Dear support team
0x03[1] bit is Parity Error Reset bit.
If we set "1" at 0x03[1] , are 0x1a and 0x1b registers clear("00")?
Best Regards
Masaaki Sugiyama
Dear support team
Best Regards
Masaaki Sugiyama
That is correct. Keep in mind that 0x03[1] is NOT self-clearing bit. It must be set back to 0 to accumulate/count possible errors.
-Sean
Dear Sean-san
Thank you for your quick reply.
One more question.
0x1a and 0x1b registers become able to write in the datasheet.
0x1A | Parity Errors | 7:0 | Parity Error Byte 0 | RW | 0x00'h | Number of parity errors in the Forward channel during normal operation. Least significant Byte. |
0x1B | Parity Errors | 7:0 | Parity Error Byte 1 | RW | 0x00'h | Number of parity errors in the Forward channel during normal operation. Most significant Byte. |
But I tried to write 0x1a and 0x1b registers on EVM, I can not written.
Are these registeres read only?
Best Regards
Masaaki Sugiyama
These registers are read only. RW is a typo. Thank you for catching this.
-Sean
Dear Sean-san
Thank you for your kind support.
When you revise data sheet, please correct upper items, too.
Best Regards
Masaaki Sugiyama
