Hi Team,
Our customer is considering to use DS80PCI402 for non PCIe datarates, such as 5.94Gbps and 6.75Gbps. This part is registered part at their company. I understand this part is optimized for PCIe datarate, however, it could be used as a general repeater.
Here are some questions to use in such situation.
[Question]
When using at 5.94Gbps and 6.75Gbps, how should you set the RATE pin ?
Could you use in GEN2 mode for these datarates ?
Could we keep OPEN or should we set to Gen3 mode with DEM ?
[Question]
How does the effect of DEM differ by setting RATE pin to each of the 4 logic levels ?
What is the relation between the RATE pin setting and the DEM ?
[Question]
What does the "inner amplitude" in the table 3 of datasheet page 14 ?
Does this mean the attenuated voltage for lower frequency component ?
Kawai
