Hi all,
I am planning to use DS15MB200 for a SFP highspeed line switching application to create a fail-over path. SO LI_0 and LO_ will be connected to the SFP connector, while the
a. SOA_0 and SIA_B will be connected to the controller
b. SOB_0 and SIB_0 will be connected to another SFP
In this configuration if my controller fails , another simple controller will be switch data lines to other SFP.
My questions are,
1. Is there any application note for this IC?
2. Is there any recommended value for pull up/pull down resisters for ENx,SELx ... etc pins?
3. Where can I find layout guidelines for this? Or can I follow general high-speed routing guidelines?
4. Any decoupling capacitor value recommendations for this?
Thank you
