Hi Toshi,
The internal oscillator at 200MHz +/-30% is just for the pattern generator feature. For testing purposes, you can feed in external PCLK and control signals to use with the pattern generator. For your actual application, you will not be using the 200MHz clock, you will have an external clock coming from your source.
Does that answer your question?
Jason Blackman
