hi team,
ds90ub921 and ds90ub940 can both support coax cable according to datasheet. Thus, is power over coax supported if using 921+940 pair?
thanks,
Mike
hi team,
thanks,
Mike
Mike,
yes, UB921/940 is fine tuned for coax cable application, it means the link design can compensate the coax cable loss etc.
For PoC, it is one application topic. in general, the PoC would introduce few noise (dependent on PoC circuit design). If both a and b can be met, you can use PoC from application view point.
a. If your link design can tolerate it (with margin); b. the PoC circuit can select the suitable inductors / FB (based on PoC requirements).
best regards,
Steven
