Other Parts Discussed in Thread: DS90UB913A-Q1
[ DS90UB914A-Q1 ] Resume Valid Output After Reconnect a Cable
My customer has reported that some of their ECUs (DS90UB914A-Q1 mounted) does not resume the output, even though a camera cable is connected again.
Here is the result.
- Let camera(DS90UB913A-Q1) and ECU work as normal
- Disconnect FPD-Link III cable. DS90UB914A-Q1 goes into loss of lock condition, output signal is no longer valid.
- Re-connect cable
- Some of ECUs resume the valid output, but some other does not resume.
Can you comment on this which shows different behavior?
I have adviced customer that a reset with either PDB or I2C is recommended after event of cable disconnect and loss of lock.
Thank you for your support in advance.
Ken
