• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » SERDESUB-16USB no PCLK on serializer side
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 6 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is not answered
Dang Tr
Posted by Dang Tr
on Aug 09 2012 12:30 PM
Prodigy60 points
I have the SERDESUB-16USB dev boards and I'm trying to communicate with a remote I2C slave without any success. The SERDESUB-16USB boards are configured in camera mode.
My question is, am I suppose to get a PCLK (25Mhz) on the Serializer side? Because I'm not getting a PCLK on the Serializer side. I am get a 25Mhz PCLK on the Deserializer.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Amritraj Khattoi
    Posted by Amritraj Khattoi
    on Aug 09 2012 12:46 PM
    Prodigy75 points
    Hi
    You will get the PCLK on the Deserializer side and not the Serializer side. Dac Tran is the applications engineer responsible for this chipset and he can help with remote I2C communication.
    Raj
    Report Abuse
    • Reply
  • Dac Tran
    Posted by Dac Tran
    on Aug 09 2012 13:09 PM
    Intellectual2525 points
    Hi Dang Tr,
    There is an internal 25MHz oscillator on the Serializer. However, the 25MHz cannot be accessed directly and will be serialized by 28*PCLK onto the FPD-Link III data stream.
    In camera mode, by default the Serializer is in a low-power Standby mode. The Deserializer requires a remote wake-up from Deserializer before starting any transmission. Please see DS90UB901/2 datasheet section for REMOTE WAKE UP (Camera Mode) procedure on pages 36-37.
    http://www.ti.com/lit/gpn/DS90UB901Q-Q1
    Dac Tran
    SVA / APPS
    Report Abuse
    • Reply
  • Dang Tr
    Posted by Dang Tr
    on Aug 10 2012 17:07 PM
    Prodigy60 points
    Dac,
    I implemented the REMOTE WAKE UP but I'm still not get a PCLK on the serializer side. Is it necessary to have PCLK on the serializer side in order to talk with remote I2C slave? I'm only trying to communicate with a remote I2C slave (a temperature sensor).
    From that Data sheet PCLK is an input. Also, from the SERDESUB-16USB User's Guild (snlu100.pdf) it said "The user needs to provide the proper 1.8V/3.3V LVCMOS inputs and 1.8V/3.3V LVCMOS
    clock to the Serializer". Please confirm that there is a internal 25MHz oscillator on the Serializer?
    Thank
    Dang
    Report Abuse
    • Reply
  • Dac Tran
    Posted by Dac Tran
    on Aug 10 2012 17:56 PM
    Hi Dang,
    The remote I2C link requires both the Serializer and Deserializer chipsets. On the Serializer side, the PCLK is an input only signal. If there is no valid PCLK input on the Serializer, it will automatically switch over to the internal 25MHz oscillator (following the remote wake sequence). Validate the Deserializer Lock pin is High before starting any I2C communication across the link.
    "The user needs to provide the proper 1.8V/3.3V LVCMOS inputs and 1.8V/3.3V LVCMOS clock to the Serializer" description in user manual refers to data transmission of the serdes interface to test equipment in order to check device functionality. However, the I2C communication does not require a PCLK input to work.
    Dac Tran
    SVA / APPS
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
