Hi Sir,
I have questions about the input equivalent circuit of the TxIN pin of the DS90C385A.
There is no equivalent circuit description of the input terminal in the DS90C385A data sheet.
There is a description that there is an internal pull-down resistor on the R_FB pin.
As with the R_FB terminal, is the TxIN pins built-in pull-down resistor ?
Is there a problem if putting the TxIN pins in the Hi-Z state for several usec ?
Hiroaki Masumoto
