I am in need of an adaptive serial cable equalizer like the CLC014 that can oparate with a 100Mbps data rate. Unfortunately the CLC014 is now obsolete and there is no direct replacement. The LMH0034 would be a possible replacement but the specified minimum data rate is only 125Mbps (typical).
Are there any conditions under which the LMH0034 can be reliably operated down to 100Mbps?
Can you recommend a differential equalizer compatible with PECL and 100Mbps data rate?
