Hi Team,
Please allow me to ask you if DS125DF410 could support 6G-SDI scrambled data.
I understand that retimer could support the 6G-SDI data rate (5.94Gbps) if the VCO range is manually programmed.
I believe the device is not tested for SDI protocol, however, could you please tell us if the device could support 6G-SDI scrambled data or not ?
- There interface would not be 6G-SDI. They are considering optical interface.
- Data rate is not fixed yet, but, it may be 6G-SDI scrambled data or 8B10B encoded 5.x to 6.x Gbps data rate (around 6Gbps).
Thanks and Best Regards,
Kawai
