According to the datasheet, LOCK pin is TRI-STATE during PDB=LOW as below.
Should the LOCK pin be connected with pull down resistor?
If yes, how much resistors should be set?
Kuramochi
Kuramochi
Hi Team,
My customer's system has diagnostic function and LOCK signal is used it.
So they must connect the pull down resistor to output Lo during PDB=Low.
What ohms resister should they connect?
Kuramochi
