• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » LMH3087 against LMH0344 and LMH0302 combined
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 19 hours ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 7 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Onyx Ahiakwo
Posted by Onyx Ahiakwo
on Aug 09 2012 11:32 AM
Intellectual2495 points
Team,
Can the LMH0344 and LMH0302 together can perform the same functions as the LMH0387? If so what are the possible setbacks and loop holes to look out for.
thanks
Onyx
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Gary Melchior
    Posted by Gary Melchior
    on Aug 09 2012 15:12 PM
    Verified Answer
    Verified by Mark Sauerwald88474
    Intellectual1370 points
    Onyx,
    Hypothetically, yes, this is possible.  But in reality, it is a very tricky layout exercise to create a bidirectional I/O using a discrete equalizer and cable driver (such as the LMH0344 and LMH0302).  Performance is inherently compromised when combining the two functions.  There are several concerns:
    1. Return Loss:  The biggest problem is meeting the SMPTE return loss specification with good margin.  You have to compensate for 2x the circuit capacitance.  This requires a complex return loss network that must be tweaked and fine tuned – a time consuming and costly process likely requiring several board spins.  By integrating this network inside the LMH0387, we are able to optimize the return loss and provide 7-8 dB of margin to the SMPTE 424M specification.  This allows extremely easy board layout for customers – all that is required between the BNC and the LMH0387 is the AC-coupling capacitor, and its placement is not critical.  This saves on BOM costs and conserves board space.
    2. Cable Driver Output Eye:  You now have a complex network and added capacitance on your cable driver output, and this will negatively affect the cable driver output eye.  This can cause jitter, overshoot, ringing, and too slow (or not matched) rise/fall times.  We’ve taken care of all of this inside the LMH0387 and already optimized the cable driver output eye.
    3. Equalizer Performance:  This complex network affects the equalizer performance as well.  This requires a very careful layout to avoid impedance discontinuities and stubs that will severely impact cable length performance, especially at 3 Gbps rates.  Again, we already took care of this inside the LMH0387, and you only see a slight reduction in cable length performance vs. using a dedicated equalizer.
    If you attempt this discrete solution, you will have a very difficult layout exercise as described above.  Once (if) you are happy with the design after your efforts, you will have to support a board design with these many critical passive components.  Assembly issues such as bad solder joints will be a nightmare to troubleshoot.  This is another benefit of using the LMH0387: one device replaces two ICs and many (critical) passives.
    Gary Melchior
    Report Abuse
    • Reply
  • Onyx Ahiakwo
    on Aug 09 2012 15:16 PM
    Thank you Gary. I will relay this information over to the customer.
    Onyx
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
