• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » DP83848C magnetics
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
DP83848C magnetics
DP83848C magnetics
This question is answered
Kent Suzuki
Posted by Kent Suzuki
on Jul 27 2012 17:28 PM
Prodigy30 points
We’re an engineering consulting firm designing a recording/mixing console for a client.  We’re using the DP83848C PHY chip for this particular 100-BaseTX Ethernet implementation, and while we normally use an Ethernet jack with integrated magnetic that they’ve always used with this IC, we now need to use an EtherCon locking Ethernet jack for this particular high-end-audio console.  These EtherCon (http://www.neutrik.com/en/ethercon/) jacks don’t offer integrated magnetic, so I was wondering if you had a list of approved magnetics to use with the DP83848C.
The client already has a Pulse H1086NL in their database, but I don’t see any other 100-BaseTX magnetics in their system.  Looking at the H1086NL datasheet, it’s connecting to a TREF pin on the Ethernet PHY.  The DP83848C doesn’t have this pin, does it?
Thanks and best regards,
Kent
DP83848C magnetics
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kent Suzuki
    on Jul 27 2012 18:55 PM
    Prodigy30 points
    Here's a follow-up.  One other option the client would like to explore is a standard RJ45 Ethernet jack with integrated magnetics and LED's.  They have such a jack in their database: http://www.belfuse.com/Data/Datasheets/08B0-1X1T-06-F.pdf.  Would this work with the DP83848C?
    Report Abuse
    • Reply
  • Patrick O'Farrell
    Posted by Patrick O'Farrell
    on Aug 01 2012 08:36 AM
    Verified Answer
    Verified by Kent Suzuki
    Expert8715 points
    Kent,
    The Pulse H1086NL magnetics are asymmetric with respect to the TD+/- and RD+/- paths.  The series choke for the RD+/- path is on the device side of the transformer.  The electrical specifications for the magnetics meet or exceed the magnetics requirements for the DP83848, but due to the asymmetry and location of the series chokes, these magnetics would not be an ideal choice for some applications using the DP83848.
    The BelFuse magnetics look like a very good choice.  The series chokes are symmetric and on the cable side.  The electrical specifications shown in the 08B0-1X1T-06-F drawing meet or exceed the magnetics requirements for the DP83848.
    For reference, the magnetics requirements are called out in the Design and Layout Guide for the DP83xxx devices, AN-1469 (Literature Number:  SNLA079C):
    http://www.ti.com/litv/pdf/snla079c
    In Auto-MDIX mode, the DP83848 will swap the TD+/- and RD+/- pins to account for a straight or crossed cable.  For applications using asymmetric magnetics, the device will see a different path based on the configuration that results from Auto-MDIX.  Using symmetric magnetics results in repeatable, symmetric results regardless of which MDI pair resolve as transmit and receive during Auto-MDIX.
    In general, we recommend using components with the series choke on the cable side of the transformer.  The DP83848 draws current from the transformer in order to develop the transmit voltage through the termination resistors.  A series choke on the device side of the magnetics will work against the efforts of the device to draw current from the transformer.
    Patrick
    Report Abuse
    • Reply
  • Kent Suzuki
    on Aug 01 2012 13:52 PM
    Prodigy30 points
    Hi Patrick,
    Thank you for a very thorough and clear explanation!
    Kent
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
