beginning and then after the host is idle for a period of time the re-driver stop working?
    Are you plugging-in VBUS powered devices to the re-driver?
    What I'm trying to discriminate is if your problem is related to the Errata #1 for this device, please go to the below link.
    Also, make sure you are not populating JMP7 and JMP8.
    http://www.ti.com/lit/er/sllz070/sllz070.pdf
    Regards.
    Report Abuse
    • Reply
  • John Sherman
    on Aug 09 2012 10:15 AM
    Mastermind0 points
    Elias,
    My system has some Intellectual Property and I do not feel comfortable providing additional information on a public forum. Is there a private communication channel (i.e. email or phone) that we can use to continue this discussion?
    John
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Aug 09 2012 11:53 AM
    Sure,
    You can email me to elias.villegas@ti.com
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
